[opa-nightly-tests] jam OPA_Daily_Tests_0312Sat_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Sat Mar 12 00:19:05 CST 2011
*** OPA Tests on 0312Sat ***
   Tests Summary
****FAILED duty: standard****
PASSED amani: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED linew: standard
   Tests Time Summary
duty: Ran 1(0/1/0) tests, Grand total test time =  0m 27s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 22s
amani: Ran 1(1/0/0) tests, Grand total test time =  1m 48s
heiwa: Ran 1(1/0/0) tests, Grand total test time =  5m 33s
linew: Ran 1(1/0/0) tests, Grand total test time =  7m 46s
jam: Ran 6(0/0/0) hosts, Grand total test time =  8m 45s
   Timekeeper log
Timekeeper started at Sat Mar 12 00:10:32 CST 2011
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0312Sat_0010
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
                 from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Sat Mar 12 00:11:24 CST 2011 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:10:10 up 36 days, 15:42, 68 users,  load average: 1.16, 1.15, 1.22
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   3994448  26105744  14% /
/dev/sda1               101086     22885     72982  24% /boot
/dev/sda2             31738420   6579584  23520608  22% /tmp
/dev/sda6             31738392   6029232  24070936  21% /var
/dev/sda7             31738392  28921184   1178984  97% /usr
/dev/sda8            124991068  10825272 107714096  10% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  15267940 172845540   9% /home
/dev/sde1            565688764 376095000 160394828  71% /scr
/dev/sdc1            961432072 794466460 118127612  88% /mnt/scr1
/dev/sdd1            961432072 862411968  50182104  95% /mnt/hdf
tmpfs                  8313848         0   8313848   0% /dev/shm
gumund:/data/ftp     480719072 279305888 176993984  62% /mnt/ftp
gumund:/data/web     480719072 279305888 176993984  62% /mnt/web
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/ro-src
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0312Sat
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0312Sat.10348: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0312Sat.10348': No such file or directory
Sat Mar 12 00:10:31 CST 2011
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
duty
liberty
    Fork off timekeeper 30
cannot remote command with liberty
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
 12:10am  up  7:07,  0 users,  load average: 1.20, 0.95, 0.57
/                  (/dev/dsk/c1t0d0s0 ):71315166 blocks  8272032 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483611 files
/proc              (proc              ):       0 blocks    29940 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ):21475872 blocks  1182237 files
/system/object     (objfs             ):       0 blocks 2147483499 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):71315166 blocks  8272032 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):71315166 blocks  8272032 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ):21475872 blocks  1182237 files
/var/run           (swap              ):21475872 blocks  1182237 files
/scr               (/dev/dsk/c1t1d0s0 ):896218562 blocks 226812745 files
/home              (jam:/home         ):366167800 blocks 50916833 files
/mnt/hdf           (jam:/mnt/hdf      ):198040208 blocks 114314881 files
/mnt/scr1          (jam:/mnt/scr1     ):333929784 blocks 116400509 files
/mnt/web           (gumund:/mnt/web   ):402826368 blocks 60893715 files
/mnt/ftp           (gumund:/mnt/ftp   ):402826368 blocks 60893715 files
TEST_TYPES=standard
Sat Mar 12 00:10:53 CST 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/linew_0312Sat_0010
*** finished standard tests for linew ***
Sat Mar 12 00:18:33 CST 2011
Total time = 7m 40s
*** finished tests in linew ***
Sat Mar 12 00:18:34 CST 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 00:10:39 up 36 days, 15:42, 68 users,  load average: 1.36, 1.20, 1.23
/dev/sda2             31738420   6579704  23520488  22% /tmp
/dev/sda6             31738392   6029236  24070932  21% /var
/dev/sdc1            961432072 794467192 118126880  88% /mnt/scr1
TEST_TYPES=standard
Sat Mar 12 00:10:49 CST 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0312Sat_0010
*** finished standard tests for jam ***
Sat Mar 12 00:12:11 CST 2011
Total time = 1m 22s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
 00:10:42 up 25 days, 11:40,  4 users,  load average: 0.00, 0.00, 0.00
/dev/hda6             39021196  29668836   7338216  81% /
/dev/hda3             12192636   4205440   7357852  37% /var
/dev/hda2             12192636    162548  11400744   2% /tmp
/dev/hda1               101086     23784     72083  25% /boot
tmpfs                  2057868         0   2057868   0% /dev/shm
jam:/home            198351840  15267936 172845568   9% /home
jam:/mnt/hdf         961432096 862411968  50182112  95% /mnt/hdf
jam:/mnt/scr1        961432096 794467296 118126816  88% /mnt/scr1
smirom:/scr          267601440  37497024 216291712  15% /mnt/tmp
/dev/sdb1            144221592  74464936  62430616  55% /scr
/dev/sda1            288451232 179573436  94225316  66% /mnt/rw-src
TEST_TYPES=standard
Sat Mar 12 00:10:52 CST 2011
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-194.32.1.el5 #1 SMP Wed Jan 5 17:52:25 EST 2011 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/amani_0312Sat_0010
*** finished standard tests for amani ***
Sat Mar 12 00:12:40 CST 2011
Total time = 1m 48s
*** finished tests in amani ***
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
 00:10:43 up 7 days, 12:41,  5 users,  load average: 0.00, 0.01, 0.00
/dev/sdb8             35435232   2727756  30907436   9% /
tmpfs                  2008144         0   2008144   0% /dev/shm
/dev/sdb4               198337    106660     81437  57% /boot
/dev/sdb6             12385456   1372968  10383344  12% /tmp
/dev/sdb7             12385456   7292576   4463736  63% /var
/dev/sda6             82573108    686812  77691728   1% /scr
jam:/mnt/scr1        961432096 794467360 118126720  88% /mnt/scr1
TEST_TYPES=standard
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0312Sat_0010
*** finished standard tests for heiwa ***
Sat Mar 12 00:16:26 CST 2011
Total time = 5m 33s
*** finished tests in heiwa ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM  up 72 days,  9:25, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/aacd0s1a       507630     60986    406034    13%    /
devfs                    1         1         0   100%    /dev
/dev/aacd0s1h    188433016 123604522  49753854    71%    /data
/dev/aacd0s1g     32494668  24660234   5234862    82%    /local_home
/dev/aacd0s1f     12186190   4125638   7085658    37%    /usr
/dev/aacd0s1d       507630     50540    416480    11%    /var
/dev/aacd0s1e       253678       178    233206     0%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840  15267940 172845540     8%    /home
jam:/mnt/hdf     961432072 862411968  50182104    95%    /mnt/hdf
jam:/mnt/scr1    961432072 794467452 118126620    87%    /mnt/scr1
gumund:/data/web 480719056 279305872 176993984    61%    /mnt/web
gumund:/data/ftp 480719056 279305872 176993984    61%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702        94    116472     0%    /tmp
TEST_TYPES=standard
Sat Mar 12 00:10:57 CST 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
*** finished standard tests for duty ***
Total time = 0m 27s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
	****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
liberty does not accept Remote Command (Sat Mar 12 00:11:20 CST 2011)
	****SYSTEM ERROR: liberty does not accept Remote Command (Sat Mar 12 00:11:20 CST 2011)
	****INCOMPLETE liberty: snaptest did not complete****
More information about the opa-nightly-tests mailing list
