[opa-nightly-tests] jam OPA_Daily_Tests_0309Wed_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Wed Mar 9 00:18:51 CST 2011
*** OPA Tests on 0309Wed ***
   Tests Summary
****FAILED duty: standard****
PASSED amani: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED linew: standard
   Tests Time Summary
duty: Ran 1(0/1/0) tests, Grand total test time =  0m 30s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 21s
amani: Ran 1(1/0/0) tests, Grand total test time =  1m 49s
heiwa: Ran 1(1/0/0) tests, Grand total test time =  5m 34s
linew: Ran 1(1/0/0) tests, Grand total test time =  7m 34s
jam: Ran 6(0/0/0) hosts, Grand total test time =  8m 31s
   Timekeeper log
Timekeeper started at Wed Mar  9 00:10:31 CST 2011
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0309Wed_0010
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
                 from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a castmv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Wed Mar  9 00:11:25 CST 2011 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:10:10 up 33 days, 15:42, 76 users,  load average: 1.94, 1.92, 2.04
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   4122292  25977900  14% /
/dev/sda1               101086     22885     72982  24% /boot
/dev/sda2             31738420   3681800  26418392  13% /tmp
/dev/sda6             31738392   5969688  24130480  20% /var
/dev/sda7             31738392  28915064   1185104  97% /usr
/dev/sda8            124991068  10807012 107732356  10% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  15041868 173071612   8% /home
/dev/sde1            565688764 375484944 161004884  70% /scr
/dev/sdc1            961432072 794856668 117737404  88% /mnt/scr1
/dev/sdd1            961432072 829255316  83338756  91% /mnt/hdf
tmpfs                  8313848         0   8313848   0% /dev/shm
gumund:/data/ftp     480719072 277803424 178496448  61% /mnt/ftp
gumund:/data/web     480719072 277803424 178496448  61% /mnt/web
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/ro-src
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0309Wed
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0309Wed.32035: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0309Wed.32035': No such file or directory
Wed Mar  9 00:10:30 CST 2011
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
duty
liberty
    Fork off timekeeper 30
cannot remote command with liberty
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
 12:10am  up 5 day(s),  8:23,  9 users,  load average: 1.22, 0.95, 0.62
/                  (/dev/dsk/c1t0d0s0 ):71286474 blocks  8272080 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483601 files
/proc              (proc              ):       0 blocks    29910 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ):20626912 blocks  1182199 files
/system/object     (objfs             ):       0 blocks 2147483452 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):71286474 blocks  8272080 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):71286474 blocks  8272080 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ):20626912 blocks  1182199 files
/var/run           (swap              ):20626912 blocks  1182199 files
/home              (jam:/home         ):366619944 blocks 50921510 files
/mnt/hdf           (jam:/mnt/hdf      ):264353512 blocks 114344495 files
/mnt/scr1          (jam:/mnt/scr1     ):333149552 blocks 116422519 files
/mnt/web           (gumund:/mnt/web   ):405831296 blocks 60891554 files
/mnt/ftp           (gumund:/mnt/ftp   ):405831296 blocks 60891554 files
/scr               (/dev/dsk/c1t1d0s0 ):895581754 blocks 226813716 files
TEST_TYPES=standard
Wed Mar  9 00:10:53 CST 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/linew_0309Wed_0010
*** finished standard tests for linew ***
Wed Mar  9 00:18:19 CST 2011
Total time = 7m 27s
*** finished tests in linew ***
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 00:10:38 up 33 days, 15:42, 76 users,  load average: 2.32, 2.01, 2.06
/dev/sda2             31738420   3681920  26418272  13% /tmp
/dev/sda6             31738392   5969692  24130476  20% /var
/dev/sdc1            961432072 794857328 117736744  88% /mnt/scr1
TEST_TYPES=standard
Wed Mar  9 00:10:48 CST 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0309Wed_0010
*** finished standard tests for jam ***
Wed Mar  9 00:12:09 CST 2011
Total time = 1m 21s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
 00:10:40 up 22 days, 11:40,  2 users,  load average: 0.00, 0.00, 0.05
/dev/hda6             39021196  29654476   7352576  81% /
/dev/hda3             12192636   4341292   7222000  38% /var
/dev/hda2             12192636    162540  11400752   2% /tmp
/dev/hda1               101086     23784     72083  25% /boot
tmpfs                  2057868         0   2057868   0% /dev/shm
jam:/home            198351840  15041856 173071616   8% /home
jam:/mnt/hdf         961432096 829255328  83338784  91% /mnt/hdf
jam:/mnt/scr1        961432096 794857376 117736704  88% /mnt/scr1
smirom:/scr          267601440  37497024 216291712  15% /mnt/tmp
/dev/sdb1            144221592  74833672  62061880  55% /scr
/dev/sda1            288451232 179573436  94225316  66% /mnt/rw-src
TEST_TYPES=standard
Wed Mar  9 00:10:51 CST 2011
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-194.32.1.el5 #1 SMP Wed Jan 5 17:52:25 EST 2011 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/amani_0309Wed_0010
*** finished standard tests for amani ***
Wed Mar  9 00:12:39 CST 2011
Total time = 1m 48s
*** finished tests in amani ***
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
 00:10:42 up 4 days, 12:41,  2 users,  load average: 0.00, 0.00, 0.00
/dev/sdb8             35435232   2727752  30907440   9% /
tmpfs                  2008144         0   2008144   0% /dev/shm
/dev/sdb4               198337    106660     81437  57% /boot
/dev/sdb6             12385456   1372760  10383552  12% /tmp
/dev/sdb7             12385456   7274268   4482044  62% /var
/dev/sda6             82573108    686812  77691728   1% /scr
jam:/mnt/scr1        961432096 794857504 117736576  88% /mnt/scr1
TEST_TYPES=standard
Wed Mar  9 00:10:52 CST 2011
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0309Wed_0010
*** finished standard tests for heiwa ***
Wed Mar  9 00:16:26 CST 2011
Total time = 5m 34s
*** finished tests in heiwa ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM  up 69 days,  9:25, 0 users, load averages: 0.08, 0.07, 0.01
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/aacd0s1a       507630     60986    406034    13%    /
devfs                    1         1         0   100%    /dev
/dev/aacd0s1h    188433016 123604522  49753854    71%    /data
/dev/aacd0s1g     32494668  25798608   4096488    86%    /local_home
/dev/aacd0s1f     12186190   4125638   7085658    37%    /usr
/dev/aacd0s1d       507630     50370    416650    11%    /var
/dev/aacd0s1e       253678       178    233206     0%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840  15041868 173071612     8%    /home
jam:/mnt/hdf     961432072 829255316  83338756    91%    /mnt/hdf
jam:/mnt/scr1    961432072 794857524 117736548    87%    /mnt/scr1
gumund:/data/web 480719056 277803408 178496448    61%    /mnt/web
gumund:/data/ftp 480719056 277803408 178496448    61%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702       102    116464     0%    /tmp
TEST_TYPES=standard
Wed Mar  9 00:10:55 CST 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
*** finished standard tests for duty ***
Total time = 0m 30s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
	****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
liberty does not accept Remote Command (Wed Mar  9 00:11:18 CST 2011)
	****SYSTEM ERROR: liberty does not accept Remote Command (Wed Mar  9 00:11:18 CST 2011)
	****INCOMPLETE liberty: snaptest did not complete****
More information about the opa-nightly-tests mailing list
