[opa-nightly-tests] honest3 OPA_Daily_Tests_0612Sat_FAILED!!!
HDFTEST Community User hdftest at ncsa.uiuc.edu
Sat Jun 12 01:01:17 CDT 2010
*** OPA Tests on 0612Sat ***
   Tests Summary
****FAILED honest1: standard****
   Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time =  1m 23s
honest3: Ran 1(0/0/0) hosts, Grand total test time =  2m 14s
   Timekeeper log
Timekeeper started at Sat Jun 12 00:59:08 CDT 2010
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of honest1: standard
Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0612Sat_0059
Testing queue sanity                                                   PASSED
Testing multithreaded queue with 2 threads                             PASSED
Testing multithreaded queue (empty queue) with 2 threads               PASSED
Testing multithreaded queue (full queue) with 2 threads                PASSED
Testing multithreaded queue with 4 threads                             PASSED
Testing multithreaded queue (empty queue) with 4 threads               PASSED
Testing multithreaded queue (full queue) with 4 threads                PASSED
Testing multithreaded queue with 10 threads                            PASSED
Testing multithreaded queue (empty queue) with 10 threads              PASSED
Testing multithreaded queue (full queue) with 10 threads               PASSED
Testing multithreaded queue with 100 threads                          *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_queue.c:383 in test_queue_threaded()...
Testing multithreaded queue (empty queue) with 100 threads            *FAILED*
Testing multithreaded queue (full queue) with 100 threads             *FAILED*
***** 3 QUEUE TESTS FAILED! *****
FAIL: test_queue
2 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Sat Jun 12 01:00:46 CDT 2010 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 00:58:53 up 23:32, 15 users,  load average: 1.66, 2.51, 1.92
Filesystem           1K-blocks      Used Available Use% Mounted on
none                   8218016         0   8218016   0% /dev/shm
abem4:/var/lib/perceus/
                      74763440  42191600  28774032  60% /var/lib/perceus
10.1.69.1:/usr/src   138916864  98938752  32921536  76% /usr/src
/dev/sda3             29463920     45220  29121420   1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
                     3385032528 618268148 2594814340  20% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
                     92298352896 72493048052 18398755380  80% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
                     55567516032 18561223764 34229124264  36% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
                     3385032528 120339384 3115669660   4% /usr/local
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
                     276891315456 193846378992 73195869380  73% /cfs/scratch
abem5:/var/spool/torque/server_logs
                     961428816 180309120 732281856  20% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
                      73575600  57981216  11796576  84% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  64107584   2865376  96% /var/forward
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running CVS checkout with output saved in
   /u/ac/hdftest/snapshots-opa/log/CVS_LOG_0612Sat
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0612Sat.24559: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0612Sat.24559': No such file or directory
*** launching tests from honest3 ***
TESTHOST is honest1
    Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -nocvs -configname honest1
Using configname option for -configname
opa
 00:59:14 up 23:30, 21 users,  load average: 1.43, 1.58, 1.99
abem2:/var/lib/perceus/
                      74763440  49163248  21802384  70% /var/lib/perceus
/dev/sda2             63013156     53204  62327152   1% /tmp
                     92298352896 72493070924 18398730976  80% /cfs/projects
                     55567516032 18561218624 34229183028  36% /u
                     3385032528 120339404 3115669736   4% /usr/local
                     276891315456 193846609620 73195580584  73% /cfs/scratch
                     961428816 180309184 732281792  20% /var/spool/torque/server_logs
                      73575600  57981424  11796368  84% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  64107624   2865336  96% /var/forward
TEST_TYPES=standard
Running standard
Sat Jun 12 00:59:24 CDT 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 1m 22s
*** finished tests in honest1 ***
Sat Jun 12 01:00:47 CDT 2010
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
	****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest3 ***
More information about the opa-nightly-tests mailing list
