[opa-nightly-tests] jam OPA_Daily_Tests_0408Fri_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Fri Apr 8 00:31:09 CDT 2011
*** OPA Tests on 0408Fri ***
Tests Summary
****FAILED amani: standard****
PASSED duty: standard
PASSED heiwa: standard
PASSED jam: standard
PASSED linew: standard
Tests Time Summary
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 23s
amani: Ran 1(0/1/0) tests, Grand total test time = 3m 40s
heiwa: Ran 1(1/0/0) tests, Grand total test time = 5m 37s
linew: Ran 1(1/0/0) tests, Grand total test time = 7m 51s
duty: Ran 1(1/0/0) tests, Grand total test time = 19m 43s
jam: Ran 6(0/0/0) hosts, Grand total test time = 20m 48s
Timekeeper log
Timekeeper started at Fri Apr 8 00:10:31 CDT 2011
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of amani: standard
Last 50 lines of /mnt/scr1/SnapTest/snapshots-opa/log/amani_0408Fri_0010
LL/SC not available
Testing pointer LL/SC stack -SKIP-
LL/SC not available
All primitives tests passed.
PASS: test_primitives
Testing memory barrier sanity PASSED
Testing memory barriers with linear array with 2 threads PASSED
Testing memory barriers with local variables with 2 threads PASSED
Testing memory barriers with scattered array with 2 threads PASSED
Testing memory barriers with linear array with 4 threads PASSED
Testing memory barriers with local variables with 4 threads PASSED
Testing memory barriers with scattered array with 4 threads PASSED
Testing memory barriers with linear array with 10 threads PASSED
Testing memory barriers with local variables with 10 threads PASSED
Testing memory barriers with scattered array with 10 threads PASSED
Testing memory barriers with linear array with 100 threads PASSED
Testing memory barriers with local variables with 100 threads PASSED
Testing memory barriers with scattered array with 100 threads PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity PASSED
Testing multithreaded queue with 2 threads PASSED
Testing multithreaded queue (empty queue) with 2 threads PASSED
Testing multithreaded queue (full queue) with 2 threads PASSED
Testing multithreaded queue with 4 threads PASSED
Testing multithreaded queue (empty queue) with 4 threads PASSED
Testing multithreaded queue (full queue) with 4 threads PASSED
Testing multithreaded queue with 10 threads PASSED
Testing multithreaded queue (empty queue) with 10 threads Incorrect number of elements dequeued: 4055888 Expected: 4500000
*FAILED*
at /home/hdftest/snapshots-opa/current/test/test_queue.c:399 in test_queue_threaded()...
Unexpected return from 1 thread
Testing multithreaded queue (full queue) with 10 threads PASSED
Testing multithreaded queue with 100 threads PASSED
Testing multithreaded queue (empty queue) with 100 threads PASSED
Testing multithreaded queue (full queue) with 100 threads PASSED
***** 1 QUEUE TEST FAILED! *****
FAIL: test_queue
1 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/amani/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/amani/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Fri Apr 8 00:14:31 CDT 2011 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
00:10:11 up 63 days, 14:42, 83 users, load average: 1.85, 1.36, 1.15
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 4096188 26004004 14% /
/dev/sda1 101086 22885 72982 24% /boot
/dev/sda2 31738420 209116 29891076 1% /tmp
/dev/sda6 31738392 6037004 24063164 21% /var
/dev/sda7 31738392 30278808 0 100% /usr
/dev/sda8 124991068 4583068 113956300 4% /var/tmp
/dev/mapper/VolGroup00-home
198351840 15456176 172657304 9% /home
/dev/sde1 565688764 385831776 150658052 72% /scr
/dev/sdc1 961432072 812104868 100489204 89% /mnt/scr1
/dev/sdd1 961432072 888602596 23991476 98% /mnt/hdf
tmpfs 8313848 16 8313832 1% /dev/shm
gumund:/data/ftp 480719072 285623744 170676128 63% /mnt/ftp
gumund:/data/web 480719072 285623744 170676128 63% /mnt/web
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/ro-src
amani:/mnt/rw-src 288451232 179573408 94225344 66% /mnt/rw-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/REPO_LOG_0408Fri
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0408Fri.15862: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0408Fri.15862': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
amani
heiwa
duty
liberty
Fork off timekeeper 30
cannot remote command with liberty
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname linew
12:10am up 27 day(s), 6:07, 4 users, load average: 1.21, 0.96, 0.50
/ (/dev/dsk/c1t0d0s0 ):69369640 blocks 8259266 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483606 files
/proc (proc ): 0 blocks 29927 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):19912256 blocks 1182199 files
/system/object (objfs ): 0 blocks 2147483491 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):69369640 blocks 8259266 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):69369640 blocks 8259266 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):19912256 blocks 1182199 files
/var/run (swap ):19912256 blocks 1182199 files
/scr (/dev/dsk/c1t1d0s0 ):896595646 blocks 226812188 files
/home (jam:/home ):365791328 blocks 50905754 files
/mnt/hdf (jam:/mnt/hdf ):145658952 blocks 114023404 files
/mnt/scr1 (jam:/mnt/scr1 ):298521632 blocks 116150996 files
/mnt/web (gumund:/mnt/web ):390190600 blocks 60893573 files
/mnt/ftp (gumund:/mnt/ftp ):390190600 blocks 60893573 files
TEST_TYPES=standard
Fri Apr 8 00:10:54 CDT 2011
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_144488-07 sun4u sparc SUNW,A70
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0408Fri_0010
*** finished standard tests for linew ***
Fri Apr 8 00:18:37 CDT 2011
Total time = 7m 44s
*** finished tests in linew ***
Fri Apr 8 00:18:39 CDT 2011
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname jam
00:10:39 up 63 days, 14:42, 83 users, load average: 1.90, 1.41, 1.17
/dev/sda2 31738420 209236 29890956 1% /tmp
/dev/sda6 31738392 6037008 24063160 21% /var
/dev/sdc1 961432072 812171268 100422804 89% /mnt/scr1
TEST_TYPES=standard
Fri Apr 8 00:10:49 CDT 2011
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-194.3.1.el5PAE #1 SMP Thu May 13 13:48:44 EDT 2010 i686 i686 i386 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0408Fri_0010
*** finished standard tests for jam ***
Fri Apr 8 00:12:12 CDT 2011
Total time = 1m 23s
*** finished tests in jam ***
Testing amani
ssh amani -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname amani
00:10:41 up 52 days, 10:40, 5 users, load average: 2.83, 2.26, 1.01
/dev/hda6 39021196 29809992 7197060 81% /
/dev/hda3 12192636 4171780 7391512 37% /var
/dev/hda2 12192636 256056 11307236 3% /tmp
/dev/hda1 101086 23784 72083 25% /boot
tmpfs 2057868 0 2057868 0% /dev/shm
jam:/home 198351840 15456160 172657312 9% /home
jam:/mnt/hdf 961432096 888602592 23991488 98% /mnt/hdf
jam:/mnt/scr1 961432096 812173088 100421024 89% /mnt/scr1
smirom:/scr 267601440 37437216 216351520 15% /mnt/tmp
/dev/sdb1 144221592 74998808 61896744 55% /scr
/dev/sda1 288451232 179573436 94225316 66% /mnt/rw-src
TEST_TYPES=standard
Fri Apr 8 00:10:51 CDT 2011
*** starting standard tests in amani ***
Uname -a: Linux amani 2.6.18-194.32.1.el5 #1 SMP Wed Jan 5 17:52:25 EST 2011 x86_64 x86_64 x86_64 GNU/Linux
*** finished standard tests for amani ***
Total time = 3m 40s
*** finished tests in amani ***
****SYSTEM ERROR amani: Abnormal exit from runtest ****
****SYSTEM ERROR amani: runtest command failed ****
Testing heiwa
ssh heiwa -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname heiwa
00:10:43 up 34 days, 11:41, 15 users, load average: 0.03, 0.18, 0.09
/dev/sdb8 35435232 2727752 30907440 9% /
tmpfs 2008144 0 2008144 0% /dev/shm
/dev/sdb4 198337 106660 81437 57% /boot
/dev/sdb6 12385456 1372868 10383444 12% /tmp
/dev/sdb7 12385456 3952120 7804192 34% /var
/dev/sda6 82573108 740672 77637868 1% /scr
TEST_TYPES=standard
*** starting standard tests in heiwa ***
Uname -a: Linux heiwa 2.6.32.16-150.fc12.ppc64 #1 SMP Sat Jul 24 05:19:27 UTC 2010 ppc64 ppc64 ppc64 GNU/Linux
/mnt/scr1/SnapTest/snapshots-opa/log/heiwa_0408Fri_0010
*** finished standard tests for heiwa ***
Fri Apr 8 00:16:30 CDT 2011
Total time = 5m 36s
*** finished tests in heiwa ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -norepo -configname duty
12:10AM up 99 days, 8:25, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60986 406034 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 123604522 49753854 71% /data
/dev/aacd0s1g 32494668 24582040 5313056 82% /local_home
/dev/aacd0s1f 12186190 4125638 7085658 37% /usr
/dev/aacd0s1d 507630 50380 416640 11% /var
/dev/aacd0s1e 253678 178 233206 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 15456176 172657304 8% /home
jam:/mnt/hdf 961432072 888602596 23991476 97% /mnt/hdf
jam:/mnt/scr1 961432072 812173096 100420976 89% /mnt/scr1
gumund:/data/web 480719056 285623756 170676100 63% /mnt/web
gumund:/data/ftp 480719056 285623756 170676100 63% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 94 116472 0% /tmp
TEST_TYPES=standard
Fri Apr 8 00:10:56 CDT 2011
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
/mnt/scr1/SnapTest/snapshots-opa/log/duty_0408Fri_0010
*** finished standard tests for duty ***
Fri Apr 8 00:30:39 CDT 2011
Total time = 19m 43s
*** finished tests in duty ***
Testing liberty
liberty does not accept Remote Command (Fri Apr 8 00:11:19 CDT 2011)
****SYSTEM ERROR: liberty does not accept Remote Command (Fri Apr 8 00:11:19 CDT 2011)
****INCOMPLETE liberty: snaptest did not complete****
More information about the opa-nightly-tests
