[opa-nightly-tests] jam OPA_Daily_Tests_0303Thu_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Thu Mar 3 00:19:19 CST 2011
*** OPA Tests on 0303Thu ***
   Tests Summary
****FAILED duty: standard****
****FAILED liberty: standard****
PASSED jam: standard
PASSED linew: standard
   Tests Time Summary
liberty: Ran 1(0/1/0) tests, Grand total test time =  0m 11s
duty: Ran 1(0/1/0) tests, Grand total test time =  0m 28s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 22s
linew: Ran 1(1/0/0) tests, Grand total test time =  8m 2s
jam: Ran 4(0/0/0) hosts, Grand total test time =  8m 59s
   Timekeeper log
Timekeeper started at Thu Mar  3 00:10:31 CST 2011
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of liberty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0303Thu_0010
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
                 from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Thu Mar  3 00:11:03 CST 2011 =====
Dumping done
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0303Thu_0010
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementationmv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
 specified
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
Failed running make
===== Exit bin/snapshot with status=0: Thu Mar  3 00:11:18 CST 2011 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:10:10 up 27 days, 15:42, 45 users,  load average: 3.01, 2.96, 2.96
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   4133176  25967016  14% /
/dev/sda1               101086     22885     72982  24% /boot
/dev/sda2             31738420   2552612  27547580   9% /tmp
/dev/sda6             31738392   5917872  24182296  20% /var
/dev/sda7             31738392  28906016   1194152  97% /usr
/dev/sda8            124991068  10768780 107770588  10% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  14949960 173163520   8% /home
/dev/sde1            565688764 373832312 162657516  70% /scr
/dev/sdc1            961432072 771597124 140996948  85% /mnt/scr1
/dev/sdd1            961432072 823485168  89108904  91% /mnt/hdf
tmpfs                  8313848         0   8313848   0% /dev/shm
gumund:/data/ftp     480719072 278223840 178076032  61% /mnt/ftp
gumund:/data/web     480719072 278223840 178076032  61% /mnt/web
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/ro-src
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0303Thu
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0303Thu.13571: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0303Thu.13571': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
duty
liberty
    Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
 12:10am  up  8:05,  2 users,  load average: 1.10, 0.98, 0.55
/                  (/dev/dsk/c1t0d0s0 ):67034818 blocks  8253129 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483609 files
/proc              (proc              ):       0 blocks    29922 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ):17952864 blocks  1182231 files
/system/object     (objfs             ):       0 blocks 2147483498 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):67034818 blocks  8253129 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):67034818 blocks  8253129 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ):17952864 blocks  1182231 files
/var/run           (swap              ):17952864 blocks  1182231 files
/home              (jam:/home         ):366803760 blocks 50923739 files
/mnt/hdf           (jam:/mnt/hdf      ):275893808 blocks 114357789 files
/mnt/scr1          (jam:/mnt/scr1     ):379668368 blocks 116669782 files
/mnt/web           (gumund:/mnt/web   ):404990416 blocks 60891055 files
/mnt/ftp           (gumund:/mnt/ftp   ):404990416 blocks 60891055 files
TEST_TYPES=standard
Thu Mar  3 00:10:58 CST 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/linew_0303Thu_0010
*** finished standard tests for linew ***
Thu Mar  3 00:18:47 CST 2011
Total time = 7m 50s
*** finished tests in linew ***
Thu Mar  3 00:18:48 CST 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 00:10:38 up 27 days, 15:42, 45 users,  load average: 3.14, 3.00, 2.97
/dev/sda2             31738420   2552736  27547456   9% /tmp
/dev/sda6             31738392   5917876  24182292  20% /var
/dev/sdc1            961432072 771597908 140996164  85% /mnt/scr1
TEST_TYPES=standard
Thu Mar  3 00:10:48 CST 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0303Thu_0010
*** finished standard tests for jam ***
Thu Mar  3 00:12:10 CST 2011
Total time = 1m 22s
*** finished tests in jam ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM  up 63 days,  9:25, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/aacd0s1a       507630     60986    406034    13%    /
devfs                    1         1         0   100%    /dev
/dev/aacd0s1h    188433016 123604522  49753854    71%    /data
/dev/aacd0s1g     32494668  25351748   4543348    85%    /local_home
/dev/aacd0s1f     12186190   4125638   7085658    37%    /usr
/dev/aacd0s1d       507630     50416    416604    11%    /var
/dev/aacd0s1e       253678       178    233206     0%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840  14949960 173163520     8%    /home
jam:/mnt/hdf     961432072 823485168  89108904    90%    /mnt/hdf
jam:/mnt/scr1    961432072 771597988 140996084    85%    /mnt/scr1
gumund:/data/web 480719056 278223848 178076008    61%    /mnt/web
gumund:/data/ftp 480719056 278223848 178076008    61%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702       102    116464     0%    /tmp
TEST_TYPES=standard
Thu Mar  3 00:10:50 CST 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
*** finished standard tests for duty ***
Total time = 0m 28s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
	****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname liberty
12:10AM  up 76 days, 13:18, 3 users, load averages: 0.00, 0.00, 0.00
/dev/aacd0s1a       507630     86918    380102    19%    /
/dev/aacd0s1g     47047830  32007990  11276014    74%    /local_home
/dev/aacd0s1f     12186190   7420280   3791016    66%    /usr
/dev/aacd0s1d      1012974    104098    827840    11%    /var
/dev/aacd0s1e       507630     62724    404296    13%    /var/tmp
jam:/mnt/scr1    961432072 771598072 140996000    85%    /mnt/scr1
/dev/md0            126702        24    116542     0%    /tmp
TEST_TYPES=standard
Thu Mar  3 00:10:52 CST 2011
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008     sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY  amd64
*** finished standard tests for liberty ***
Total time = 0m 11s
*** finished tests in liberty ***
****SYSTEM ERROR liberty: Abnormal exit from runtest ****
	****SYSTEM ERROR liberty: runtest command failed ****
More information about the opa-nightly-tests mailing list
