[opa-nightly-tests] honest4 OPA_Daily_Tests_0314Sun_FAILED!!!
HDFTEST Community User
hdftest at ncsa.uiuc.edu
Sun Mar 14 01:47:22 CST 2010
*** OPA Tests on 0314Sun ***
Tests Summary
****FAILED honest1: standard****
Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time = 1m 12s
honest4: Ran 1(0/0/0) hosts, Grand total test time = 2m 8s
Timekeeper log
Timekeeper started at Sun Mar 14 01:45:24 CST 2010
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of honest1: standard
Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0314Sun_0145
Testing memory barrier sanity PASSED
Testing memory barriers with linear array with 2 threads PASSED
Testing memory barriers with local variables with 2 threads PASSED
Testing memory barriers with scattered array with 2 threads PASSED
Testing memory barriers with linear array with 4 threads PASSED
Testing memory barriers with local variables with 4 threads PASSED
Testing memory barriers with scattered array with 4 threads PASSED
Testing memory barriers with linear array with 10 threads PASSED
Testing memory barriers with local variables with 10 threads PASSED
Testing memory barriers with scattered array with 10 threads PASSED
Testing memory barriers with linear array with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:304 in test_barriers_linear_array()...
Testing memory barriers with local variables with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:558 in test_barriers_variables()...
Testing memory barriers with scattered array with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:660 in test_barriers_scattered_array()...
***** 3 BARRIERS TESTS FAILED! *****
FAIL: test_barriers
1 of 3 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Sun Mar 14 01:46:52 CST 2010 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
Testing all hosts.
opa
01:45:04 up 10 days, 15:03, 30 users, load average: 0.24, 0.51, 0.99
Filesystem 1K-blocks Used Available Use% Mounted on
none 8218016 0 8218016 0% /dev/shm
abem1:/var/lib/perceus/
138916864 108267072 23593216 83% /var/lib/perceus
10.1.69.1:/usr/src 138916864 108267072 23593216 83% /usr/src
/dev/sda2 63013156 607308 61773048 1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
3385032528 568990756 2644091652 18% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
80761058784 55541470436 24398915880 70% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
55567516032 16988919200 35801395020 33% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
3385032528 104978424 3131030664 4% /usr/local
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
242279901024 116291229220 117890796316 50% /cfs/scratch
abem5:/var/spool/torque/server_logs
961428816 146199968 766391008 17% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
73575600 58289456 11488336 84% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 53638912 13334048 81% /var/forward
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running CVS checkout with output saved in
/u/ac/hdftest/snapshots-opa/log/CVS_LOG_0314Sun
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0314Sun.14851: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0314Sun.14851': No such file or directory
*** launching tests from honest4 ***
TESTHOST is honest1
Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -nocvs -configname honest1
Using configname option for -configname
opa
01:45:30 up 48 days, 5:01, 48 users, load average: 0.21, 0.20, 0.18
abem2:/var/lib/perceus/
74763440 59092256 11873376 84% /var/lib/perceus
/dev/sda2 63013156 700332 61680024 2% /tmp
80761058784 55542412696 24397248560 70% /cfs/projects
55567516032 16988881972 35801170888 33% /u
3385032528 104978192 3131030792 4% /usr/local
242279901024 116292002992 117888905964 50% /cfs/scratch
961428816 146200080 766390896 17% /var/spool/torque/server_logs
pop:/var/forward 70557056 53638984 13333976 81% /var/forward
mds03.uits.indiana.edu:/mds-wan/client
363327960768 281249299436 79817333440 78% /WAN/IU
TEST_TYPES=standard
Running standard
Sun Mar 14 01:45:40 CST 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 1m 12s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest4 ***
More information about the opa-nightly-tests
