[opa-nightly-tests] honest4 OPA_Daily_Tests_0316Tue_FAILED!!!
HDFTEST Community User hdftest at ncsa.uiuc.edu
Tue Mar 16 01:05:18 CDT 2010
*** OPA Tests on 0316Tue ***
   Tests Summary
****FAILED honest1: standard****
   Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time =  1m 12s
honest4: Ran 1(0/0/0) hosts, Grand total test time =  2m 9s
   Timekeeper log
Timekeeper started at Tue Mar 16 01:03:19 CDT 2010
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of honest1: standard
Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0316Tue_0103
Testing memory barrier sanity                                          PASSED
Testing memory barriers with linear array with 2 threads               PASSED
Testing memory barriers with local variables with 2 threads            PASSED
Testing memory barriers with scattered array with 2 threads            PASSED
Testing memory barriers with linear array with 4 threads               PASSED
Testing memory barriers with local variables with 4 threads            PASSED
Testing memory barriers with scattered array with 4 threads            PASSED
Testing memory barriers with linear array with 10 threads              PASSED
Testing memory barriers with local variables with 10 threads           PASSED
Testing memory barriers with scattered array with 10 threads           PASSED
Testing memory barriers with linear array with 100 threads            *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:304 in test_barriers_linear_array()...
Testing memory barriers with local variables with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:558 in test_barriers_variables()...
Testing memory barriers with scattered array with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:660 in test_barriers_scattered_array()...
***** 3 BARRIERS TESTS FAILED! *****
FAIL: test_barriers
1 of 3 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Tue Mar 16 01:04:47 CDT 2010 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 01:02:58 up 12 days, 13:21, 33 users,  load average: 1.48, 1.72, 2.30
Filesystem           1K-blocks      Used Available Use% Mounted on
none                   8218016         0   8218016   0% /dev/shm
abem1:/var/lib/perceus/
                     138916864 108260944  23599344  83% /var/lib/perceus
10.1.69.1:/usr/src   138916864 108260928  23599360  83% /usr/src
/dev/sda2             63013156    607528  61772828   1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
                     3385032528 569045284 2644037048  18% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
                     80761058784 58481500856 21458221564  74% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
                     55567516032 17043555040 35746794852  33% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
                     3385032528 105080516 3130928588   4% /usr/local
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
                     242279901024 128936490244 105244396528  56% /cfs/scratch
abem5:/var/spool/torque/server_logs
                     961428816 146926576 765664400  17% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
                      73575600  56999712  12778080  82% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  54115976  12856984  81% /var/forward
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running CVS checkout with output saved in
   /u/ac/hdftest/snapshots-opa/log/CVS_LOG_0316Tue
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0316Tue.10850: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0316Tue.10850': No such file or directory
*** launching tests from honest4 ***
TESTHOST is honest1
    Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -nocvs -configname honest1
Using configname option for -configname
opa
 01:03:25 up 50 days,  3:18, 43 users,  load average: 0.05, 0.17, 0.26
abem2:/var/lib/perceus/
                      74763440  58906752  12058880  84% /var/lib/perceus
/dev/sda2             63013156    700868  61679488   2% /tmp
                     80761058784 58481632632 21458093252  74% /cfs/projects
                     55567516032 17040907484 35749448152  33% /u
                     3385032528 105080528 3130928580   4% /usr/local
                     242279901024 128937476600 105243238840  56% /cfs/scratch
                     961428816 146926672 765664304  17% /var/spool/torque/server_logs
                      73575600  56999984  12777808  82% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  54116120  12856840  81% /var/forward
mds03.uits.indiana.edu:/mds-wan/client
                     363327960768 284926341276 76140078356  79% /WAN/IU
TEST_TYPES=standard
Running standard
Tue Mar 16 01:03:35 CDT 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 1m 12s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
	Tue Mar 16 01:05:17 CDT 2010
	****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest4 ***
More information about the opa-nightly-tests mailing list
