[opa-nightly-tests] jam OPA_Daily_Tests_0227Sun_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Sun Feb 27 00:19:15 CST 2011
*** OPA Tests on 0227Sun ***
Tests Summary
****FAILED duty: standard****
****FAILED liberty: standard****
PASSED jam: standard
PASSED linew: standard
Tests Time Summary
liberty: Ran 1(0/1/0) tests, Grand total test time = 0m 11s
duty: Ran 1(0/1/0) tests, Grand total test time = 0m 30s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 21s
linew: Ran 1(1/0/0) tests, Grand total test time = 7m 59s
jam: Ran 4(0/0/0) hosts, Grand total test time = 8m 56s
Timekeeper log
Timekeeper started at Sun Feb 27 00:10:30 CST 2011
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of liberty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0227Sun_0010
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Sun Feb 27 00:11:02 CST 2011 =====
Dumping done
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0227Sun_0010
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
Failed running make
===== Exit bin/snapshot with status=0: Sun Feb 27 00:11:19 CST 2011 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:10:09 up 23 days, 15:42, 55 users, load average: 2.20, 2.12, 2.09
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 4131164 25969028 14% /
/dev/sda1 101086 22885 72982 24% /boot
/dev/sda2 31738420 1886320 28213872 7% /tmp
/dev/sda6 31738392 6011908 24088260 20% /var
/dev/sda7 31738392 28899984 1200184 97% /usr
/dev/sda8 124991068 10768772 107770596 10% /var/tmp
/dev/mapper/VolGroup00-home
198351840 14857552 173255928 8% /home
/dev/sde1 565688764 375339224 161150604 70% /scr
/dev/sdc1 961432072 766033248 146560824 84% /mnt/scr1
/dev/sdd1 961432072 818298140 94295932 90% /mnt/hdf
tmpfs 8313848 0 8313848 0% /dev/shm
gumund:/data/ftp 480719072 277656864 178643008 61% /mnt/ftp
gumund:/data/web 480719072 277656864 178643008 61% /mnt/web
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/ro-src
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0227Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0227Sun.22164: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0227Sun.22164': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
duty
liberty
Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
12:10am up 33 day(s), 11:33, 4 users, load average: 2.73, 2.99, 2.56
/ (/dev/dsk/c1t0d0s0 ):65482946 blocks 8252417 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483605 files
/proc (proc ): 0 blocks 29914 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):20493280 blocks 1180993 files
/system/object (objfs ): 0 blocks 2147483498 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):65482946 blocks 8252417 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):65482946 blocks 8252417 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):20493280 blocks 1180993 files
/var/run (swap ):20493280 blocks 1180993 files
/home (jam:/home ):366988576 blocks 50926236 files
/mnt/hdf (jam:/mnt/hdf ):286267864 blocks 114390302 files
/mnt/scr1 (jam:/mnt/scr1 ):390796024 blocks 116744689 files
/mnt/web (gumund:/mnt/web ):406124408 blocks 60891084 files
/mnt/ftp (gumund:/mnt/ftp ):406124408 blocks 60891084 files
TEST_TYPES=standard
Sun Feb 27 00:10:48 CST 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0227Sun_0010
*** finished standard tests for linew ***
Sun Feb 27 00:18:42 CST 2011
Total time = 7m 56s
*** finished tests in linew ***
Sun Feb 27 00:18:43 CST 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:10:37 up 23 days, 15:42, 55 users, load average: 2.47, 2.19, 2.12
/dev/sda2 31738420 1886444 28213748 7% /tmp
/dev/sda6 31738392 6011912 24088256 20% /var
/dev/sdc1 961432072 766034088 146559984 84% /mnt/scr1
TEST_TYPES=standard
Sun Feb 27 00:10:47 CST 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0227Sun_0010
*** finished standard tests for jam ***
Sun Feb 27 00:12:08 CST 2011
Total time = 1m 21s
*** finished tests in jam ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM up 59 days, 9:25, 0 users, load averages: 0.02, 0.01, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60986 406034 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 123604522 49753854 71% /data
/dev/aacd0s1g 32494668 25718200 4176896 86% /local_home
/dev/aacd0s1f 12186190 4125638 7085658 37% /usr
/dev/aacd0s1d 507630 50520 416500 11% /var
/dev/aacd0s1e 253678 178 233206 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 14857552 173255928 8% /home
jam:/mnt/hdf 961432072 818298140 94295932 90% /mnt/hdf
jam:/mnt/scr1 961432072 766034192 146559880 84% /mnt/scr1
gumund:/data/web 480719056 277656852 178643004 61% /mnt/web
gumund:/data/ftp 480719056 277656852 178643004 61% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 102 116464 0% /tmp
TEST_TYPES=standard
Sun Feb 27 00:10:49 CST 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
*** finished standard tests for duty ***
Total time = 0m 30s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname liberty
12:10AM up 72 days, 13:18, 4 users, load averages: 0.00, 0.00, 0.00
/dev/aacd0s1a 507630 86918 380102 19% /
/dev/aacd0s1g 47047830 32621182 10662822 75% /local_home
/dev/aacd0s1f 12186190 7420280 3791016 66% /usr
/dev/aacd0s1d 1012974 104088 827850 11% /var
/dev/aacd0s1e 507630 62724 404296 13% /var/tmp
jam:/mnt/scr1 961432072 766034324 146559748 84% /mnt/scr1
/dev/md0 126702 26 116540 0% /tmp
TEST_TYPES=standard
Sun Feb 27 00:10:51 CST 2011
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008 sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY amd64
*** finished standard tests for liberty ***
Total time = 0m 11s
*** finished tests in liberty ***
****SYSTEM ERROR liberty: Abnormal exit from runtest ****
****SYSTEM ERROR liberty: runtest command failed ****
More information about the opa-nightly-tests
