[opa-nightly-tests] honest3 OPA_Daily_Tests_0624Thu
HDFTEST Community User
hdftest at ncsa.uiuc.edu
Thu Jun 24 00:08:31 CDT 2010
*** OPA Tests on 0624Thu ***
Tests Summary
Tests Time Summary
honest3: Ran 1(0/0/0) hosts, Grand total test time = 0m 50s
Timekeeper log
Timekeeper started at Thu Jun 24 00:07:37 CDT 2010
Timekeeper sleeping for 1800 seconds
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
Testing all hosts.
opa
00:07:23 up 2 days, 6:07, 16 users, load average: 1.50, 1.46, 1.38
Filesystem 1K-blocks Used Available Use% Mounted on
none 8218016 0 8218016 0% /dev/shm
abem4:/var/lib/perceus/
74763440 42380752 28584880 60% /var/lib/perceus
10.1.69.1:/usr/src 138916864 100973856 30886400 77% /usr/src
/dev/sda3 29463920 45412 29121228 1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
3385032528 618268156 2594814332 20% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
55567516032 18964807872 33825871144 36% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
3385032528 120863088 3115145948 4% /usr/local
abem5:/var/spool/torque/server_logs
961428816 184319088 728271888 21% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
73575600 61261056 8516736 88% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 53614096 13358864 81% /var/forward
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
92298352896 73477554108 17414249796 81% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
276891315456 173457691140 93587914676 65% /cfs/scratch
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/u/ac/hdftest/snapshots-opa/log/REPO_LOG_0624Thu
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0624Thu.25757: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0624Thu.25757': No such file or directory
*** launching tests from honest3 ***
TESTHOST is honest1
Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -norepo -configname honest1
Unknown option (-norepo)
Thu Jun 24 00:07:42 CDT 2010
****SYSTEM ERROR honest1: Unknown option (-norepo)
/u/ac/hdftest/snapshots-opa/bin/runtest: line 132: $SYSERRLOG: ambiguous redirect
Usage: runtest [-h] [-debug] [-r<version>] [-all] [-nocvs] [-nodiff] [<host> ...]
-h
print this help page
-debug
turn on debug mode
-r<version>
do runtest for <version>
-all
launch tests for all pre-defined testing hosts
-nocvs
do not do cvs commands
-nodiff
do not do diff commands
-setup
setup the directory structure for snapshot test
-configname <name>
use <name> as hostname in the parsing of the snaptest configure file
<host>
launch tests for <host>
-all and <host> are contradictory and whichever is specified last, is
the one to take effect. If neither are given, do the test for the
local host.
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
Thu Jun 24 00:08:20 CDT 2010
****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest3 ***
Thu Jun 24 00:08:22 CDT 2010
More information about the opa-nightly-tests
