[opa-nightly-tests] honest3 OPA_Daily_Tests_0726Mon_FAILED!!!
HDFTEST Community User
hdftest at ncsa.uiuc.edu
Mon Jul 26 00:53:17 CDT 2010
*** OPA Tests on 0726Mon ***
Tests Summary
****FAILED honest1: standard****
Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time = 1m 22s
honest3: Ran 1(0/0/0) hosts, Grand total test time = 2m 12s
Timekeeper log
Timekeeper started at Mon Jul 26 00:51:10 CDT 2010
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of honest1: standard
Last 50 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0726Mon_0051
Testing pointer compare-and-swap fairness with 100 threads PASSED
Testing integer swap with 100 threads PASSED
Testing pointer swap with 100 threads PASSED
Testing integer LL/SC stack -SKIP-
LL/SC not available
Testing pointer LL/SC stack -SKIP-
LL/SC not available
All primitives tests passed.
PASS: test_primitives
Testing memory barrier sanity PASSED
Testing memory barriers with linear array with 2 threads PASSED
Testing memory barriers with local variables with 2 threads PASSED
Testing memory barriers with scattered array with 2 threads PASSED
Testing memory barriers with linear array with 4 threads PASSED
Testing memory barriers with local variables with 4 threads PASSED
Testing memory barriers with scattered array with 4 threads PASSED
Testing memory barriers with linear array with 10 threads PASSED
Testing memory barriers with local variables with 10 threads PASSED
Testing memory barriers with scattered array with 10 threads PASSED
Testing memory barriers with linear array with 100 threads PASSED
Testing memory barriers with local variables with 100 threads PASSED
Testing memory barriers with scattered array with 100 threads PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity PASSED
Testing multithreaded queue with 2 threads PASSED
Testing multithreaded queue (empty queue) with 2 threads PASSED
Testing multithreaded queue (full queue) with 2 threads PASSED
Testing multithreaded queue with 4 threads PASSED
Testing multithreaded queue (empty queue) with 4 threads PASSED
Testing multithreaded queue (full queue) with 4 threads PASSED
Testing multithreaded queue with 10 threads PASSED
Testing multithreaded queue (empty queue) with 10 threads PASSED
Testing multithreaded queue (full queue) with 10 threads PASSED
Testing multithreaded queue with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_queue.c:383 in test_queue_threaded()...
Testing multithreaded queue (empty queue) with 100 threads /bin/sh: line 1: 11367 Segmentation fault ${dir}$tst
FAIL: test_queue
1 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Mon Jul 26 00:52:47 CDT 2010 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
Testing all hosts.
opa
00:50:55 up 34 days, 6:51, 22 users, load average: 0.02, 0.18, 0.59
Filesystem 1K-blocks Used Available Use% Mounted on
none 8218016 0 8218016 0% /dev/shm
abem4:/var/lib/perceus/
74763440 42374048 28591584 60% /var/lib/perceus
10.1.69.1:/usr/src 138916864 100035648 31824608 76% /usr/src
/dev/sda3 29463920 91272 29075368 1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
3385032528 618527340 2594555148 20% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
55567516032 18916483032 33873434724 36% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
3385032528 123758540 3112250524 4% /usr/local
abem5:/var/spool/torque/server_logs
961428816 194408896 718182080 22% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
73575600 56511248 13266544 81% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 61359936 5613024 92% /var/forward
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
92298352896 78029040852 12862500260 86% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
276891315456 170387387812 96656150316 64% /cfs/scratch
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/u/ac/hdftest/snapshots-opa/log/REPO_LOG_0726Mon
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0726Mon.16503: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0726Mon.16503': No such file or directory
*** launching tests from honest3 ***
TESTHOST is honest1
Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -norepo -configname honest1
Using configname option for -configname
opa
00:51:15 up 34 days, 6:51, 39 users, load average: 1.12, 1.13, 1.10
abem2:/var/lib/perceus/
74763440 49194544 21771088 70% /var/lib/perceus
/dev/sda2 63013156 3779844 58600512 7% /tmp
55567516032 18916486172 33873792480 36% /u
3385032528 123758264 3112250804 4% /usr/local
961428816 194408960 718182016 22% /var/spool/torque/server_logs
73575600 56511264 13266528 81% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 61360008 5612952 92% /var/forward
276891315456 170387358244 96656068968 64% /cfs/scratch
TEST_TYPES=standard
Running standard
Mon Jul 26 00:51:26 CDT 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 1m 21s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest3 ***
More information about the opa-nightly-tests
