[opa-nightly-tests] jam OPA_Daily_Tests_0318Fri_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Fri Mar 18 00:18:46 CDT 2011
*** OPA Tests on 0318Fri ***
   Tests Summary
****FAILED duty: standard****
PASSED amani: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED linew: standard
   Tests Time Summary
duty: Ran 1(0/1/0) tests, Grand total test time =  0m 28s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 23s
amani: Ran 1(1/0/0) tests, Grand total test time =  1m 49s
heiwa: Ran 1(1/0/0) tests, Grand total test time =  5m 29s
linew: Ran 1(1/0/0) tests, Grand total test time =  7m 28s
jam: Ran 6(0/0/0) hosts, Grand total test time =  8m 26s
   Timekeeper log
Timekeeper started at Fri Mar 18 00:10:31 CDT 2011
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0318Fri_0010
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
                 from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Fri Mar 18 00:11:24 CDT 2011 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:10:10 up 42 days, 14:42, 61 users,  load average: 1.13, 1.07, 1.04
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   3986228  26113964  14% /
/dev/sda1               101086     22885     72982  24% /boot
/dev/sda2             31738420   2563048  27537144   9% /tmp
/dev/sda6             31738392   5975412  24124756  20% /var
/dev/sda7             31738392  28931672   1168496  97% /usr
/dev/sda8            124991068  10812900 107726468  10% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  15359188 172754292   9% /home
/dev/sde1            565688764 377186984 159302844  71% /scr
/dev/sdc1            961432072 800969220 111624852  88% /mnt/scr1
/dev/sdd1            961432072 865689288  46904784  95% /mnt/hdf
tmpfs                  8313848        16   8313832   1% /dev/shm
gumund:/data/ftp     480719072 279324832 176975040  62% /mnt/ftp
gumund:/data/web     480719072 279324832 176975040  62% /mnt/web
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/ro-src
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0318Fri
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0318Fri.14038: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0318Fri.14038': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
duty
liberty
    Fork off timekeeper 30
cannot remote command with liberty
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
 12:10am  up 6 day(s),  6:07,  3 users,  load average: 1.23, 0.92, 0.47
/                  (/dev/dsk/c1t0d0s0 ):71314340 blocks  8272033 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483607 files
/proc              (proc              ):       0 blocks    29930 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ):20919200 blocks  1182210 files
/system/object     (objfs             ):       0 blocks 2147483494 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):71314340 blocks  8272033 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):71314340 blocks  8272033 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ):20919200 blocks  1182210 files
/var/run           (swap              ):20919200 blocks  1182210 files
/scr               (/dev/dsk/c1t1d0s0 ):896572552 blocks 226812135 files
/home              (jam:/home         ):365985304 blocks 50915117 files
/mnt/hdf           (jam:/mnt/hdf      ):191485568 blocks 114312788 files
/mnt/scr1          (jam:/mnt/scr1     ):320924032 blocks 116244023 files
/mnt/web           (gumund:/mnt/web   ):402788432 blocks 60893679 files
/mnt/ftp           (gumund:/mnt/ftp   ):402788432 blocks 60893679 files
TEST_TYPES=standard
Fri Mar 18 00:10:51 CDT 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/linew_0318Fri_0010
*** finished standard tests for linew ***
Fri Mar 18 00:18:13 CDT 2011
Total time = 7m 23s
*** finished tests in linew ***
Fri Mar 18 00:18:15 CDT 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 00:10:38 up 42 days, 14:42, 61 users,  load average: 1.36, 1.12, 1.06
/dev/sda2             31738420   2563172  27537020   9% /tmp
/dev/sda6             31738392   5975416  24124752  20% /var
/dev/sdc1            961432072 800970096 111623976  88% /mnt/scr1
TEST_TYPES=standard
Fri Mar 18 00:10:48 CDT 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0318Fri_0010
*** finished standard tests for jam ***
Fri Mar 18 00:12:11 CDT 2011
Total time = 1m 23s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
 00:10:41 up 31 days, 10:40,  2 users,  load average: 0.00, 0.00, 0.03
/dev/hda6             39021196  29697328   7309724  81% /
/dev/hda3             12192636   4221740   7341552  37% /var
/dev/hda2             12192636    208588  11354704   2% /tmp
/dev/hda1               101086     23784     72083  25% /boot
tmpfs                  2057868         0   2057868   0% /dev/shm
jam:/home            198351840  15359168 172754304   9% /home
jam:/mnt/hdf         961432096 865689312  46904800  95% /mnt/hdf
jam:/mnt/scr1        961432096 800970208 111623904  88% /mnt/scr1
smirom:/scr          267601440  37497024 216291712  15% /mnt/tmp
/dev/sdb1            144221592  74530020  62365532  55% /scr
/dev/sda1            288451232 179573436  94225316  66% /mnt/rw-src
TEST_TYPES=standard
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-194.32.1.el5 #1 SMP Wed Jan 5 17:52:25 EST 2011 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/amani_0318Fri_0010
*** finished standard tests for amani ***
Fri Mar 18 00:12:40 CDT 2011
Total time = 1m 49s
*** finished tests in amani ***
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
 00:10:41 up 13 days, 11:41,  4 users,  load average: 0.25, 0.19, 0.11
/dev/sdb8             35435232   2727628  30907564   9% /
tmpfs                  2008144         0   2008144   0% /dev/shm
/dev/sdb4               198337    106660     81437  57% /boot
/dev/sdb6             12385456   1372960  10383352  12% /tmp
/dev/sdb7             12385456   7281500   4474812  62% /var
/dev/sda6             82573108    686812  77691728   1% /scr
jam:/mnt/scr1        961432096 800970304 111623808  88% /mnt/scr1
TEST_TYPES=standard
Fri Mar 18 00:10:52 CDT 2011
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0318Fri_0010
*** finished standard tests for heiwa ***
Fri Mar 18 00:16:20 CDT 2011
Total time = 5m 28s
*** finished tests in heiwa ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM  up 78 days,  8:25, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/aacd0s1a       507630     60986    406034    13%    /
devfs                    1         1         0   100%    /dev
/dev/aacd0s1h    188433016 123604522  49753854    71%    /data
/dev/aacd0s1g     32494668  24660236   5234860    82%    /local_home
/dev/aacd0s1f     12186190   4125638   7085658    37%    /usr
/dev/aacd0s1d       507630     50426    416594    11%    /var
/dev/aacd0s1e       253678       178    233206     0%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840  15359188 172754292     8%    /home
jam:/mnt/hdf     961432072 865689288  46904784    95%    /mnt/hdf
jam:/mnt/scr1    961432072 800970352 111623720    88%    /mnt/scr1
gumund:/data/web 480719056 279324840 176975016    61%    /mnt/web
gumund:/data/ftp 480719056 279324840 176975016    61%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702        94    116472     0%    /tmp
TEST_TYPES=standard
Fri Mar 18 00:10:56 CDT 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
*** finished standard tests for duty ***
Total time = 0m 28s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
	****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
liberty does not accept Remote Command (Fri Mar 18 00:11:20 CDT 2011)
	****SYSTEM ERROR: liberty does not accept Remote Command (Fri Mar 18 00:11:20 CDT 2011)
	****INCOMPLETE liberty: snaptest did not complete****
More information about the opa-nightly-tests mailing list
