[opa-nightly-tests] jam OPA_Daily_Tests_0226Sat_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Sat Feb 26 00:19:53 CST 2011
*** OPA Tests on 0226Sat ***
   Tests Summary
****FAILED duty: standard****
****FAILED liberty: standard****
PASSED jam: standard
PASSED linew: standard
   Tests Time Summary
liberty: Ran 1(0/1/0) tests, Grand total test time =  0m 12s
duty: Ran 1(0/1/0) tests, Grand total test time =  0m 28s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 22s
linew: Ran 1(1/0/0) tests, Grand total test time =  8m 36s
jam: Ran 4(0/0/0) hosts, Grand total test time =  9m 34s
   Timekeeper log
Timekeeper started at Sat Feb 26 00:10:30 CST 2011
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of liberty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0226Sat_0010
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
                 from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Sat Feb 26 00:11:03 CST 2011 =====
Dumping done
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0226Sat_0010
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
Failed running make
===== Exit bin/snapshot with status=0: Sat Feb 26 00:11:16 CST 2011 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:10:09 up 22 days, 15:42, 57 users,  load average: 2.09, 2.04, 2.20
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   4134432  25965760  14% /
/dev/sda1               101086     22885     72982  24% /boot
/dev/sda2             31738420   1886324  28213868   7% /tmp
/dev/sda6             31738392   6021944  24078224  21% /var
/dev/sda7             31738392  28897944   1202224  97% /usr
/dev/sda8            124991068  10768772 107770596  10% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  14856992 173256488   8% /home
/dev/sde1            565688764 375319944 161169884  70% /scr
/dev/sdc1            961432072 764399220 148194852  84% /mnt/scr1
/dev/sdd1            961432072 818246004  94348068  90% /mnt/hdf
tmpfs                  8313848         0   8313848   0% /dev/shm
gumund:/data/ftp     480719072 277656832 178643040  61% /mnt/ftp
gumund:/data/web     480719072 277656832 178643040  61% /mnt/web
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/ro-src
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0226Sat
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0226Sat.1068: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0226Sat.1068': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
duty
liberty
    Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
 12:10am  up 32 day(s), 11:33,  4 users,  load average: 2.49, 2.54, 2.75
/                  (/dev/dsk/c1t0d0s0 ):62640118 blocks  8253447 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483606 files
/proc              (proc              ):       0 blocks    29914 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ):20205376 blocks  1180991 files
/system/object     (objfs             ):       0 blocks 2147483498 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):62640118 blocks  8253447 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):62640118 blocks  8253447 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ):20205376 blocks  1180991 files
/var/run           (swap              ):20205376 blocks  1180991 files
/home              (jam:/home         ):366989696 blocks 50926240 files
/mnt/hdf           (jam:/mnt/hdf      ):286372136 blocks 114389662 files
/mnt/scr1          (jam:/mnt/scr1     ):394062096 blocks 116753407 files
/mnt/web           (gumund:/mnt/web   ):406124424 blocks 60891084 files
/mnt/ftp           (gumund:/mnt/ftp   ):406124424 blocks 60891084 files
TEST_TYPES=standard
Sat Feb 26 00:10:58 CST 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/linew_0226Sat_0010
*** finished standard tests for linew ***
Sat Feb 26 00:19:21 CST 2011
Total time = 8m 24s
*** finished tests in linew ***
Sat Feb 26 00:19:22 CST 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 00:10:37 up 22 days, 15:42, 57 users,  load average: 2.10, 2.05, 2.19
/dev/sda2             31738420   1886448  28213744   7% /tmp
/dev/sda6             31738392   6021948  24078220  21% /var
/dev/sdc1            961432072 764401036 148193036  84% /mnt/scr1
TEST_TYPES=standard
Sat Feb 26 00:10:47 CST 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0226Sat_0010
*** finished standard tests for jam ***
Sat Feb 26 00:12:08 CST 2011
Total time = 1m 21s
*** finished tests in jam ***
Sat Feb 26 00:12:09 CST 2011
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM  up 58 days,  9:25, 0 users, load averages: 0.04, 0.04, 0.00
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/aacd0s1a       507630     60986    406034    13%    /
devfs                    1         1         0   100%    /dev
/dev/aacd0s1h    188433016 123604522  49753854    71%    /data
/dev/aacd0s1g     32494668  25718200   4176896    86%    /local_home
/dev/aacd0s1f     12186190   4125638   7085658    37%    /usr
/dev/aacd0s1d       507630     50592    416428    11%    /var
/dev/aacd0s1e       253678       178    233206     0%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840  14856992 173256488     8%    /home
jam:/mnt/hdf     961432072 818246004  94348068    90%    /mnt/hdf
jam:/mnt/scr1    961432072 764401100 148192972    84%    /mnt/scr1
gumund:/data/web 480719056 277656844 178643012    61%    /mnt/web
gumund:/data/ftp 480719056 277656844 178643012    61%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702       102    116464     0%    /tmp
TEST_TYPES=standard
Sat Feb 26 00:10:49 CST 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
	Sat Feb 26 00:11:17 CST 2011
*** finished standard tests for duty ***
Total time = 0m 28s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
	****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname liberty
12:10AM  up 71 days, 13:18, 3 users, load averages: 0.00, 0.00, 0.00
/dev/aacd0s1a       507630     86918    380102    19%    /
/dev/aacd0s1g     47047830  32660114  10623890    75%    /local_home
/dev/aacd0s1f     12186190   7420280   3791016    66%    /usr
/dev/aacd0s1d      1012974    104116    827822    11%    /var
/dev/aacd0s1e       507630     62724    404296    13%    /var/tmp
jam:/mnt/scr1    961432072 764401172 148192900    84%    /mnt/scr1
/dev/md0            126702        24    116542     0%    /tmp
TEST_TYPES=standard
Sat Feb 26 00:10:52 CST 2011
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008     sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY  amd64
*** finished standard tests for liberty ***
Total time = 0m 11s
*** finished tests in liberty ***
****SYSTEM ERROR liberty: Abnormal exit from runtest ****
	****SYSTEM ERROR liberty: runtest command failed ****
More information about the opa-nightly-tests mailing list
