[opa-nightly-tests] jam OPA_Daily_Tests_0211Fri_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Fri Feb 11 00:15:24 CST 2011
*** OPA Tests on 0211Fri ***
   Tests Summary
****FAILED duty: standard****
****FAILED jam: standard****
****FAILED liberty: standard****
****FAILED linew: standard****
   Tests Time Summary
jam: Ran 1(0/1/0) tests, Grand total test time =  0m 7s
liberty: Ran 1(0/1/0) tests, Grand total test time =  0m 12s
duty: Ran 1(0/1/0) tests, Grand total test time =  0m 29s
linew: Ran 1(0/1/0) tests, Grand total test time =  4m 8s
jam: Ran 4(0/0/0) hosts, Grand total test time =  5m 5s
   Timekeeper log
Timekeeper started at Fri Feb 11 00:10:30 CST 2011
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of jam: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/jam_0211Fri_0010
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c -o opa_queue.lo /home/hdftest/snapshots-opa/current/src/opa_queue.c
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_primitives.c -o opa_primitives.o
libtool: compile:  gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src -MT opa_queue.lo -MD -MP -MF .deps/opa_queue.Tpo -c /home/hdftest/snapshots-opa/current/src/opa_queue.c -o opa_queue.o
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.h:10,
                 from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: error: #error no primitives implementation specified
In file included from /home/hdftest/snapshots-opa/current/src/opa_queue.c:9:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: expected specifier-qualifier-list before ‘OPA_ptr_t’
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function ‘OPA_Shm_rel_to_abs’:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a cast
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: ‘size_t’ undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: (Each undeclared identifier is reported only once
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: for each function it appears in.)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: expected ‘)’ before ‘offset’
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function ‘OPA_Shm_abs_to_rel’:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: ‘size_t’ undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: expected ‘)’ before ‘a’
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function ‘OPA_Shm_swap_rel’:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function ‘OPA_Shm_cas_rel_null’:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function ‘OPA_Queue_is_empty’:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function ‘OPA_Queue_peek_head’:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: ‘NULL’ undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function ‘OPA_Queue_init’:
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function ‘OPA_Queue_header_init’:
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: ‘OPA_Shm_rel_addr_t’ has no member named ‘offset’
gmake[2]: *** [opa_queue.lo] Error 1
gmake[2]: *** Waiting for unfinished jobs....
mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/jam/src'
gmake[1]: *** [all] Error 2
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/jam/src'
gmake: *** [all-recursive] Error 1
Failed running make
===== Exit bin/snapshot with status=2: Fri Feb 11 00:10:54 CST 2011 =====
Dumping done
Dumping logfile of liberty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0211Fri_0010
/bin/sh ../libtool --tag=CC   --mode=compile gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/src      -MT opa_primitives.lo -MD -MP -MF .deps/opa_primitives.Tpo -c -o opa_primitives.lo /home/hdftest/snapshots-opa/current/src/opa_primitives.c
/home/hdftest/snapshots-opa/current/src/opa_primitives.h:114:2: #error no primitives implementation specified
/home/hdftest/snapshots-opa/current/src/opa_queue.h:56: error: syntax error before "OPA_ptr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_rel_to_abs':mv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:65: error: syntax error before "offset"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_abs_to_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: `size_t' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:75: error: syntax error before "a"
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_swap_rel':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Shm_cas_rel_null':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_is_empty':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:166: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:171: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h: In function `OPA_Queue_peek_head':
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.h:197: error: `NULL' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:32: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c:33: error: structure has no member named `offset'
/home/hdftest/snapshots-opa/current/src/opa_queue.c: In function `OPA_Queue_header_init':
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: structure has no member named `offset'
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/liberty/src'
Failed running make
===== Exit bin/snapshot with status=0: Fri Feb 11 00:11:04 CST 2011 =====
Dumping done
Dumping logfile of duty: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/duty_0211Fri_0010
/home/hdftest/snapshots-opa/current/src/opa_queue.h:63: warning: initialization makes pointer from integer without a castmv -f .deps/opa_primitives.Tpo .deps/opa_primitives.Plo
gmake[2]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
gmake[1]: Leaving directory `/mnt/scr1/SnapTest/snapshots-opa/TestDir/duty/src'
Failed running make
===== Exit bin/snapshot with status=0: Fri Feb 11 00:11:19 CST 2011 =====
Dumping done
Dumping logfile of linew: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/linew_0211Fri_0010
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: `oldv' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: `addr' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:82: error: `newv' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h: At top level:
/home/hdftest/snapshots-opa/current/src/opa_queue.h:90: error: syntax error before "OPA_Shm_cas_rel_null"
/home/hdftest/snapshots-opa/current/src/opa_queue.h:90: error: syntax error before '*' token
/home/hdftest/snapshots-opa/current/src/opa_queue.h:91: error: syntax error before "prev"
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: `prev' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: `addr' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:92: error: `oldv' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:140: error: syntax error before "OPA_Shm_rel_addr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h:140: warning: no semicolon at end of struct or union
/home/hdftest/snapshots-opa/current/src/opa_queue.h:141: warning: data definition has no type or storage class
/home/hdftest/snapshots-opa/current/src/opa_queue.h:143: error: syntax error before "shadow_head"
/home/hdftest/snapshots-opa/current/src/opa_queue.h:143: warning: data definition has no type or storage class
/home/hdftest/snapshots-opa/current/src/opa_queue.h:145: error: syntax error before '}' token
/home/hdftest/snapshots-opa/current/src/opa_queue.h:145: warning: data definition has no type or storage class
/home/hdftest/snapshots-opa/current/src/opa_queue.h:151: error: syntax error before "OPA_Shm_rel_addr_t"
/home/hdftest/snapshots-opa/current/src/opa_queue.h:151: warning: no semicolon at end of struct or union
/home/hdftest/snapshots-opa/current/src/opa_queue.h:152: warning: data definition has no type or storage class
/home/hdftest/snapshots-opa/current/src/opa_queue.h:156: error: syntax error before '*' token
/home/hdftest/snapshots-opa/current/src/opa_queue.h:159: error: syntax error before '*' token
/home/hdftest/snapshots-opa/current/src/opa_queue.h:162: error: syntax error before '*' token
/home/hdftest/snapshots-opa/current/src/opa_queue.h:165: error: `qhead' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.h:192: error: syntax error before '*' token
/home/hdftest/snapshots-opa/current/src/opa_queue.h:196: error: `qhead_ptr' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c: At top level:
/home/hdftest/snapshots-opa/current/src/opa_queue.c:29: error: syntax error before '*' token
/home/hdftest/snapshots-opa/current/src/opa_queue.c:31: error: `qhead' undeclared (first use in this function)
/home/hdftest/snapshots-opa/current/src/opa_queue.c:36: error: syntax error before '*' token
/home/hdftest/snapshots-opa/current/src/opa_queue.c:38: error: `hdr' undeclared (first use in this function)
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/src'
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/src'
Failed running make
===== Exit bin/snapshot with status=0: Fri Feb 11 00:14:52 CST 2011 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
 00:10:09 up 7 days, 15:42, 42 users,  load average: 2.09, 2.07, 2.06
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   3980308  26119884  14% /
/dev/sda1               101086     22885     72982  24% /boot
/dev/sda2             31738420    249136  29851056   1% /tmp
/dev/sda6             31738392   5897308  24202860  20% /var
/dev/sda7             31738392  28756148   1344020  96% /usr
/dev/sda8            124991068    326748 118212620   1% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  14880880 173232600   8% /home
/dev/sde1            565688764 374907084 161582744  70% /scr
/dev/sdc1            961432072 718721912 193872160  79% /mnt/scr1
/dev/sdd1            961432072 803554532 109039540  89% /mnt/hdf
tmpfs                  8313848         0   8313848   0% /dev/shm
gumund:/data/ftp     480719072 273486976 182812896  60% /mnt/ftp
gumund:/data/web     480719072 273486976 182812896  60% /mnt/web
pegdub:/mnt/rw-src   288451232 179417888  94380864  66% /mnt/ro-src
pegdub:/mnt/rw-src   288451232 179417888  94380864  66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0211Fri
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0211Fri.17488: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0211Fri.17488': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
duty
liberty
    Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
 12:10am  up 17 day(s), 11:33,  0 users,  load average: 1.09, 0.99, 0.55
/                  (/dev/dsk/c1t0d0s0 ):62409962 blocks  8253990 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483610 files
/proc              (proc              ):       0 blocks    29939 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ):20649424 blocks  1182273 files
/system/object     (objfs             ):       0 blocks 2147483500 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):62409962 blocks  8253990 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):62409962 blocks  8253990 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ):20649424 blocks  1182273 files
/var/run           (swap              ):20649424 blocks  1182273 files
/home              (jam:/home         ):366941920 blocks 50919326 files
/mnt/hdf           (jam:/mnt/hdf      ):315755080 blocks 114854318 files
/mnt/scr1          (jam:/mnt/scr1     ):485418776 blocks 117160712 files
/mnt/web           (gumund:/mnt/web   ):414464152 blocks 60891512 files
/mnt/ftp           (gumund:/mnt/ftp   ):414464152 blocks 60891512 files
TEST_TYPES=standard
Fri Feb 11 00:10:57 CST 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
*** finished standard tests for linew ***
Total time = 3m 56s
*** finished tests in linew ***
Fri Feb 11 00:14:53 CST 2011
****SYSTEM ERROR linew: Abnormal exit from runtest ****
	****SYSTEM ERROR linew: runtest command failed ****
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
 00:10:37 up 7 days, 15:42, 42 users,  load average: 2.27, 2.11, 2.08
/dev/sda2             31738420    249260  29850932   1% /tmp
/dev/sda6             31738392   5897312  24202856  20% /var
/dev/sdc1            961432072 718722744 193871328  79% /mnt/scr1
TEST_TYPES=standard
Fri Feb 11 00:10:47 CST 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
*** finished standard tests for jam ***
Total time = 0m 7s
*** finished tests in jam ***
****SYSTEM ERROR jam: Abnormal exit from runtest ****
	****SYSTEM ERROR jam: runtest command failed ****
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM  up 43 days,  9:25, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/aacd0s1a       507630     60990    406030    13%    /
devfs                    1         1         0   100%    /dev
/dev/aacd0s1h    188433016 123604522  49753854    71%    /data
/dev/aacd0s1g     32494668  25345144   4549952    85%    /local_home
/dev/aacd0s1f     12186190   4125638   7085658    37%    /usr
/dev/aacd0s1d       507630     50460    416560    11%    /var
/dev/aacd0s1e       253678       178    233206     0%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840  14880880 173232600     8%    /home
jam:/mnt/hdf     961432072 803554532 109039540    88%    /mnt/hdf
jam:/mnt/scr1    961432072 718722812 193871260    79%    /mnt/scr1
gumund:/data/web 480719056 273486980 182812876    60%    /mnt/web
gumund:/data/ftp 480719056 273486980 182812876    60%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702        76    116490     0%    /tmp
TEST_TYPES=standard
Fri Feb 11 00:10:50 CST 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
*** finished standard tests for duty ***
Total time = 0m 29s
*** finished tests in duty ***
****SYSTEM ERROR duty: Abnormal exit from runtest ****
	****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname liberty
12:10AM  up 56 days, 13:18, 2 users, load averages: 0.00, 0.00, 0.00
/dev/aacd0s1a       507630     86918    380102    19%    /
/dev/aacd0s1g     47047830  31099734  12184270    72%    /local_home
/dev/aacd0s1f     12186190   7420280   3791016    66%    /usr
/dev/aacd0s1d      1012974    104166    827772    11%    /var
/dev/aacd0s1e       507630     62724    404296    13%    /var/tmp
jam:/mnt/scr1    961432072 718722884 193871188    79%    /mnt/scr1
/dev/md0            126702        20    116546     0%    /tmp
TEST_TYPES=standard
Fri Feb 11 00:10:53 CST 2011
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008     sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY  amd64
*** finished standard tests for liberty ***
Total time = 0m 11s
*** finished tests in liberty ***
****SYSTEM ERROR liberty: Abnormal exit from runtest ****
	****SYSTEM ERROR liberty: runtest command failed ****
More information about the opa-nightly-tests mailing list
