[opa-nightly-tests] jam OPA_Daily_Tests_0304Fri_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Fri Mar 4 00:19:12 CST 2011
*** OPA Tests on 0304Fri ***
   Tests Summary
****FAILED duty: standard****
PASSED amani: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED linew: standard
   Tests Time Summary
duty: Ran 1(0/1/0) tests, Grand total test time =  0m 27s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 21s
amani: Ran 1(1/0/0) tests, Grand total test time =  1m 48s
heiwa: Ran 1(1/0/0) tests, Grand total test time =  5m 28s
linew: Ran 1(1/0/0) tests, Grand total test time =  7m 54s
jam: Ran 6(0/0/0) hosts, Grand total test time =  8m 52s
   Timekeeper log
Timekeeper started at Fri Mar  4 00:10:31 CST 2011
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0304Fri_0010
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
                 from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Fri Mar  4 00:11:22 CST 2011 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:10:10 up 28 days, 15:42, 46 users,  load average: 2.10, 2.07, 2.01
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   4134152  25966040  14% /
/dev/sda1               101086     22885     72982  24% /boot
/dev/sda2             31738420   2553308  27546884   9% /tmp
/dev/sda6             31738392   5929288  24170880  20% /var
/dev/sda7             31738392  28907388   1192780  97% /usr
/dev/sda8            124991068  10768780 107770588  10% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  14974844 173138636   8% /home
/dev/sde1            565688764 374792872 161696956  70% /scr
/dev/sdc1            961432072 779082804 133511268  86% /mnt/scr1
/dev/sdd1            961432072 824350988  88243084  91% /mnt/hdf
tmpfs                  8313848         0   8313848   0% /dev/shm
gumund:/data/ftp     480719072 278227232 178072640  61% /mnt/ftp
gumund:/data/web     480719072 278227232 178072640  61% /mnt/web
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/ro-src
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0304Fri
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0304Fri.22946: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0304Fri.22946': No such file or directory
Fri Mar  4 00:10:30 CST 2011
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
duty
liberty
    Fork off timekeeper 30
cannot remote command with liberty
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
 12:10am  up  8:23,  7 users,  load average: 1.09, 0.98, 0.54
/                  (/dev/dsk/c1t0d0s0 ):63376024 blocks  8252157 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483604 files
/proc              (proc              ):       0 blocks    29920 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ):21194080 blocks  1182214 files
/system/object     (objfs             ):       0 blocks 2147483454 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):63376024 blocks  8252157 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):63376024 blocks  8252157 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ):21194080 blocks  1182214 files
/var/run           (swap              ):21194080 blocks  1182214 files
/home              (jam:/home         ):366753992 blocks 50923293 files
/mnt/hdf           (jam:/mnt/hdf      ):274162168 blocks 114357333 files
/mnt/scr1          (jam:/mnt/scr1     ):364697128 blocks 116660391 files
/mnt/web           (gumund:/mnt/web   ):404983624 blocks 60891052 files
/mnt/ftp           (gumund:/mnt/ftp   ):404983624 blocks 60891052 files
/scr-new           (/dev/dsk/c1t1d0s0 ):915380496 blocks 226896187 files
TEST_TYPES=standard
Fri Mar  4 00:10:58 CST 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/linew_0304Fri_0010
*** finished standard tests for linew ***
Fri Mar  4 00:18:40 CST 2011
Total time = 7m 42s
*** finished tests in linew ***
Fri Mar  4 00:18:41 CST 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 00:10:38 up 28 days, 15:42, 46 users,  load average: 2.14, 2.07, 2.01
/dev/sda2             31738420   2553432  27546760   9% /tmp
/dev/sda6             31738392   5929292  24170876  20% /var
/dev/sdc1            961432072 779083548 133510524  86% /mnt/scr1
TEST_TYPES=standard
Fri Mar  4 00:10:48 CST 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0304Fri_0010
*** finished standard tests for jam ***
Fri Mar  4 00:12:09 CST 2011
Total time = 1m 21s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
 00:10:41 up 17 days, 11:40,  3 users,  load average: 0.00, 0.00, 0.00
/dev/hda6             39021196  29629104   7377948  81% /
/dev/hda3             12192636   4484488   7078804  39% /var
/dev/hda2             12192636    208616  11354676   2% /tmp
/dev/hda1               101086     23784     72083  25% /boot
tmpfs                  2057868         0   2057868   0% /dev/shm
jam:/home            198351840  14974816 173138656   8% /home
jam:/mnt/hdf         961432096 824351008  88243104  91% /mnt/hdf
jam:/mnt/scr1        961432096 779083584 133510496  86% /mnt/scr1
smirom:/scr          267601440  37497024 216291712  15% /mnt/tmp
/dev/sdb1            144221592  73958880  62936672  55% /scr
/dev/sda1            288451232 179573436  94225316  66% /mnt/rw-src
TEST_TYPES=standard
Fri Mar  4 00:10:51 CST 2011
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-194.32.1.el5 #1 SMP Wed Jan 5 17:52:25 EST 2011 x86_64 x86_64 x86_64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/amani_0304Fri_0010
*** finished standard tests for amani ***
Fri Mar  4 00:12:39 CST 2011
Total time = 1m 48s
*** finished tests in amani ***
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
 00:10:43 up 37 days, 10:43,  3 users,  load average: 0.29, 0.13, 0.05
/dev/sdb8             35435232   2727756  30907436   9% /
tmpfs                  2008144         0   2008144   0% /dev/shm
/dev/sdb4               198337    106660     81437  57% /boot
/dev/sdb6             12385456   1547860  10208452  14% /tmp
/dev/sdb7             12385456   7281412   4474900  62% /var
/dev/sda6             82573108    686812  77691728   1% /scr
jam:/mnt/scr1        961432096 779083680 133510432  86% /mnt/scr1
TEST_TYPES=standard
Fri Mar  4 00:10:53 CST 2011
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0304Fri_0010
*** finished standard tests for heiwa ***
Fri Mar  4 00:16:21 CST 2011
Total time = 5m 28s
*** finished tests in heiwa ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM  up 64 days,  9:25, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/aacd0s1a       507630     60986    406034    13%    /
devfs                    1         1         0   100%    /dev
/dev/aacd0s1h    188433016 123604522  49753854    71%    /data
/dev/aacd0s1g     32494668  25721286   4173810    86%    /local_home
/dev/aacd0s1f     12186190   4125638   7085658    37%    /usr
/dev/aacd0s1d       507630     50542    416478    11%    /var
/dev/aacd0s1e       253678       178    233206     0%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840  14974844 173138636     8%    /home
jam:/mnt/hdf     961432072 824350988  88243084    90%    /mnt/hdf
jam:/mnt/scr1    961432072 779083696 133510376    85%    /mnt/scr1
gumund:/data/web 480719056 278227244 178072612    61%    /mnt/web
gumund:/data/ftp 480719056 278227244 178072612    61%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702       100    116466     0%    /tmp
TEST_TYPES=standard
Fri Mar  4 00:10:55 CST 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
*** finished standard tests for duty ***
Total time = 0m 27s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
	****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
liberty does not accept Remote Command (Fri Mar  4 00:11:18 CST 2011)
	****SYSTEM ERROR: liberty does not accept Remote Command (Fri Mar  4 00:11:18 CST 2011)
	****INCOMPLETE liberty: snaptest did not complete****
More information about the opa-nightly-tests mailing list
