[opa-nightly-tests] honest4 OPA_Daily_Tests_0509Sun_FAILED!!!
HDFTEST Community User
hdftest at ncsa.uiuc.edu
Sun May 9 01:26:33 CDT 2010
*** OPA Tests on 0509Sun ***
Tests Summary
****FAILED honest1: standard****
Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time = 1m 0s
honest4: Ran 1(0/0/0) hosts, Grand total test time = 1m 56s
Timekeeper log
Timekeeper started at Sun May 9 01:24:47 CDT 2010
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of honest1: standard
Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0509Sun_0125
Testing memory barrier sanity PASSED
Testing memory barriers with linear array with 2 threads PASSED
Testing memory barriers with local variables with 2 threads PASSED
Testing memory barriers with scattered array with 2 threads PASSED
Testing memory barriers with linear array with 4 threads PASSED
Testing memory barriers with local variables with 4 threads PASSED
Testing memory barriers with scattered array with 4 threads PASSED
Testing memory barriers with linear array with 10 threads PASSED
Testing memory barriers with local variables with 10 threads PASSED
Testing memory barriers with scattered array with 10 threads PASSED
Testing memory barriers with linear array with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:304 in test_barriers_linear_array()...
Testing memory barriers with local variables with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:558 in test_barriers_variables()...
Testing memory barriers with scattered array with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:660 in test_barriers_scattered_array()...
***** 3 BARRIERS TESTS FAILED! *****
FAIL: test_barriers
2 of 3 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Sun May 9 01:26:03 CDT 2010 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
Testing all hosts.
opa
01:24:27 up 26 days, 16:54, 30 users, load average: 2.58, 2.80, 3.41
Filesystem 1K-blocks Used Available Use% Mounted on
none 8218016 0 8218016 0% /dev/shm
abem1:/var/lib/perceus/
138916864 99738320 32121952 76% /var/lib/perceus
10.1.69.1:/usr/src 138916864 99738304 32121952 76% /usr/src
/dev/sda2 63013156 58592 62321764 1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
3385032528 612781336 2600301152 20% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
80761058784 73060864472 6879657124 92% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
55567516032 17615035992 35174987284 34% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
3385032528 112744000 3123265108 4% /usr/local
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
242279901024 163111176728 71077740232 70% /cfs/scratch
abem5:/var/spool/torque/server_logs
961428816 167510496 745080480 19% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
73575600 57748304 12029488 83% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 54379608 12593352 82% /var/forward
mds03.uits.indiana.edu:/mds-wan/client
363327960768 280725507176 80341306628 78% /WAN/IU
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running CVS checkout with output saved in
/u/ac/hdftest/snapshots-opa/log/CVS_LOG_0509Sun
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0509Sun.9131: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0509Sun.9131': No such file or directory
Sun May 9 01:24:46 CDT 2010
*** launching tests from honest4 ***
TESTHOST is honest1
Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -nocvs -configname honest1
Using configname option for -configname
opa
01:24:53 up 26 days, 16:55, 35 users, load average: 1.64, 1.34, 1.23
none 8218016 3128 8214888 1% /dev/shm
abem2:/var/lib/perceus/
74763440 50843376 20122256 72% /var/lib/perceus
/dev/sda2 63013156 72740 62307616 1% /tmp
55567516032 17615360092 35174694020 34% /u
3385032528 112744000 3123265112 4% /usr/local
242279901024 163115585728 71073331700 70% /cfs/scratch
961428816 167510592 745080384 19% /var/spool/torque/server_logs
pop:/var/forward 70557056 54379704 12593256 82% /var/forward
363327960768 280725507168 80341306636 78% /WAN/IU
TEST_TYPES=standard
Running standard
Sun May 9 01:25:03 CDT 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 1m 0s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest4 ***
More information about the opa-nightly-tests
