[opa-nightly-tests] honest4 OPA_Daily_Tests_0313Sat_FAILED!!!
HDFTEST Community User hdftest at ncsa.uiuc.edu
Sat Mar 13 05:20:18 CST 2010
*** OPA Tests on 0313Sat ***
   Tests Summary
****FAILED honest1: standard****
   Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time =  1m 10s
honest4: Ran 1(0/0/0) hosts, Grand total test time =  2m 6s
   Timekeeper log
Timekeeper started at Sat Mar 13 05:18:21 CST 2010
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of honest1: standard
Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0313Sat_0518
Testing memory barrier sanity                                          PASSED
Testing memory barriers with linear array with 2 threads               PASSED
Testing memory barriers with local variables with 2 threads            PASSED
Testing memory barriers with scattered array with 2 threads            PASSED
Testing memory barriers with linear array with 4 threads               PASSED
Testing memory barriers with local variables with 4 threads            PASSED
Testing memory barriers with scattered array with 4 threads            PASSED
Testing memory barriers with linear array with 10 threads              PASSED
Testing memory barriers with local variables with 10 threads           PASSED
Testing memory barriers with scattered array with 10 threads           PASSED
Testing memory barriers with linear array with 100 threads            *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:304 in test_barriers_linear_array()...
Testing memory barriers with local variables with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:558 in test_barriers_variables()...
Testing memory barriers with scattered array with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:660 in test_barriers_scattered_array()...
***** 3 BARRIERS TESTS FAILED! *****
FAIL: test_barriers
1 of 3 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Sat Mar 13 05:19:47 CST 2010 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 05:18:02 up 9 days, 18:36, 30 users,  load average: 0.22, 0.57, 1.19
Filesystem           1K-blocks      Used Available Use% Mounted on
none                   8218016         0   8218016   0% /dev/shm
abem1:/var/lib/perceus/
                     138916864 108250992  23609296  83% /var/lib/perceus
10.1.69.1:/usr/src   138916864 108250976  23609312  83% /usr/src
/dev/sda2             63013156    607308  61773048   1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
                     3385032528 568990756 2644091612  18% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
                     80761058784 54481917212 25457684952  69% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
                     55567516032 16926139932 35863997088  33% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
                     3385032528 104933212 3131075900   4% /usr/local
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
                     242279901024 107731607232 126448159540  47% /cfs/scratch
abem5:/var/spool/torque/server_logs
                     961428816 145829072 766761904  16% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
                      73575600  58311616  11466176  84% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  53282344  13690616  80% /var/forward
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running CVS checkout with output saved in
   /u/ac/hdftest/snapshots-opa/log/CVS_LOG_0313Sat
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0313Sat.4590: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0313Sat.4590': No such file or directory
*** launching tests from honest4 ***
TESTHOST is honest1
    Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -nocvs -configname honest1
Using configname option for -configname
opa
 05:18:27 up 47 days,  8:33, 44 users,  load average: 0.11, 0.05, 0.09
abem2:/var/lib/perceus/
                      74763440  59053696  11911936  84% /var/lib/perceus
/dev/sda2             63013156    700344  61680012   2% /tmp
                     80761058784 54482149792 25457530944  69% /cfs/projects
                     55567516032 16926141948 35863907116  33% /u
                     3385032528 104933220 3131075892   4% /usr/local
                     242279901024 107734313124 126445569032  47% /cfs/scratch
                     961428816 145829184 766761792  16% /var/spool/torque/server_logs
                      73575600  58311728  11466064  84% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  53282440  13690520  80% /var/forward
mds03.uits.indiana.edu:/mds-wan/client
                     363327960768 275718892800 85347604348  77% /WAN/IU
TEST_TYPES=standard
Running standard
Sat Mar 13 05:18:37 CST 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 1m 10s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
	****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest4 ***
More information about the opa-nightly-tests mailing list
