[opa-nightly-tests] honest3 OPA_Daily_Tests_0613Sun_FAILED!!!
HDFTEST Community User hdftest at ncsa.uiuc.edu
Sun Jun 13 01:50:51 CDT 2010
*** OPA Tests on 0613Sun ***
   Tests Summary
****FAILED honest1: standard****
   Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time =  1m 27s
honest3: Ran 1(0/0/0) hosts, Grand total test time =  2m 21s
   Timekeeper log
Timekeeper started at Sun Jun 13 01:48:38 CDT 2010
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of honest1: standard
Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0613Sun_0148
Testing memory barriers with scattered array with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:659 in test_barriers_scattered_array()...
***** 3 BARRIERS TESTS FAILED! *****
FAIL: test_barriers
Testing queue sanity                                                   PASSED
Testing multithreaded queue with 2 threads                             PASSED
Testing multithreaded queue (empty queue) with 2 threads               PASSED
Testing multithreaded queue (full queue) with 2 threads                PASSED
Testing multithreaded queue with 4 threads                             PASSED
Testing multithreaded queue (empty queue) with 4 threads               PASSED
Testing multithreaded queue (full queue) with 4 threads                PASSED
Testing multithreaded queue with 10 threads                            PASSED
Testing multithreaded queue (empty queue) with 10 threads              PASSED
Testing multithreaded queue (full queue) with 10 threads               PASSED
Testing multithreaded queue with 100 threads                          *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_queue.c:383 in test_queue_threaded()...
Testing multithreaded queue (empty queue) with 100 threads            /bin/sh: line 1: 26157 Segmentation fault      ${dir}$tst
FAIL: test_queue
2 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Sun Jun 13 01:50:21 CDT 2010 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 01:48:20 up 2 days, 21 min, 13 users,  load average: 1.66, 2.53, 1.81
Filesystem           1K-blocks      Used Available Use% Mounted on
none                   8218016         0   8218016   0% /dev/shm
abem4:/var/lib/perceus/
                      74763440  42191808  28773824  60% /var/lib/perceus
10.1.69.1:/usr/src   138916864  98750688  33109600  75% /usr/src
/dev/sda3             29463920     45208  29121432   1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
                     3385032528 618268148 2594814340  20% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
                     92298352896 72506564560 18385239132  80% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
                     55567516032 18207226316 34583334408  35% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
                     3385032528 120412344 3115596720   4% /usr/local
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
                     276891315456 198443074176 68600994740  75% /cfs/scratch
abem5:/var/spool/torque/server_logs
                     961428816 180710816 731880160  20% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
                      73575600  57986256  11791536  84% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  63714128   3258832  96% /var/forward
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running CVS checkout with output saved in
   /u/ac/hdftest/snapshots-opa/log/CVS_LOG_0613Sun
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0613Sun.24067: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0613Sun.24067': No such file or directory
*** launching tests from honest3 ***
TESTHOST is honest1
    Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -nocvs -configname honest1
Using configname option for -configname
opa
 01:48:44 up 2 days, 20 min, 20 users,  load average: 1.16, 1.15, 1.24
abem2:/var/lib/perceus/
                      74763440  49220592  21745040  70% /var/lib/perceus
/dev/sda2             63013156     53328  62327028   1% /tmp
                     55567516032 18207299016 34583136260  35% /u
                     3385032528 120412304 3115596764   4% /usr/local
                     276891315456 198448097632 68595639056  75% /cfs/scratch
                     961428816 180710912 731880064  20% /var/spool/torque/server_logs
                      73575600  57986752  11791040  84% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  63714160   3258800  96% /var/forward
TEST_TYPES=standard
Running standard
Sun Jun 13 01:48:54 CDT 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 1m 27s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
	****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest3 ***
More information about the opa-nightly-tests mailing list
