[opa-nightly-tests] jam OPA_Daily_Tests_0213Sun_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Sun Feb 13 00:19:37 CST 2011
*** OPA Tests on 0213Sun ***
Tests Summary
****FAILED duty: standard****
****FAILED liberty: standard****
PASSED jam: standard
PASSED linew: standard
Tests Time Summary
liberty: Ran 1(0/1/0) tests, Grand total test time = 0m 14s
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 21s
duty: Ran 1(0/1/0) tests, Grand total test time = 3m 20s
linew: Ran 1(1/0/0) tests, Grand total test time = 8m 12s
jam: Ran 4(0/0/0) hosts, Grand total test time = 9m 14s
Timekeeper log
Timekeeper started at Sun Feb 13 00:10:38 CST 2011
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of liberty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0213Sun_0011
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementationmv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=0: Sun Feb 13 00:11:14 CST 2011 =====
Dumping done
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0213Sun_0010
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
primitives implementation specified
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
Failed running make
===== Exit bin/snapshot with status=0: Sun Feb 13 00:14:18 CST 2011 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:10:13 up 9 days, 15:42, 51 users, load average: 6.04, 7.50, 8.43
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3983260 26116932 14% /
/dev/sda1 101086 22885 72982 24% /boot
/dev/sda2 31738420 250776 29849416 1% /tmp
/dev/sda6 31738392 5916256 24183912 20% /var
/dev/sda7 31738392 28761948 1338220 96% /usr
/dev/sda8 124991068 326756 118212612 1% /var/tmp
/dev/mapper/VolGroup00-home
198351840 14995620 173117860 8% /home
/dev/sde1 565688764 375191884 161297944 70% /scr
/dev/sdc1 961432072 724379448 188214624 80% /mnt/scr1
/dev/sdd1 961432072 804284944 108309128 89% /mnt/hdf
tmpfs 8313848 0 8313848 0% /dev/shm
gumund:/data/ftp 480719072 273487872 182812000 60% /mnt/ftp
gumund:/data/web 480719072 273487872 182812000 60% /mnt/web
pegdub:/mnt/rw-src 288451232 179417888 94380864 66% /mnt/ro-src
pegdub:/mnt/rw-src 288451232 179417888 94380864 66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0213Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0213Sun.9952: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0213Sun.9952': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
duty
liberty
Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
12:10am up 19 day(s), 11:33, 0 users, load average: 3.04, 2.82, 2.21
/ (/dev/dsk/c1t0d0s0 ):63112766 blocks 8254818 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483608 files
/proc (proc ): 0 blocks 29926 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):20783776 blocks 1182274 files
/system/object (objfs ): 0 blocks 2147483500 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):63112766 blocks 8254818 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):63112766 blocks 8254818 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):20783776 blocks 1182274 files
/var/run (swap ):20783776 blocks 1182274 files
/home (jam:/home ):366712440 blocks 50918256 files
/mnt/hdf (jam:/mnt/hdf ):314294256 blocks 114835675 files
/mnt/scr1 (jam:/mnt/scr1 ):474098632 blocks 117128148 files
/mnt/web (gumund:/mnt/web ):414462352 blocks 60891509 files
/mnt/ftp (gumund:/mnt/ftp ):414462352 blocks 60891509 files
TEST_TYPES=standard
Sun Feb 13 00:11:07 CST 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0213Sun_0011
*** finished standard tests for linew ***
Sun Feb 13 00:19:04 CST 2011
Total time = 7m 58s
*** finished tests in linew ***
Sun Feb 13 00:19:05 CST 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:10:45 up 9 days, 15:42, 51 users, load average: 6.49, 7.45, 8.38
/dev/sda2 31738420 250896 29849296 1% /tmp
/dev/sda6 31738392 5916260 24183908 20% /var
/dev/sdc1 961432072 724382764 188211308 80% /mnt/scr1
TEST_TYPES=standard
Sun Feb 13 00:10:55 CST 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0213Sun_0010
*** finished standard tests for jam ***
Sun Feb 13 00:12:16 CST 2011
Total time = 1m 21s
*** finished tests in jam ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM up 45 days, 9:25, 0 users, load averages: 0.02, 0.01, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60990 406030 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 123604522 49753854 71% /data
/dev/aacd0s1g 32494668 25345266 4549830 85% /local_home
/dev/aacd0s1f 12186190 4125638 7085658 37% /usr
/dev/aacd0s1d 507630 50504 416516 11% /var
/dev/aacd0s1e 253678 178 233206 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 14995620 173117860 8% /home
jam:/mnt/hdf 961432072 804284944 108309128 88% /mnt/hdf
jam:/mnt/scr1 961432072 724382808 188211264 79% /mnt/scr1
gumund:/data/web 480719056 273487880 182811976 60% /mnt/web
gumund:/data/ftp 480719056 273487880 182811976 60% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 78 116488 0% /tmp
TEST_TYPES=standard
Sun Feb 13 00:10:58 CST 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
*** finished standard tests for duty ***
Total time = 3m 20s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname liberty
12:10AM up 58 days, 13:18, 1 user, load averages: 0.40, 0.27, 0.26
/dev/aacd0s1a 507630 86918 380102 19% /
/dev/aacd0s1g 47047830 31057730 12226274 72% /local_home
/dev/aacd0s1f 12186190 7420280 3791016 66% /usr
/dev/aacd0s1d 1012974 104298 827640 11% /var
/dev/aacd0s1e 507630 62724 404296 13% /var/tmp
jam:/mnt/scr1 961432072 724382816 188211256 79% /mnt/scr1
/dev/md0 126702 20 116546 0% /tmp
TEST_TYPES=standard
Sun Feb 13 00:11:00 CST 2011
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008 sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY amd64
*** finished standard tests for liberty ***
Total time = 0m 14s
*** finished tests in liberty ***
****SYSTEM ERROR liberty: Abnormal exit from runtest ****
****SYSTEM ERROR liberty: runtest command failed ****
More information about the opa-nightly-tests
