[opa-nightly-tests] jam OPA_Daily_Tests_0215Tue_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Tue Feb 15 00:19:22 CST 2011
*** OPA Tests on 0215Tue ***
   Tests Summary
****FAILED duty: standard****
****FAILED liberty: standard****
PASSED jam: standard
PASSED linew: standard
   Tests Time Summary
liberty: Ran 1(0/1/0) tests, Grand total test time =  0m 11s
duty: Ran 1(0/1/0) tests, Grand total test time =  0m 29s
jam: Ran 1(1/0/0) tests, Grand total test time =  1m 21s
linew: Ran 1(1/0/0) tests, Grand total test time =  8m 4s
jam: Ran 4(0/0/0) hosts, Grand total test time =  9m 2s
   Timekeeper log
Timekeeper started at Tue Feb 15 00:10:31 CST 2011
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of liberty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0215Tue_0010
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
                 from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Tue Feb 15 00:11:04 CST 2011 =====
Dumping done
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0215Tue_0010
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
Failed running make
===== Exit bin/snapshot with status=0: Tue Feb 15 00:11:19 CST 2011 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:10:10 up 11 days, 15:42, 62 users,  load average: 1.05, 1.11, 1.32
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   3984020  26116172  14% /
/dev/sda1               101086     22885     72982  24% /boot
/dev/sda2             31738420    249224  29850968   1% /tmp
/dev/sda6             31738392   5890204  24209964  20% /var
/dev/sda7             31738392  28766132   1334036  96% /usr
/dev/sda8            124991068    326744 118212624   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  15003892 173109588   8% /home
/dev/sde1            565688764 374865200 161624628  70% /scr
/dev/sdc1            961432072 727170724 185423348  80% /mnt/scr1
/dev/sdd1            961432072 804822204 107771868  89% /mnt/hdf
tmpfs                  8313848         0   8313848   0% /dev/shm
gumund:/data/ftp     480719072 273829984 182469888  61% /mnt/ftp
gumund:/data/web     480719072 273829984 182469888  61% /mnt/web
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/ro-src
amani:/mnt/rw-src    288451232 179573408  94225344  66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0215Tue
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0215Tue.11704: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0215Tue.11704': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
duty
liberty
    Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
 12:10am  up 21 day(s), 11:33,  0 users,  load average: 1.11, 0.98, 0.54
/                  (/dev/dsk/c1t0d0s0 ):63051914 blocks  8253323 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483610 files
/proc              (proc              ):       0 blocks    29939 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ):20492368 blocks  1182271 files
/system/object     (objfs             ):       0 blocks 2147483499 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):63051914 blocks  8253323 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):63051914 blocks  8253323 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ):20492368 blocks  1182271 files
/var/run           (swap              ):20492368 blocks  1182271 files
/home              (jam:/home         ):366695896 blocks 50918166 files
/mnt/hdf           (jam:/mnt/hdf      ):313219736 blocks 114822757 files
/mnt/scr1          (jam:/mnt/scr1     ):468521264 blocks 117091297 files
/mnt/web           (gumund:/mnt/web   ):413778168 blocks 60891508 files
/mnt/ftp           (gumund:/mnt/ftp   ):413778168 blocks 60891508 files
TEST_TYPES=standard
Tue Feb 15 00:10:59 CST 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/linew_0215Tue_0011
*** finished standard tests for linew ***
Tue Feb 15 00:18:50 CST 2011
Total time = 7m 52s
*** finished tests in linew ***
Tue Feb 15 00:18:51 CST 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 00:10:38 up 11 days, 15:42, 62 users,  load average: 1.17, 1.13, 1.32
/dev/sda2             31738420    249348  29850844   1% /tmp
/dev/sda6             31738392   5890208  24209960  20% /var
/dev/sdc1            961432072 727171464 185422608  80% /mnt/scr1
TEST_TYPES=standard
Tue Feb 15 00:10:48 CST 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0215Tue_0010
*** finished standard tests for jam ***
Tue Feb 15 00:12:09 CST 2011
Total time = 1m 21s
*** finished tests in jam ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM  up 47 days,  9:25, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/aacd0s1a       507630     60990    406030    13%    /
devfs                    1         1         0   100%    /dev
/dev/aacd0s1h    188433016 123604522  49753854    71%    /data
/dev/aacd0s1g     32494668  25345218   4549878    85%    /local_home
/dev/aacd0s1f     12186190   4125638   7085658    37%    /usr
/dev/aacd0s1d       507630     50540    416480    11%    /var
/dev/aacd0s1e       253678       178    233206     0%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840  15003892 173109588     8%    /home
jam:/mnt/hdf     961432072 804822204 107771868    88%    /mnt/hdf
jam:/mnt/scr1    961432072 727171548 185422524    80%    /mnt/scr1
gumund:/data/web 480719056 273829972 182469884    60%    /mnt/web
gumund:/data/ftp 480719056 273829972 182469884    60%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702        76    116490     0%    /tmp
TEST_TYPES=standard
Tue Feb 15 00:10:51 CST 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
*** finished standard tests for duty ***
Total time = 0m 28s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
	****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname liberty
12:10AM  up 60 days, 13:18, 1 user, load averages: 0.00, 0.00, 0.00
/dev/aacd0s1a       507630     86918    380102    19%    /
/dev/aacd0s1g     47047830  31275972  12008032    72%    /local_home
/dev/aacd0s1f     12186190   7420280   3791016    66%    /usr
/dev/aacd0s1d      1012974    104204    827734    11%    /var
/dev/aacd0s1e       507630     62724    404296    13%    /var/tmp
jam:/mnt/scr1    961432072 727171584 185422488    80%    /mnt/scr1
/dev/md0            126702        18    116548     0%    /tmp
TEST_TYPES=standard
Tue Feb 15 00:10:53 CST 2011
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008     sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY  amd64
*** finished standard tests for liberty ***
Total time = 0m 11s
*** finished tests in liberty ***
****SYSTEM ERROR liberty: Abnormal exit from runtest ****
	****SYSTEM ERROR liberty: runtest command failed ****
More information about the opa-nightly-tests mailing list
