[opa-nightly-tests] jam OPA_Daily_Tests_0308Tue_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Tue Mar 8 00:18:45 CST 2011
*** OPA Tests on 0308Tue ***
Tests Summary
****FAILED duty: standard****
PASSED amani: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED linew: standard
Tests Time Summary
duty: Ran 1(0/1/0) tests, Grand total test time = 0m 26s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 22s
amani: Ran 1(1/0/0) tests, Grand total test time = 1m 49s
heiwa: Ran 1(1/0/0) tests, Grand total test time = 5m 32s
linew: Ran 1(1/0/0) tests, Grand total test time = 7m 28s
jam: Ran 6(0/0/0) hosts, Grand total test time = 8m 25s
Timekeeper log
Timekeeper started at Tue Mar 8 00:10:31 CST 2011
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0308Tue_0010
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specifiedmv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Tue Mar 8 00:11:21 CST 2011 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:10:10 up 32 days, 15:42, 67 users, load average: 1.35, 1.18, 1.11
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 4124096 25976096 14% /
/dev/sda1 101086 22885 72982 24% /boot
/dev/sda2 31738420 3498188 26602004 12% /tmp
/dev/sda6 31738392 5934184 24165984 20% /var
/dev/sda7 31738392 28913364 1186804 97% /usr
/dev/sda8 124991068 10807008 107732360 10% /var/tmp
/dev/mapper/VolGroup00-home
198351840 14974228 173139252 8% /home
/dev/sde1 565688764 375484696 161005132 70% /scr
/dev/sdc1 961432072 825662168 86931904 91% /mnt/scr1
/dev/sdd1 961432072 828992788 83601284 91% /mnt/hdf
tmpfs 8313848 0 8313848 0% /dev/shm
gumund:/data/ftp 480719072 278195040 178104832 61% /mnt/ftp
gumund:/data/web 480719072 278195040 178104832 61% /mnt/web
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/ro-src
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0308Tue
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0308Tue.18932: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0308Tue.18932': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
duty
liberty
Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
12:10am up 4 day(s), 8:23, 9 users, load average: 1.20, 0.94, 0.49
/ (/dev/dsk/c1t0d0s0 ):71287046 blocks 8272080 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483601 files
/proc (proc ): 0 blocks 29909 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):17501248 blocks 1182199 files
/system/object (objfs ): 0 blocks 2147483453 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):71287046 blocks 8272080 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):71287046 blocks 8272080 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):17501248 blocks 1182199 files
/var/run (swap ):17501248 blocks 1182199 files
/home (jam:/home ):366755224 blocks 50923530 files
/mnt/hdf (jam:/mnt/hdf ):264878568 blocks 114341246 files
/mnt/scr1 (jam:/mnt/scr1 ):271539760 blocks 116439739 files
/mnt/web (gumund:/mnt/web ):405048008 blocks 60891487 files
/mnt/ftp (gumund:/mnt/ftp ):405048008 blocks 60891487 files
/scr (/dev/dsk/c1t1d0s0 ):900155988 blocks 226824832 files
TEST_TYPES=standard
Tue Mar 8 00:10:52 CST 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0308Tue_0010
*** finished standard tests for linew ***
Tue Mar 8 00:18:13 CST 2011
Total time = 7m 22s
*** finished tests in linew ***
Tue Mar 8 00:18:14 CST 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:10:38 up 32 days, 15:42, 67 users, load average: 1.34, 1.19, 1.12
/dev/sda2 31738420 3498308 26601884 12% /tmp
/dev/sda6 31738392 5934188 24165980 20% /var
/dev/sdc1 961432072 825662200 86931872 91% /mnt/scr1
TEST_TYPES=standard
Tue Mar 8 00:10:48 CST 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0308Tue_0010
*** finished standard tests for jam ***
Tue Mar 8 00:12:10 CST 2011
Total time = 1m 22s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
00:10:41 up 21 days, 11:40, 3 users, load average: 0.00, 0.00, 0.00
/dev/hda6 39021196 29648900 7358152 81% /
/dev/hda3 12192636 4362484 7200808 38% /var
/dev/hda2 12192636 162544 11400748 2% /tmp
/dev/hda1 101086 23784 72083 25% /boot
tmpfs 2057868 0 2057868 0% /dev/shm
jam:/home 198351840 14974208 173139264 8% /home
jam:/mnt/hdf 961432096 828992800 83601312 91% /mnt/hdf
jam:/mnt/scr1 961432096 825662208 86931872 91% /mnt/scr1
smirom:/scr 267601440 37497024 216291712 15% /mnt/tmp
/dev/sdb1 144221592 74220864 62674688 55% /scr
/dev/sda1 288451232 179573436 94225316 66% /mnt/rw-src
TEST_TYPES=standard
Tue Mar 8 00:10:51 CST 2011
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-194.32.1.el5 #1 SMP Wed Jan 5 17:52:25 EST 2011 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/amani_0308Tue_0010
*** finished standard tests for amani ***
Tue Mar 8 00:12:40 CST 2011
Total time = 1m 49s
*** finished tests in amani ***
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
00:10:43 up 3 days, 12:41, 2 users, load average: 0.05, 0.02, 0.01
/dev/sdb8 35435232 2727764 30907428 9% /
tmpfs 2008144 0 2008144 0% /dev/shm
/dev/sdb4 198337 106660 81437 57% /boot
/dev/sdb6 12385456 1372764 10383548 12% /tmp
/dev/sdb7 12385456 7277948 4478364 62% /var
/dev/sda6 82573108 686812 77691728 1% /scr
jam:/mnt/scr1 961432096 825662240 86931872 91% /mnt/scr1
TEST_TYPES=standard
Tue Mar 8 00:10:53 CST 2011
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0308Tue_0010
*** finished standard tests for heiwa ***
Tue Mar 8 00:16:25 CST 2011
Total time = 5m 32s
*** finished tests in heiwa ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM up 68 days, 9:25, 6 users, load averages: 0.00, 0.00, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60986 406034 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 123604522 49753854 71% /data
/dev/aacd0s1g 32494668 25721298 4173798 86% /local_home
/dev/aacd0s1f 12186190 4125638 7085658 37% /usr
/dev/aacd0s1d 507630 50360 416660 11% /var
/dev/aacd0s1e 253678 178 233206 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 14974228 173139252 8% /home
jam:/mnt/hdf 961432072 828992788 83601284 91% /mnt/hdf
jam:/mnt/scr1 961432072 825662224 86931848 90% /mnt/scr1
gumund:/data/web 480719056 278195052 178104804 61% /mnt/web
gumund:/data/ftp 480719056 278195052 178104804 61% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 102 116464 0% /tmp
TEST_TYPES=standard
Tue Mar 8 00:10:56 CST 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
Tue Mar 8 00:11:22 CST 2011
*** finished standard tests for duty ***
Total time = 0m 26s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
liberty is not reachable (Tue Mar 8 00:10:48 CST 2011)
****SYSTEM ERROR: liberty is not reachable (Tue Mar 8 00:10:48 CST 2011)
****INCOMPLETE liberty: snaptest did not complete****
More information about the opa-nightly-tests
