[opa-nightly-tests] honest3 OPA_Daily_Tests_1020Wed_FAILED!!!
HDFTEST Community User hdftest at ncsa.uiuc.edu
Wed Oct 20 00:29:21 CDT 2010
*** OPA Tests on 1020Wed ***
   Tests Summary
****FAILED honest1: standard****
   Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time =  1m 40s
honest3: Ran 1(0/0/0) hosts, Grand total test time =  2m 29s
   Timekeeper log
Timekeeper started at Wed Oct 20 00:26:56 CDT 2010
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of honest1: standard
Last 50 lines of /u/ac/hdftest/snapshots-opa/log/honest1_1020Wed_0027
    LL/SC not available
Testing pointer LL/SC stack                                            -SKIP-
    LL/SC not available
All primitives tests passed.
PASS: test_primitives
Testing memory barrier sanity                                          PASSED
Testing memory barriers with linear array with 2 threads               PASSED
Testing memory barriers with local variables with 2 threads            PASSED
Testing memory barriers with scattered array with 2 threads            PASSED
Testing memory barriers with linear array with 4 threads               PASSED
Testing memory barriers with local variables with 4 threads            PASSED
Testing memory barriers with scattered array with 4 threads            PASSED
Testing memory barriers with linear array with 10 threads              PASSED
Testing memory barriers with local variables with 10 threads           PASSED
Testing memory barriers with scattered array with 10 threads           PASSED
Testing memory barriers with linear array with 100 threads             PASSED
Testing memory barriers with local variables with 100 threads          PASSED
Testing memory barriers with scattered array with 100 threads          PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity                                                   PASSED
Testing multithreaded queue with 2 threads                             PASSED
Testing multithreaded queue (empty queue) with 2 threads               PASSED
Testing multithreaded queue (full queue) with 2 threads                PASSED
Testing multithreaded queue with 4 threads                             PASSED
Testing multithreaded queue (empty queue) with 4 threads               PASSED
Testing multithreaded queue (full queue) with 4 threads                PASSED
Testing multithreaded queue with 10 threads                            PASSED
Testing multithreaded queue (empty queue) with 10 threads              PASSED
Testing multithreaded queue (full queue) with 10 threads               PASSED
Testing multithreaded queue with 100 threads                          *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_queue.c:383 in test_queue_threaded()...
Testing multithreaded queue (empty queue) with 100 threads            *FAILED*
Testing multithreaded queue (full queue) with 100 threads             *FAILED*
***** 3 QUEUE TESTS FAILED! *****
FAIL: test_queue
1 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Wed Oct 20 00:28:51 CDT 2010 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 00:26:42 up 33 days,  6:02, 20 users,  load average: 0.87, 1.44, 1.91
Filesystem           1K-blocks      Used Available Use% Mounted on
none                   8218016         8   8218008   1% /dev/shm
abem4:/var/lib/perceus/
                      74763440  42423584  28542048  60% /var/lib/perceus
10.1.69.1:/usr/src   138916864 100932256  30928032  77% /usr/src
/dev/sda3             29463920    486632  28680008   2% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
                     3385032528 640494856 2572587632  20% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
                     92298352896 68529051936 22362732968  76% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
                     55567516032 20702134748 32087739940  40% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
                     3385032528 134598720 3101410372   5% /usr/local
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
                     276891315456 129762936236 137275705012  49% /cfs/scratch
abem5:/var/spool/torque/server_logs
                     961428816 219331664 693259312  25% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
                      73575600  59314704  10463088  86% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  58900936   8072024  88% /var/forward
mds03.uits.indiana.edu:/mds-wan/client
                     363327960768 304643245332 56423635156  85% /WAN/IU
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /u/ac/hdftest/snapshots-opa/log/REPO_LOG_1020Wed
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.1020Wed.13815: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.1020Wed.13815': No such file or directory
Wed Oct 20 00:26:55 CDT 2010
*** launching tests from honest3 ***
TESTHOST is honest1
    Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -norepo -configname honest1
Using configname option for -configname
opa
 00:27:01 up 15 days, 11:21, 35 users,  load average: 0.16, 0.09, 0.05
none                   8218016         0   8218016   0% /dev/shm
abem2:/var/lib/perceus/
                      74763440  49538000  21427632  70% /var/lib/perceus
/dev/sda2             63013156   1527604  60852752   3% /tmp
                     92298352896 68529060120 22362728704  76% /cfs/projects
                     55567516032 20702134384 32087683784  40% /u
                     3385032528 134598716 3101410428   5% /usr/local
                     276891315456 129763037552 137276294008  49% /cfs/scratch
                     961428816 219331776 693259200  25% /var/spool/torque/server_logs
                      73575600  59314688  10463104  86% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  58901136   8071824  88% /var/forward
                     363327960768 304643245332 56423635144  85% /WAN/IU
TEST_TYPES=standard
Running standard
Wed Oct 20 00:27:11 CDT 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #8 SMP Thu Sep 16 17:22:55 CDT 2010 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 1m 40s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
	****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest3 ***
More information about the opa-nightly-tests mailing list
