[opa-nightly-tests] jam OPA_Daily_Tests_0615Tue
HDF Tester
hdftest at hdfgroup.org
Tue Jun 15 00:20:26 CDT 2010
*** OPA Tests on 0615Tue ***
Tests Summary
PASSED jam: standard
PASSED liberty: standard
PASSED linew: standard
Tests Time Summary
jam: Ran 1(1/0/0) tests, Grand total test time = 1m 6s
liberty: Ran 1(1/0/0) tests, Grand total test time = 7m 14s
linew: Ran 1(1/0/0) tests, Grand total test time = 9m 7s
jam: Ran 4(0/0/0) hosts, Grand total test time = 10m 2s
Timekeeper log
Timekeeper started at Tue Jun 15 00:10:31 CDT 2010
Timekeeper sleeping for 1800 seconds
Tests Failures
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
Testing all hosts.
opa
00:10:13 up 26 days, 9:36, 19 users, load average: 1.08, 0.97, 0.57
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 4247136 25853056 15% /
/dev/sda1 101086 50385 45482 53% /boot
/dev/sda2 31738420 320916 29779276 2% /tmp
/dev/sda6 31738392 4370456 25729712 15% /var
/dev/sda7 31738392 25837848 4262320 86% /usr
/dev/sda8 124991068 3021672 115517696 3% /var/tmp
/dev/mapper/VolGroup00-home
198351840 8347948 179765532 5% /home
/dev/sde1 565688764 67525688 468964140 13% /scr
/dev/sdc1 961432072 520924492 391669580 58% /mnt/scr1
/dev/sdd1 961432072 467897292 444696780 52% /mnt/hdf
tmpfs 8313860 8 8313852 1% /dev/shm
gumund:/data/ftp 480719072 267658656 188641216 59% /mnt/ftp
gumund:/data/web 480719072 267658656 188641216 59% /mnt/web
pegdub:/mnt/rw-src 288451232 211884576 61914176 78% /mnt/ro-src
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running CVS checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/CVS_LOG_0615Tue
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0615Tue.16094: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0615Tue.16094': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
duty
liberty
Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname linew
Using configname option for -configname
opa
12:10am up 5 day(s), 12:24, 0 users, load average: 1.28, 1.12, 0.65
/ (/dev/dsk/c1t0d0s0 ):77885548 blocks 8282858 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483609 files
/proc (proc ): 0 blocks 29935 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):20661008 blocks 1180997 files
/system/object (objfs ): 0 blocks 2147483486 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):77885548 blocks 8282858 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):77885548 blocks 8282858 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):20661008 blocks 1180997 files
/var/run (swap ):20661008 blocks 1180997 files
/scr (/dev/dsk/c1t1d0s0 ):260766584 blocks 18233161 files
/home (jam:/home ):380007784 blocks 51042015 files
/mnt/hdf (jam:/mnt/hdf ):987069560 blocks 115391209 files
/mnt/scr1 (jam:/mnt/scr1 ):881015112 blocks 118498938 files
/mnt/web (gumund:/mnt/web ):426120792 blocks 60821356 files
/mnt/ftp (gumund:/mnt/ftp ):426120792 blocks 60821356 files
TEST_TYPES=standard
Running standard
Tue Jun 15 00:11:00 CDT 2010
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_142900-12 sun4u sparc SUNW,A70
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: !: not found
SRCDIRNAME is linew
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0615Tue_0011
SNAPCMD is srcdir test clean
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname linew
*** finished standard tests for linew ***
Tue Jun 15 00:19:53 CDT 2010
Total time = 8m 54s
*** finished tests in linew ***
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname jam
opa
00:10:38 up 26 days, 9:36, 19 users, load average: 1.26, 1.02, 0.59
/dev/sda2 31738420 320964 29779228 2% /tmp
/dev/sda6 31738392 4370460 25729708 15% /var
/dev/sdc1 961432072 520924524 391669548 58% /mnt/scr1
TEST_TYPES=standard
Running standard
Tue Jun 15 00:10:48 CDT 2010
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-164.11.1.el5PAE #1 SMP Wed Jan 20 08:16:13 EST 2010 i686 i686 i386 GNU/Linux
SRCDIRNAME is jam
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0615Tue_0010
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname jam
*** finished standard tests for jam ***
Tue Jun 15 00:11:54 CDT 2010
Total time = 1m 6s
*** finished tests in jam ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname duty
Could not chdir to home directory /home/hdftest: Permission denied
/home/hdftest/snapshots-opa: Permission denied.
****SYSTEM ERROR duty: Abnormal exit from runtest ****
Tue Jun 15 00:20:25 CDT 2010
****SYSTEM ERROR duty: runtest command failed ****
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname liberty
opa
12:10AM up 47 days, 15:09, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 86920 380100 19% /
devfs 1 1 0 100% /dev
/dev/aacd0s1g 47047830 30419580 12864424 70% /local_home
/dev/aacd0s1f 12186190 7033652 4177644 63% /usr
/dev/aacd0s1d 1012974 103070 828868 11% /var
/dev/aacd0s1e 507630 62734 404286 13% /var/tmp
jam:/home 198351840 8347948 179765532 4% /home
jam:/mnt/hdf 961432072 467897292 444696780 51% /mnt/hdf
jam:/mnt/scr1 961432072 520924536 391669536 57% /mnt/scr1
gumund:/data/ftp 480719056 267658660 188641196 59% /mnt/ftp
gumund:/data/web 480719056 267658660 188641196 59% /mnt/web
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 146 116420 0% /tmp
TEST_TYPES=standard
Running standard
Tue Jun 15 00:10:53 CDT 2010
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008 sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY amd64
SRCDIRNAME is liberty
/mnt/scr1/SnapTest/snapshots-opa/log/liberty_0615Tue_0010
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname liberty
*** finished standard tests for liberty ***
Tue Jun 15 00:18:07 CDT 2010
Total time = 7m 14s
*** finished tests in liberty ***
More information about the opa-nightly-tests
