[opa-nightly-tests] jam OPA_Daily_Tests_0307Mon_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Mon Mar 7 00:22:13 CST 2011
*** OPA Tests on 0307Mon ***
Tests Summary
****FAILED duty: standard****
PASSED amani: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED linew: standard
Tests Time Summary
duty: Ran 1(0/1/0) tests, Grand total test time = 0m 26s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 23s
amani: Ran 1(1/0/0) tests, Grand total test time = 1m 49s
heiwa: Ran 1(1/0/0) tests, Grand total test time = 5m 31s
linew: Ran 1(1/0/0) tests, Grand total test time = 10m 54s
jam: Ran 6(0/0/0) hosts, Grand total test time = 11m 53s
Timekeeper log
Timekeeper started at Mon Mar 7 00:10:31 CST 2011
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0307Mon_0010
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Mon Mar 7 00:11:23 CST 2011 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:10:10 up 31 days, 15:42, 58 users, load average: 2.17, 2.17, 2.43
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 4119924 25980268 14% /
/dev/sda1 101086 22885 72982 24% /boot
/dev/sda2 31738420 3349360 26750832 12% /tmp
/dev/sda6 31738392 5910452 24189716 20% /var
/dev/sda7 31738392 28913124 1187044 97% /usr
/dev/sda8 124991068 10781580 107757788 10% /var/tmp
/dev/mapper/VolGroup00-home
198351840 14982064 173131416 8% /home
/dev/sde1 565688764 374984696 161505132 70% /scr
/dev/sdc1 961432072 791132728 121461344 87% /mnt/scr1
/dev/sdd1 961432072 827301912 85292160 91% /mnt/hdf
tmpfs 8313848 0 8313848 0% /dev/shm
gumund:/data/ftp 480719072 278184832 178115040 61% /mnt/ftp
gumund:/data/web 480719072 278184832 178115040 61% /mnt/web
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/ro-src
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0307Mon
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0307Mon.20820: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0307Mon.20820': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
duty
liberty
Fork off timekeeper 30
cannot remote command with liberty
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
12:10am up 3 day(s), 8:23, 4 users, load average: 3.79, 3.28, 2.59
/ (/dev/dsk/c1t0d0s0 ):71286024 blocks 8272080 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483605 files
/proc (proc ): 0 blocks 29907 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):17633200 blocks 1182210 files
/system/object (objfs ): 0 blocks 2147483453 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):71286024 blocks 8272080 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):71286024 blocks 8272080 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):17633200 blocks 1182210 files
/var/run (swap ):17633200 blocks 1182210 files
/home (jam:/home ):366739552 blocks 50923252 files
/mnt/hdf (jam:/mnt/hdf ):268260320 blocks 114344310 files
/mnt/scr1 (jam:/mnt/scr1 ):340595528 blocks 116459495 files
/mnt/web (gumund:/mnt/web ):405068456 blocks 60891487 files
/mnt/ftp (gumund:/mnt/ftp ):405068456 blocks 60891487 files
/scr (/dev/dsk/c1t1d0s0 ):894416276 blocks 226827478 files
TEST_TYPES=standard
Mon Mar 7 00:11:01 CST 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0307Mon_0011
*** finished standard tests for linew ***
Mon Mar 7 00:21:40 CST 2011
Total time = 10m 40s
*** finished tests in linew ***
Mon Mar 7 00:21:42 CST 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:10:39 up 31 days, 15:42, 58 users, load average: 2.32, 2.21, 2.43
/dev/sda2 31738420 3349480 26750712 12% /tmp
/dev/sda6 31738392 5910456 24189712 20% /var
/dev/sdc1 961432072 791134400 121459672 87% /mnt/scr1
TEST_TYPES=standard
Mon Mar 7 00:10:49 CST 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0307Mon_0010
*** finished standard tests for jam ***
Mon Mar 7 00:12:12 CST 2011
Total time = 1m 23s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
00:10:42 up 20 days, 11:40, 2 users, load average: 0.08, 0.02, 0.11
/dev/hda6 39021196 29646320 7360732 81% /
/dev/hda3 12192636 4421120 7142172 39% /var
/dev/hda2 12192636 162540 11400752 2% /tmp
/dev/hda1 101086 23784 72083 25% /boot
tmpfs 2057868 0 2057868 0% /dev/shm
jam:/home 198351840 14982048 173131424 8% /home
jam:/mnt/hdf 961432096 827301920 85292160 91% /mnt/hdf
jam:/mnt/scr1 961432096 791134528 121459552 87% /mnt/scr1
smirom:/scr 267601440 37497024 216291712 15% /mnt/tmp
/dev/sdb1 144221592 74158708 62736844 55% /scr
/dev/sda1 288451232 179573436 94225316 66% /mnt/rw-src
TEST_TYPES=standard
Mon Mar 7 00:10:52 CST 2011
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-194.32.1.el5 #1 SMP Wed Jan 5 17:52:25 EST 2011 x86_64 x86_64 x86_64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/amani_0307Mon_0010
*** finished standard tests for amani ***
Mon Mar 7 00:12:41 CST 2011
Total time = 1m 49s
*** finished tests in amani ***
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
00:10:44 up 2 days, 12:41, 2 users, load average: 0.16, 0.03, 0.01
/dev/sdb8 35435232 2727764 30907428 9% /
tmpfs 2008144 0 2008144 0% /dev/shm
/dev/sdb4 198337 106660 81437 57% /boot
/dev/sdb6 12385456 1372764 10383548 12% /tmp
/dev/sdb7 12385456 7277172 4479140 62% /var
/dev/sda6 82573108 686812 77691728 1% /scr
jam:/mnt/scr1 961432096 791134720 121459392 87% /mnt/scr1
TEST_TYPES=standard
Mon Mar 7 00:10:54 CST 2011
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0307Mon_0010
*** finished standard tests for heiwa ***
Mon Mar 7 00:16:25 CST 2011
Total time = 5m 31s
*** finished tests in heiwa ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM up 67 days, 9:25, 0 users, load averages: 0.07, 0.05, 0.07
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60986 406034 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 123604522 49753854 71% /data
/dev/aacd0s1g 32494668 25721290 4173806 86% /local_home
/dev/aacd0s1f 12186190 4125638 7085658 37% /usr
/dev/aacd0s1d 507630 50508 416512 11% /var
/dev/aacd0s1e 253678 178 233206 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 14982064 173131416 8% /home
jam:/mnt/hdf 961432072 827301912 85292160 91% /mnt/hdf
jam:/mnt/scr1 961432072 791134748 121459324 87% /mnt/scr1
gumund:/data/web 480719056 278184828 178115028 61% /mnt/web
gumund:/data/ftp 480719056 278184828 178115028 61% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 102 116464 0% /tmp
TEST_TYPES=standard
Mon Mar 7 00:10:57 CST 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
*** finished standard tests for duty ***
Total time = 0m 26s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
liberty does not accept Remote Command (Mon Mar 7 00:11:20 CST 2011)
****SYSTEM ERROR: liberty does not accept Remote Command (Mon Mar 7 00:11:20 CST 2011)
****INCOMPLETE liberty: snaptest did not complete****
More information about the opa-nightly-tests
