[opa-nightly-tests] jam OPA_Daily_Tests_0315Tue_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Tue Mar 15 00:19:06 CDT 2011
*** OPA Tests on 0315Tue ***
   Tests Summary
****FAILED duty: standard****
PASSED amani: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED linew: standard
   Tests Time Summary
duty: Ran 1(0/1/0) tests, Grand total test time =  0m 27s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 23s
amani: Ran 1(1/0/0) tests, Grand total test time =  1m 48s
heiwa: Ran 1(1/0/0) tests, Grand total test time =  5m 27s
linew: Ran 1(1/0/0) tests, Grand total test time =  7m 48s
jam: Ran 6(0/0/0) hosts, Grand total test time =  8m 46s
   Timekeeper log
Timekeeper started at Tue Mar 15 00:10:31 CDT 2011
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0315Tue_0010
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
                 from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Tue Mar 15 00:11:22 CDT 2011 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:10:10 up 39 days, 14:42, 46 users,  load average: 1.09, 1.08, 1.06
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   3992288  26107904  14% /
/dev/sda1               101086     22885     72982  24% /boot
/dev/sda2             31738420   4091628  26008564  14% /tmp
/dev/sda6             31738392   5950936  24149232  20% /var
/dev/sda7             31738392  28926720   1173448  97% /usr
/dev/sda8            124991068  10812904 107726464  10% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  15269184 172844296   9% /home
/dev/sde1            565688764 376654820 159835008  71% /scr
/dev/sdc1            961432072 795313736 117280336  88% /mnt/scr1
/dev/sdd1            961432072 863326608  49267464  95% /mnt/hdf
tmpfs                  8313848         0   8313848   0% /dev/shm
gumund:/data/ftp     480719072 279307552 176992320  62% /mnt/ftp
gumund:/data/web     480719072 279307552 176992320  62% /mnt/web
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/ro-src
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0315Tue
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0315Tue.11943: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0315Tue.11943': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
duty
liberty
    Fork off timekeeper 30
cannot remote command with liberty
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
 12:10am  up 3 day(s),  6:07,  0 users,  load average: 1.20, 0.94, 0.48
/                  (/dev/dsk/c1t0d0s0 ):71314466 blocks  8272032 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483610 files
/proc              (proc              ):       0 blocks    29938 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ):21076512 blocks  1182227 files
/system/object     (objfs             ):       0 blocks 2147483497 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):71314466 blocks  8272032 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):71314466 blocks  8272032 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ):21076512 blocks  1182227 files
/var/run           (swap              ):21076512 blocks  1182227 files
/scr               (/dev/dsk/c1t1d0s0 ):896156236 blocks 226813902 files
/home              (jam:/home         ):366165312 blocks 50916866 files
/mnt/hdf           (jam:/mnt/hdf      ):196210928 blocks 114311674 files
/mnt/scr1          (jam:/mnt/scr1     ):332232280 blocks 116340667 files
/mnt/web           (gumund:/mnt/web   ):402823000 blocks 60893713 files
/mnt/ftp           (gumund:/mnt/ftp   ):402823000 blocks 60893713 files
TEST_TYPES=standard
Tue Mar 15 00:10:53 CDT 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/linew_0315Tue_0010
*** finished standard tests for linew ***
Tue Mar 15 00:18:33 CDT 2011
Total time = 7m 40s
*** finished tests in linew ***
Tue Mar 15 00:18:34 CDT 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 00:10:38 up 39 days, 14:42, 46 users,  load average: 1.18, 1.10, 1.07
/dev/sda2             31738420   4091752  26008440  14% /tmp
/dev/sda6             31738392   5950944  24149224  20% /var
/dev/sdc1            961432072 795315940 117278132  88% /mnt/scr1
TEST_TYPES=standard
Tue Mar 15 00:10:48 CDT 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0315Tue_0010
*** finished standard tests for jam ***
Tue Mar 15 00:12:11 CDT 2011
Total time = 1m 23s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
 00:10:41 up 28 days, 10:40,  2 users,  load average: 0.00, 0.00, 0.00
/dev/hda6             39021196  29684032   7323020  81% /
/dev/hda3             12192636   4247884   7315408  37% /var
/dev/hda2             12192636    162540  11400752   2% /tmp
/dev/hda1               101086     23784     72083  25% /boot
tmpfs                  2057868         0   2057868   0% /dev/shm
jam:/home            198351840  15269184 172844320   9% /home
jam:/mnt/hdf         961432096 863326624  49267488  95% /mnt/hdf
jam:/mnt/scr1        961432096 795315968 117278144  88% /mnt/scr1
smirom:/scr          267601440  37497024 216291712  15% /mnt/tmp
/dev/sdb1            144221592  74792348  62103204  55% /scr
/dev/sda1            288451232 179573436  94225316  66% /mnt/rw-src
TEST_TYPES=standard
Tue Mar 15 00:10:51 CDT 2011
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-194.32.1.el5 #1 SMP Wed Jan 5 17:52:25 EST 2011 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/amani_0315Tue_0010
*** finished standard tests for amani ***
Tue Mar 15 00:12:39 CDT 2011
Total time = 1m 48s
*** finished tests in amani ***
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
 00:10:41 up 10 days, 11:41,  2 users,  load average: 0.00, 0.00, 0.00
/dev/sdb8             35435232   2727624  30907568   9% /
tmpfs                  2008144         0   2008144   0% /dev/shm
/dev/sdb4               198337    106660     81437  57% /boot
/dev/sdb6             12385456   1372944  10383368  12% /tmp
/dev/sdb7             12385456   7280688   4475624  62% /var
/dev/sda6             82573108    686812  77691728   1% /scr
TEST_TYPES=standard
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0315Tue_0010
*** finished standard tests for heiwa ***
Tue Mar 15 00:16:18 CDT 2011
Total time = 5m 27s
*** finished tests in heiwa ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM  up 75 days,  8:25, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/aacd0s1a       507630     60986    406034    13%    /
devfs                    1         1         0   100%    /dev
/dev/aacd0s1h    188433016 123604522  49753854    71%    /data
/dev/aacd0s1g     32494668  24660234   5234862    82%    /local_home
/dev/aacd0s1f     12186190   4125638   7085658    37%    /usr
/dev/aacd0s1d       507630     50498    416522    11%    /var
/dev/aacd0s1e       253678       178    233206     0%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840  15269184 172844296     8%    /home
jam:/mnt/hdf     961432072 863326608  49267464    95%    /mnt/hdf
jam:/mnt/scr1    961432072 795315964 117278108    87%    /mnt/scr1
gumund:/data/web 480719056 279307556 176992300    61%    /mnt/web
gumund:/data/ftp 480719056 279307556 176992300    61%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702        94    116472     0%    /tmp
TEST_TYPES=standard
Tue Mar 15 00:10:55 CDT 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
*** finished standard tests for duty ***
Total time = 0m 27s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
	****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
liberty does not accept Remote Command (Tue Mar 15 00:11:19 CDT 2011)
	****SYSTEM ERROR: liberty does not accept Remote Command (Tue Mar 15 00:11:19 CDT 2011)
	****INCOMPLETE liberty: snaptest did not complete****
More information about the opa-nightly-tests mailing list
