[opa-nightly-tests] jam OPA_Daily_Tests_0221Mon_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Mon Feb 21 00:19:49 CST 2011
*** OPA Tests on 0221Mon ***
Tests Summary
****FAILED duty: standard****
****FAILED liberty: standard****
PASSED jam: standard
PASSED linew: standard
Tests Time Summary
liberty: Ran 1(0/1/0) tests, Grand total test time = 0m 11s
duty: Ran 1(0/1/0) tests, Grand total test time = 0m 29s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 21s
linew: Ran 1(1/0/0) tests, Grand total test time = 8m 32s
jam: Ran 4(0/0/0) hosts, Grand total test time = 9m 30s
Timekeeper log
Timekeeper started at Mon Feb 21 00:10:30 CST 2011
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of liberty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0221Mon_0010
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Mon Feb 21 00:11:03 CST 2011 =====
Dumping done
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0221Mon_0010
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
Failed running make
===== Exit bin/snapshot with status=0: Mon Feb 21 00:11:19 CST 2011 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:10:09 up 17 days, 15:42, 58 users, load average: 2.30, 3.66, 5.13
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3991184 26109008 14% /
/dev/sda1 101086 22885 72982 24% /boot
/dev/sda2 31738420 665344 29434848 3% /tmp
/dev/sda6 31738392 5944116 24156052 20% /var
/dev/sda7 31738392 28887916 1212252 96% /usr
/dev/sda8 124991068 4482980 114056388 4% /var/tmp
/dev/mapper/VolGroup00-home
198351840 15200476 172913004 9% /home
/dev/sde1 565688764 375074644 161415184 70% /scr
/dev/sdc1 961432072 755365864 157228208 83% /mnt/scr1
/dev/sdd1 961432072 809563172 103030900 89% /mnt/hdf
tmpfs 8313848 0 8313848 0% /dev/shm
gumund:/data/ftp 480719072 274211296 182088576 61% /mnt/ftp
gumund:/data/web 480719072 274211296 182088576 61% /mnt/web
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/ro-src
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0221Mon
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0221Mon.16121: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0221Mon.16121': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
duty
liberty
Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
12:10am up 27 day(s), 11:33, 2 users, load average: 2.13, 2.12, 1.63
/ (/dev/dsk/c1t0d0s0 ):61405570 blocks 8255599 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483607 files
/proc (proc ): 0 blocks 29918 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):20600800 blocks 1182251 files
/system/object (objfs ): 0 blocks 2147483498 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):61405570 blocks 8255599 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):61405570 blocks 8255599 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):20600800 blocks 1182251 files
/var/run (swap ):20600800 blocks 1182251 files
/home (jam:/home ):366302728 blocks 50916484 files
/mnt/hdf (jam:/mnt/hdf ):303736544 blocks 114781545 files
/mnt/scr1 (jam:/mnt/scr1 ):412098504 blocks 116796167 files
/mnt/web (gumund:/mnt/web ):413015496 blocks 60891145 files
/mnt/ftp (gumund:/mnt/ftp ):413015496 blocks 60891145 files
TEST_TYPES=standard
Mon Feb 21 00:10:57 CST 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0221Mon_0010
*** finished standard tests for linew ***
Mon Feb 21 00:19:16 CST 2011
Total time = 8m 20s
*** finished tests in linew ***
Mon Feb 21 00:19:17 CST 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:10:37 up 17 days, 15:42, 58 users, load average: 2.34, 3.56, 5.06
/dev/sda2 31738420 665464 29434728 3% /tmp
/dev/sda6 31738392 5944124 24156044 20% /var
/dev/sdc1 961432072 755382868 157211204 83% /mnt/scr1
/dev/sdd1 961432072 809563800 103030272 89% /mnt/hdf
TEST_TYPES=standard
Mon Feb 21 00:10:48 CST 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0221Mon_0010
*** finished standard tests for jam ***
Mon Feb 21 00:12:08 CST 2011
Total time = 1m 20s
*** finished tests in jam ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM up 53 days, 9:25, 0 users, load averages: 0.21, 0.10, 0.04
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60986 406034 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 123604522 49753854 71% /data
/dev/aacd0s1g 32494668 25424302 4470794 85% /local_home
/dev/aacd0s1f 12186190 4125638 7085658 37% /usr
/dev/aacd0s1d 507630 50562 416458 11% /var
/dev/aacd0s1e 253678 198 233186 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 15200476 172913004 8% /home
jam:/mnt/hdf 961432072 809563800 103030272 89% /mnt/hdf
jam:/mnt/scr1 961432072 755382988 157211084 83% /mnt/scr1
gumund:/data/web 480719056 274211308 182088548 60% /mnt/web
gumund:/data/ftp 480719056 274211308 182088548 60% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 100 116466 0% /tmp
TEST_TYPES=standard
Mon Feb 21 00:10:50 CST 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
*** finished standard tests for duty ***
Total time = 0m 29s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname liberty
12:10AM up 66 days, 13:18, 3 users, load averages: 0.00, 0.27, 0.43
/dev/aacd0s1a 507630 86918 380102 19% /
/dev/aacd0s1g 47047830 31162842 12121162 72% /local_home
/dev/aacd0s1f 12186190 7420280 3791016 66% /usr
/dev/aacd0s1d 1012974 104122 827816 11% /var
/dev/aacd0s1e 507630 62724 404296 13% /var/tmp
jam:/mnt/scr1 961432072 755383120 157210952 83% /mnt/scr1
/dev/md0 126702 24 116542 0% /tmp
TEST_TYPES=standard
Mon Feb 21 00:10:52 CST 2011
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008 sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY amd64
*** finished standard tests for liberty ***
Total time = 0m 11s
*** finished tests in liberty ***
****SYSTEM ERROR liberty: Abnormal exit from runtest ****
****SYSTEM ERROR liberty: runtest command failed ****
More information about the opa-nightly-tests
