[opa-nightly-tests] jam OPA_Daily_Tests_0211Fri_FAILED!!!
Dave Goodell
goodell at mcs.anl.gov
Fri Feb 11 10:19:32 CST 2011
Alright, thanks for checking. Apparently my testing was insufficient. I'll try a few more shell combinations and see if I can make them all happy.
-Dave
On Feb 11, 2011, at 10:15 AM CST, Neil Fortner wrote:
> Dave,
> I just tried running this manually (with autoreconf -vif), and got the same errors. I also noticed this line at the end of the output from configure:
> sed: file conftest.prefix line 3: unterminated `s' command
> -Neil
> On 02/11/2011 10:03 AM, Dave Goodell wrote:
>> I updated configure.in in r113, which probably caused this directly or indirectly. Does the nightly test script still not run "autoreconf -vif" before running the tests? Or did I actually manage to break something this time?
>> -Dave
>> On Feb 11, 2011, at 12:15 AM CST, HDF Tester wrote:
>>> *** OPA Tests on 0211Fri ***
>>> Tests Summary
>>> ****FAILED duty: standard****
>>> ****FAILED jam: standard****
>>> ****FAILED liberty: standard****
>>> ****FAILED linew: standard****
>>> Tests Time Summary
>>> jam: Ran 1(0/1/0) tests, Grand total test time = 0m 7s
>>> liberty: Ran 1(0/1/0) tests, Grand total test time = 0m 12s
>>> duty: Ran 1(0/1/0) tests, Grand total test time = 0m 29s
>>> linew: Ran 1(0/1/0) tests, Grand total test time = 4m 8s
>>> jam: Ran 4(0/0/0) hosts, Grand total test time = 5m 5s
>>> Timekeeper log
>>> Timekeeper started at Fri Feb 11 00:10:30 CST 2011
>>> Timekeeper sleeping for 1800 seconds
>>> Tests Failures
>>> Dumping logfile of jam: standard
>>> Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/jam_0211Fri_0010
>>> /bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
>>> libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
>>> libtool: compile: gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
>>> In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
>>> from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
>>> /home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: error: #error no primitives implementation specified
>>> In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: expected specifier-qualifier-list before ‘OPA_ptr_t’
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h: In function ‘OPA_Shm_rel_to_abs’:
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: ‘size_t’ undeclared (first use in this function)
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: expected ‘)’ before ‘offset’
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h: In function ‘OPA_Shm_abs_to_rel’:
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: ‘size_t’ undeclared (first use in this function)
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: expected ‘)’ before ‘a’
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h: In function ‘OPA_Shm_swap_rel’:
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h: In function ‘OPA_Shm_cas_rel_null’:
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h: In function ‘OPA_Queue_is_empty’:
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h: In function ‘OPA_Queue_peek_head’:
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: ‘NULL’ undeclared (first use in this function)
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.c: In function ‘OPA_Queue_init’:
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.c: In function ‘OPA_Queue_header_init’:
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
>>> gmake[2]: *** [opa_queue.lo] Error 1
>>> gmake[2]: *** Waiting for unfinished jobs....
>>> mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
>>> gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/jam/src'
>>> gmake[1]: *** [all] Error 2
>>> gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/jam/src'
>>> gmake: *** [all-recursive] Error 1
>>> Failed running make
>>> ===== Exit bin/snapshot with status=2: Fri Feb 11 00:10:54 CST 2011 =====
>>> Dumping done
>>> Dumping logfile of liberty: standard
>>> Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0211Fri_0010
>>> /bin/sh ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
>>> /home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
>>> gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
>>> gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
>>> Failed running make
>>> ===== Exit bin/snapshot with status=0: Fri Feb 11 00:11:04 CST 2011 =====
>>> Dumping done
>>> Dumping logfile of duty: standard
>>> Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0211Fri_0010
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a castmv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
>>> gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
>>> gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
>>> Failed running make
>>> ===== Exit bin/snapshot with status=0: Fri Feb 11 00:11:19 CST 2011 =====
>>> Dumping done
>>> Dumping logfile of linew: standard
>>> Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/linew_0211Fri_0010
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: `oldv' undeclared (first use in this function)
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: `addr' undeclared (first use in this function)
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: `newv' undeclared (first use in this function)
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h: At top level:
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:90: error: syntax error before "OPA_Shm_cas_rel_null"
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:90: error: syntax error before '*' token
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:91: error: syntax error before "prev"
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: `prev' undeclared (first use in this function)
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: `addr' undeclared (first use in this function)
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: `oldv' undeclared (first use in this function)
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:140: error: syntax error before "OPA_Shm_rel_addr_t"
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:140: warning: no semicolon at end of struct or union
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:141: warning: data definition has no type or storage class
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:143: error: syntax error before "shadow_head"
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:143: warning: data definition has no type or storage class
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:145: error: syntax error before '}' token
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:145: warning: data definition has no type or storage class
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:151: error: syntax error before "OPA_Shm_rel_addr_t"
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:151: warning: no semicolon at end of struct or union
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:152: warning: data definition has no type or storage class
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:156: error: syntax error before '*' token
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:159: error: syntax error before '*' token
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:162: error: syntax error before '*' token
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: `qhead' undeclared (first use in this function)
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:192: error: syntax error before '*' token
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: `qhead_ptr' undeclared (first use in this function)
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.c: At top level:
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.c:29: error: syntax error before '*' token
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: `qhead' undeclared (first use in this function)
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.c:36: error: syntax error before '*' token
>>> /home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: `hdr' undeclared (first use in this function)
>>> gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/src'
>>> gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/src'
>>> Failed running make
>>> ===== Exit bin/snapshot with status=0: Fri Feb 11 00:14:52 CST 2011 =====
>>> Dumping done
>>> Runtest did not exit normally.
>>> Watchers List
>>> OPA Daily test features/platforms watchers and procedure
>>> Procedure:
>>> The watcher will investigate and report the cause of failure by 11am.
>>> The developer who checked in the error code may report so by then too.
>>> The watcher or the developer should get the failure fixed and report it
>>> by 3pm.
>>> Watcher for OPA: Neil
>>> updated: 2009/05/05
>>> Tests Details
>>> 00:10:09 up 7 days, 15:42, 42 users, load average: 2.09, 2.07, 2.06
>>> Filesystem 1K-blocks Used Available Use% Mounted on
>>> /dev/sda3 31738420 3980308 26119884 14% /
>>> /dev/sda1 101086 22885 72982 24% /boot
>>> /dev/sda2 31738420 249136 29851056 1% /tmp
>>> /dev/sda6 31738392 5897308 24202860 20% /var
>>> /dev/sda7 31738392 28756148 1344020 96% /usr
>>> /dev/sda8 124991068 326748 118212620 1% /var/tmp
>>> /dev/mapper/VolGroup00-home
>>> 198351840 14880880 173232600 8% /home
>>> /dev/sde1 565688764 374907084 161582744 70% /scr
>>> /dev/sdc1 961432072 718721912 193872160 79% /mnt/scr1
>>> /dev/sdd1 961432072 803554532 109039540 89% /mnt/hdf
>>> tmpfs 8313848 0 8313848 0% /dev/shm
>>> gumund:/data/ftp 480719072 273486976 182812896 60% /mnt/ftp
>>> gumund:/data/web 480719072 273486976 182812896 60% /mnt/web
>>> pegdub:/mnt/rw-src 288451232 179417888 94380864 66% /mnt/ro-src
>>> pegdub:/mnt/rw-src 288451232 179417888 94380864 66% /mnt/rw-src
>>> STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
>>> TEST_TYPES=standard
>>> Running source repository checkout with output saved in
>>> /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0211Fri
>>> Checking MANIFEST file ...
>>> cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0211Fri.17488: No such file or directory
>>> rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0211Fri.17488': No such file or directory
>>> *** launching tests from jam ***
>>> TESTHOST is linew
>>> jam
>>> duty
>>> liberty
>>> Fork off timekeeper 30
>>> Testing linew
>>> ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
>>> 12:10am up 17 day(s), 11:33, 0 users, load average: 1.09, 0.99, 0.55
>>> / (/dev/dsk/c1t0d0s0 ):62409962 blocks 8253990 files
>>> /devices (/devices ): 0 blocks 0 files
>>> /system/contract (ctfs ): 0 blocks 2147483610 files
>>> /proc (proc ): 0 blocks 29939 files
>>> /etc/mnttab (mnttab ): 0 blocks 0 files
>>> /etc/svc/volatile (swap ):20649424 blocks 1182273 files
>>> /system/object (objfs ): 0 blocks 2147483500 files
>>> /etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
>>> /platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):62409962 blocks 8253990 files
>>> /platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):62409962 blocks 8253990 files
>>> /dev/fd (fd ): 0 blocks 0 files
>>> /tmp (swap ):20649424 blocks 1182273 files
>>> /var/run (swap ):20649424 blocks 1182273 files
>>> /home (jam:/home ):366941920 blocks 50919326 files
>>> /mnt/hdf (jam:/mnt/hdf ):315755080 blocks 114854318 files
>>> /mnt/scr1 (jam:/mnt/scr1 ):485418776 blocks 117160712 files
>>> /mnt/web (gumund:/mnt/web ):414464152 blocks 60891512 files
>>> /mnt/ftp (gumund:/mnt/ftp ):414464152 blocks 60891512 files
>>> TEST_TYPES=standard
>>> Fri Feb 11 00:10:57 CST 2011
>>> *** starting standard tests in linew ***
>>> Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
>>> Running snapshot with output saved in
>>> *** finished standard tests for linew ***
>>> Total time = 3m 56s
>>> *** finished tests in linew ***
>>> Fri Feb 11 00:14:53 CST 2011
>>> ****SYSTEM ERROR linew: Abnormal exit from runtest ****
>>> Fri Feb 11 00:15:24 CST 2011
>>> ****SYSTEM ERROR linew: runtest command failed ****
>>> Testing jam
>>> ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
>>> 00:10:37 up 7 days, 15:42, 42 users, load average: 2.27, 2.11, 2.08
>>> /dev/sda2 31738420 249260 29850932 1% /tmp
>>> /dev/sda6 31738392 5897312 24202856 20% /var
>>> /dev/sdc1 961432072 718722744 193871328 79% /mnt/scr1
>>> TEST_TYPES=standard
>>> Fri Feb 11 00:10:47 CST 2011
>>> *** starting standard tests in jam ***
>>> Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
>>> *** finished standard tests for jam ***
>>> Total time = 0m 7s
>>> *** finished tests in jam ***
>>> ****SYSTEM ERROR jam: Abnormal exit from runtest ****
>>> ****SYSTEM ERROR jam: runtest command failed ****
>>> Testing duty
>>> ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
>>> 12:10AM up 43 days, 9:25, 0 users, load averages: 0.00, 0.00, 0.00
>>> Filesystem 1K-blocks Used Avail Capacity Mounted on
>>> /dev/aacd0s1a 507630 60990 406030 13% /
>>> devfs 1 1 0 100% /dev
>>> /dev/aacd0s1h 188433016 123604522 49753854 71% /data
>>> /dev/aacd0s1g 32494668 25345144 4549952 85% /local_home
>>> /dev/aacd0s1f 12186190 4125638 7085658 37% /usr
>>> /dev/aacd0s1d 507630 50460 416560 11% /var
>>> /dev/aacd0s1e 253678 178 233206 0% /var/tmp
>>> procfs 4 4 0 100% /proc
>>> jam:/home 198351840 14880880 173232600 8% /home
>>> jam:/mnt/hdf 961432072 803554532 109039540 88% /mnt/hdf
>>> jam:/mnt/scr1 961432072 718722812 193871260 79% /mnt/scr1
>>> gumund:/data/web 480719056 273486980 182812876 60% /mnt/web
>>> gumund:/data/ftp 480719056 273486980 182812876 60% /mnt/ftp
>>> devfs 1 1 0 100% /var/named/dev
>>> /dev/md0 126702 76 116490 0% /tmp
>>> TEST_TYPES=standard
>>> Fri Feb 11 00:10:50 CST 2011
>>> *** starting standard tests in duty ***
>>> Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
>>> *** finished standard tests for duty ***
>>> Total time = 0m 29s
>>> *** finished tests in duty ***
>>> ****SYSTEM ERROR duty: Abnormal exit from runtest ****
>>> ****SYSTEM ERROR duty: runtest command failed ****
>>> Testing liberty
>>> ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname liberty
>>> 12:10AM up 56 days, 13:18, 2 users, load averages: 0.00, 0.00, 0.00
>>> /dev/aacd0s1a 507630 86918 380102 19% /
>>> /dev/aacd0s1g 47047830 31099734 12184270 72% /local_home
>>> /dev/aacd0s1f 12186190 7420280 3791016 66% /usr
>>> /dev/aacd0s1d 1012974 104166 827772 11% /var
>>> /dev/aacd0s1e 507630 62724 404296 13% /var/tmp
>>> jam:/mnt/scr1 961432072 718722884 193871188 79% /mnt/scr1
>>> /dev/md0 126702 20 116546 0% /tmp
>>> TEST_TYPES=standard
>>> Fri Feb 11 00:10:53 CST 2011
>>> *** starting standard tests in liberty ***
>>> Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008 sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY amd64
>>> *** finished standard tests for liberty ***
>>> Total time = 0m 11s
>>> *** finished tests in liberty ***
>>> ****SYSTEM ERROR liberty: Abnormal exit from runtest ****
>>> ****SYSTEM ERROR liberty: runtest command failed ****
>>> _______________________________________________
>>> opa-nightly-tests mailing list
>>> opa-nightly-tests at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/opa-nightly-tests
More information about the opa-nightly-tests
