[opa-nightly-tests] jam OPA_Daily_Tests_0217Thu_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Thu Feb 17 00:19:12 CST 2011
*** OPA Tests on 0217Thu ***
Tests Summary
****FAILED duty: standard****
****FAILED liberty: standard****
PASSED jam: standard
PASSED linew: standard
Tests Time Summary
liberty: Ran 1(0/1/0) tests, Grand total test time = 0m 11s
duty: Ran 1(0/1/0) tests, Grand total test time = 0m 31s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 18s
linew: Ran 1(1/0/0) tests, Grand total test time = 7m 54s
jam: Ran 4(0/0/0) hosts, Grand total test time = 8m 52s
Timekeeper log
Timekeeper started at Thu Feb 17 00:10:31 CST 2011
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of liberty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0217Thu_0010
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Thu Feb 17 00:11:04 CST 2011 =====
Dumping done
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0217Thu_0010
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
Failed running make
===== Exit bin/snapshot with status=0: Thu Feb 17 00:11:21 CST 2011 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:10:10 up 13 days, 15:42, 48 users, load average: 2.15, 2.04, 2.36
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3987352 26112840 14% /
/dev/sda1 101086 22885 72982 24% /boot
/dev/sda2 31738420 248876 29851316 1% /tmp
/dev/sda6 31738392 5913296 24186872 20% /var
/dev/sda7 31738392 28876540 1223628 96% /usr
/dev/sda8 124991068 326752 118212616 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 15030228 173083252 8% /home
/dev/sde1 565688764 373776764 162713064 70% /scr
/dev/sdc1 961432072 724087368 188506704 80% /mnt/scr1
/dev/sdd1 961432072 806190468 106403604 89% /mnt/hdf
tmpfs 8313848 0 8313848 0% /dev/shm
gumund:/data/ftp 480719072 273838080 182461792 61% /mnt/ftp
gumund:/data/web 480719072 273838080 182461792 61% /mnt/web
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/ro-src
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0217Thu
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0217Thu.30800: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0217Thu.30800': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
duty
liberty
Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
12:10am up 23 day(s), 11:33, 0 users, load average: 1.12, 1.00, 0.77
/ (/dev/dsk/c1t0d0s0 ):66399978 blocks 8253805 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483610 files
/proc (proc ): 0 blocks 29939 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):20486752 blocks 1182270 files
/system/object (objfs ): 0 blocks 2147483499 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):66399978 blocks 8253805 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):66399978 blocks 8253805 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):20486752 blocks 1182270 files
/var/run (swap ):20486752 blocks 1182270 files
/home (jam:/home ):366643224 blocks 50918009 files
/mnt/hdf (jam:/mnt/hdf ):310483208 blocks 114819353 files
/mnt/scr1 (jam:/mnt/scr1 ):474687960 blocks 117079813 files
/mnt/web (gumund:/mnt/web ):413761936 blocks 60891496 files
/mnt/ftp (gumund:/mnt/ftp ):413761936 blocks 60891496 files
TEST_TYPES=standard
Thu Feb 17 00:10:58 CST 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0217Thu_0011
*** finished standard tests for linew ***
Thu Feb 17 00:18:39 CST 2011
Total time = 7m 41s
*** finished tests in linew ***
Thu Feb 17 00:18:40 CST 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:10:38 up 13 days, 15:42, 48 users, load average: 2.22, 2.07, 2.36
/dev/sda2 31738420 249000 29851192 1% /tmp
/dev/sda6 31738392 5913300 24186868 20% /var
/dev/sdc1 961432072 724088116 188505956 80% /mnt/scr1
TEST_TYPES=standard
Thu Feb 17 00:10:48 CST 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0217Thu_0010
*** finished standard tests for jam ***
Thu Feb 17 00:12:06 CST 2011
Total time = 1m 18s
*** finished tests in jam ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM up 49 days, 9:25, 0 users, load averages: 0.01, 0.07, 0.08
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60986 406034 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 123604522 49753854 71% /data
/dev/aacd0s1g 32494668 24977374 4917722 84% /local_home
/dev/aacd0s1f 12186190 4125638 7085658 37% /usr
/dev/aacd0s1d 507630 50548 416472 11% /var
/dev/aacd0s1e 253678 178 233206 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 15030228 173083252 8% /home
jam:/mnt/hdf 961432072 806190468 106403604 88% /mnt/hdf
jam:/mnt/scr1 961432072 724088192 188505880 79% /mnt/scr1
gumund:/data/web 480719056 273838088 182461768 60% /mnt/web
gumund:/data/ftp 480719056 273838088 182461768 60% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 78 116488 0% /tmp
TEST_TYPES=standard
Thu Feb 17 00:10:51 CST 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
*** finished standard tests for duty ***
Total time = 0m 30s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
Thu Feb 17 00:19:11 CST 2011
****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname liberty
12:10AM up 62 days, 13:18, 1 user, load averages: 0.00, 0.00, 0.00
/dev/aacd0s1a 507630 86918 380102 19% /
/dev/aacd0s1g 47047830 30620242 12663762 71% /local_home
/dev/aacd0s1f 12186190 7420280 3791016 66% /usr
/dev/aacd0s1d 1012974 104198 827740 11% /var
/dev/aacd0s1e 507630 62724 404296 13% /var/tmp
jam:/mnt/scr1 961432072 724088300 188505772 79% /mnt/scr1
/dev/md0 126702 18 116548 0% /tmp
TEST_TYPES=standard
Thu Feb 17 00:10:53 CST 2011
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008 sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY amd64
*** finished standard tests for liberty ***
Total time = 0m 11s
*** finished tests in liberty ***
****SYSTEM ERROR liberty: Abnormal exit from runtest ****
****SYSTEM ERROR liberty: runtest command failed ****
More information about the opa-nightly-tests
