[opa-nightly-tests] honest4 OPA_Daily_Tests_0331Wed_FAILED!!!
HDFTEST Community User hdftest at ncsa.uiuc.edu
Wed Mar 31 00:48:58 CDT 2010
*** OPA Tests on 0331Wed ***
   Tests Summary
****FAILED honest1: standard****
   Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time =  0m 54s
honest4: Ran 1(0/0/0) hosts, Grand total test time =  1m 43s
   Timekeeper log
Timekeeper started at Wed Mar 31 00:47:19 CDT 2010
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of honest1: standard
Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0331Wed_0047
Testing memory barrier sanity                                          PASSED
Testing memory barriers with linear array with 2 threads               PASSED
Testing memory barriers with local variables with 2 threads            PASSED
Testing memory barriers with scattered array with 2 threads            PASSED
Testing memory barriers with linear array with 4 threads               PASSED
Testing memory barriers with local variables with 4 threads            PASSED
Testing memory barriers with scattered array with 4 threads            PASSED
Testing memory barriers with linear array with 10 threads              PASSED
Testing memory barriers with local variables with 10 threads           PASSED
Testing memory barriers with scattered array with 10 threads           PASSED
Testing memory barriers with linear array with 100 threads            *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:304 in test_barriers_linear_array()...
Testing memory barriers with local variables with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:558 in test_barriers_variables()...
Testing memory barriers with scattered array with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:660 in test_barriers_scattered_array()...
***** 3 BARRIERS TESTS FAILED! *****
FAIL: test_barriers
2 of 3 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Wed Mar 31 00:48:28 CDT 2010 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 00:47:05 up 7 days,  7:00, 27 users,  load average: 0.36, 0.64, 0.95
Filesystem           1K-blocks      Used Available Use% Mounted on
none                   8218016         0   8218016   0% /dev/shm
abem1:/var/lib/perceus/
                     138916864 108322544  23537728  83% /var/lib/perceus
10.1.69.1:/usr/src   138916864 108322528  23537728  83% /usr/src
/dev/sda2             63013156     53472  62326884   1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
                     3385032528 569164592 2643917896  18% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
                     80761058784 61208351904 18732220996  77% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
                     55567516032 17241355556 35548281980  33% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
                     3385032528 109998108 3126011000   4% /usr/local
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
                     242279901024 139276183856 94914609064  60% /cfs/scratch
abem5:/var/spool/torque/server_logs
                     961428816 154483440 758107536  17% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
                      73575600  57196592  12581200  82% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  57924104   9048856  87% /var/forward
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running CVS checkout with output saved in
   /u/ac/hdftest/snapshots-opa/log/CVS_LOG_0331Wed
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0331Wed.24280: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0331Wed.24280': No such file or directory
*** launching tests from honest4 ***
TESTHOST is honest1
    Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -nocvs -configname honest1
Using configname option for -configname
opa
 00:47:24 up 7 days,  7:00, 35 users,  load average: 1.23, 1.46, 1.11
abem2:/var/lib/perceus/
                      74763440  59060496  11905136  84% /var/lib/perceus
/dev/sda2             63013156     53460  62326896   1% /tmp
                     80761058784 61208351904 18732218492  77% /cfs/projects
                     55567516032 17241366568 35548253640  33% /u
                     242279901024 139277034096 94913877804  60% /cfs/scratch
                     961428816 154483520 758107456  17% /var/spool/torque/server_logs
pop:/var/forward      70557056  57924128   9048832  87% /var/forward
TEST_TYPES=standard
Running standard
Wed Mar 31 00:47:34 CDT 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 0m 54s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
	****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest4 ***
More information about the opa-nightly-tests mailing list
