[opa-nightly-tests] honest3 OPA_Daily_Tests_0723Fri_FAILED!!!
HDFTEST Community User hdftest at ncsa.uiuc.edu
Fri Jul 23 00:49:42 CDT 2010
*** OPA Tests on 0723Fri ***
   Tests Summary
****FAILED honest1: standard****
   Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time =  1m 27s
honest3: Ran 1(0/0/0) hosts, Grand total test time =  2m 19s
   Timekeeper log
Timekeeper started at Fri Jul 23 00:47:29 CDT 2010
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of honest1: standard
Last 50 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0723Fri_0047
Testing pointer compare-and-swap fairness with 100 threads             PASSED
Testing integer swap with 100 threads                                  PASSED
Testing pointer swap with 100 threads                                  PASSED
Testing integer LL/SC stack                                            -SKIP-
    LL/SC not available
Testing pointer LL/SC stack                                            -SKIP-
    LL/SC not available
All primitives tests passed.
PASS: test_primitives
Testing memory barrier sanity                                          PASSED
Testing memory barriers with linear array with 2 threads               PASSED
Testing memory barriers with local variables with 2 threads            PASSED
Testing memory barriers with scattered array with 2 threads            PASSED
Testing memory barriers with linear array with 4 threads               PASSED
Testing memory barriers with local variables with 4 threads            PASSED
Testing memory barriers with scattered array with 4 threads            PASSED
Testing memory barriers with linear array with 10 threads              PASSED
Testing memory barriers with local variables with 10 threads           PASSED
Testing memory barriers with scattered array with 10 threads           PASSED
Testing memory barriers with linear array with 100 threads             PASSED
Testing memory barriers with local variables with 100 threads          PASSED
Testing memory barriers with scattered array with 100 threads          PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity                                                   PASSED
Testing multithreaded queue with 2 threads                             PASSED
Testing multithreaded queue (empty queue) with 2 threads               PASSED
Testing multithreaded queue (full queue) with 2 threads                PASSED
Testing multithreaded queue with 4 threads                             PASSED
Testing multithreaded queue (empty queue) with 4 threads               PASSED
Testing multithreaded queue (full queue) with 4 threads                PASSED
Testing multithreaded queue with 10 threads                            PASSED
Testing multithreaded queue (empty queue) with 10 threads              PASSED
Testing multithreaded queue (full queue) with 10 threads               PASSED
Testing multithreaded queue with 100 threads                          *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_queue.c:383 in test_queue_threaded()...
Testing multithreaded queue (empty queue) with 100 threads            /bin/sh: line 1: 14363 Segmentation fault      ${dir}$tst
FAIL: test_queue
1 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Fri Jul 23 00:49:11 CDT 2010 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 00:47:12 up 31 days,  6:47, 29 users,  load average: 1.15, 1.29, 1.65
Filesystem           1K-blocks      Used Available Use% Mounted on
none                   8218016         0   8218016   0% /dev/shm
abem4:/var/lib/perceus/
                      74763440  42390656  28574976  60% /var/lib/perceus
10.1.69.1:/usr/src   138916864 100114176  31746080  76% /usr/src
/dev/sda3             29463920     91260  29075380   1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
                     3385032528 618527340 2594555148  20% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
                     55567516032 18858224576 33931708940  36% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
                     3385032528 123666168 3112342860   4% /usr/local
abem5:/var/spool/torque/server_logs
                     961428816 193515248 719075728  22% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
                      73575600  56731920  13045872  82% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  61910744   5062216  93% /var/forward
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
                     92298352896 78026549128 12864885252  86% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
                     276891315456 168323804680 98716261308  64% /cfs/scratch
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /u/ac/hdftest/snapshots-opa/log/REPO_LOG_0723Fri
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0723Fri.10553: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0723Fri.10553': No such file or directory
*** launching tests from honest3 ***
TESTHOST is honest1
    Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -norepo -configname honest1
Using configname option for -configname
opa
 00:47:34 up 31 days,  6:47, 46 users,  load average: 0.93, 0.79, 0.62
abem2:/var/lib/perceus/
                      74763440  49409168  21556464  70% /var/lib/perceus
/dev/sda2             63013156   3779820  58600536   7% /tmp
                     55567516032 18858225480 33931698060  36% /u
                     3385032528 123666164 3112342868   4% /usr/local
                     961428816 193515344 719075632  22% /var/spool/torque/server_logs
                      73575600  56731968  13045824  82% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  61910800   5062160  93% /var/forward
                     92298352896 78026550128 12864884252  86% /cfs/projects
                     276891315456 168325097504 98714861324  64% /cfs/scratch
TEST_TYPES=standard
Running standard
Fri Jul 23 00:47:45 CDT 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 1m 26s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
	Fri Jul 23 00:49:41 CDT 2010
	****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest3 ***
More information about the opa-nightly-tests mailing list
