[opa-nightly-tests] jam OPA_Daily_Tests_0218Fri_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Fri Feb 18 00:19:21 CST 2011
*** OPA Tests on 0218Fri ***
   Tests Summary
****FAILED duty: standard****
****FAILED liberty: standard****
PASSED jam: standard
PASSED linew: standard
   Tests Time Summary
liberty: Ran 1(0/1/0) tests, Grand total test time =  0m 11s
duty: Ran 1(0/1/0) tests, Grand total test time =  0m 29s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 22s
linew: Ran 1(1/0/0) tests, Grand total test time =  8m 3s
jam: Ran 4(0/0/0) hosts, Grand total test time =  9m 1s
   Timekeeper log
Timekeeper started at Fri Feb 18 00:10:31 CST 2011
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of liberty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0218Fri_0010
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
                 from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Fri Feb 18 00:11:03 CST 2011 =====
Dumping done
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0218Fri_0010
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only oncemv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
Failed running make
===== Exit bin/snapshot with status=0: Fri Feb 18 00:11:19 CST 2011 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:10:10 up 14 days, 15:42, 49 users,  load average: 1.18, 1.12, 1.11
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   3990864  26109328  14% /
/dev/sda1               101086     22885     72982  24% /boot
/dev/sda2             31738420    494888  29605304   2% /tmp
/dev/sda6             31738392   5947604  24152564  20% /var
/dev/sda7             31738392  28879764   1220404  96% /usr
/dev/sda8            124991068   4482972 114056396   4% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  15044120 173069360   8% /home
/dev/sde1            565688764 375094820 161395008  70% /scr
/dev/sdc1            961432072 725228900 187365172  80% /mnt/scr1
/dev/sdd1            961432072 807576972 105017100  89% /mnt/hdf
tmpfs                  8313848         0   8313848   0% /dev/shm
gumund:/data/ftp     480719072 274173792 182126080  61% /mnt/ftp
gumund:/data/web     480719072 274173792 182126080  61% /mnt/web
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/ro-src
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0218Fri
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0218Fri.16925: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0218Fri.16925': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
duty
liberty
    Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
 12:10am  up 24 day(s), 11:33,  2 users,  load average: 1.11, 0.99, 0.55
/                  (/dev/dsk/c1t0d0s0 ):62840768 blocks  8253173 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483608 files
/proc              (proc              ):       0 blocks    29933 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ):20463632 blocks  1182258 files
/system/object     (objfs             ):       0 blocks 2147483499 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):62840768 blocks  8253173 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):62840768 blocks  8253173 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ):20463632 blocks  1182258 files
/var/run           (swap              ):20463632 blocks  1182258 files
/home              (jam:/home         ):366615440 blocks 50918220 files
/mnt/hdf           (jam:/mnt/hdf      ):307710200 blocks 114797664 files
/mnt/scr1          (jam:/mnt/scr1     ):472404944 blocks 117086894 files
/mnt/web           (gumund:/mnt/web   ):413090528 blocks 60891146 files
/mnt/ftp           (gumund:/mnt/ftp   ):413090528 blocks 60891146 files
TEST_TYPES=standard
Fri Feb 18 00:10:58 CST 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/linew_0218Fri_0010
*** finished standard tests for linew ***
Fri Feb 18 00:18:49 CST 2011
Total time = 7m 52s
*** finished tests in linew ***
Fri Feb 18 00:18:50 CST 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 00:10:38 up 14 days, 15:42, 49 users,  load average: 1.26, 1.14, 1.11
/dev/sda2             31738420    495012  29605180   2% /tmp
/dev/sda6             31738392   5947608  24152560  20% /var
/dev/sdc1            961432072 725229608 187364464  80% /mnt/scr1
TEST_TYPES=standard
Fri Feb 18 00:10:48 CST 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0218Fri_0010
*** finished standard tests for jam ***
Fri Feb 18 00:12:10 CST 2011
Total time = 1m 22s
*** finished tests in jam ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM  up 50 days,  9:25, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/aacd0s1a       507630     60986    406034    13%    /
devfs                    1         1         0   100%    /dev
/dev/aacd0s1h    188433016 123604522  49753854    71%    /data
/dev/aacd0s1g     32494668  25423420   4471676    85%    /local_home
/dev/aacd0s1f     12186190   4125638   7085658    37%    /usr
/dev/aacd0s1d       507630     50592    416428    11%    /var
/dev/aacd0s1e       253678       178    233206     0%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840  15044120 173069360     8%    /home
jam:/mnt/hdf     961432072 807576972 105017100    88%    /mnt/hdf
jam:/mnt/scr1    961432072 725229732 187364340    79%    /mnt/scr1
gumund:/data/web 480719056 274173792 182126064    60%    /mnt/web
gumund:/data/ftp 480719056 274173792 182126064    60%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702        98    116468     0%    /tmp
TEST_TYPES=standard
Fri Feb 18 00:10:50 CST 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
*** finished standard tests for duty ***
Total time = 0m 29s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
	Fri Feb 18 00:19:20 CST 2011
	****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname liberty
12:10AM  up 63 days, 13:18, 3 users, load averages: 0.00, 0.00, 0.00
/dev/aacd0s1a       507630     86918    380102    19%    /
/dev/aacd0s1g     47047830  31380054  11903950    72%    /local_home
/dev/aacd0s1f     12186190   7420280   3791016    66%    /usr
/dev/aacd0s1d      1012974    104154    827784    11%    /var
/dev/aacd0s1e       507630     62724    404296    13%    /var/tmp
jam:/mnt/scr1    961432072 725229764 187364308    79%    /mnt/scr1
/dev/md0            126702        24    116542     0%    /tmp
TEST_TYPES=standard
Fri Feb 18 00:10:53 CST 2011
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008     sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY  amd64
*** finished standard tests for liberty ***
Total time = 0m 10s
*** finished tests in liberty ***
****SYSTEM ERROR liberty: Abnormal exit from runtest ****
	****SYSTEM ERROR liberty: runtest command failed ****
More information about the opa-nightly-tests mailing list
