[opa-nightly-tests] honest3 OPA_Daily_Tests_0721Wed_FAILED!!!
HDFTEST Community User
hdftest at ncsa.uiuc.edu
Wed Jul 21 00:37:40 CDT 2010
*** OPA Tests on 0721Wed ***
Tests Summary
****FAILED honest1: standard****
Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time = 8m 42s
honest3: Ran 1(0/0/0) hosts, Grand total test time = 9m 34s
Timekeeper log
Timekeeper started at Wed Jul 21 00:28:12 CDT 2010
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of honest1: standard
Last 50 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0721Wed_0028
LL/SC not available
Testing pointer LL/SC stack -SKIP-
LL/SC not available
All primitives tests passed.
PASS: test_primitives
Testing memory barrier sanity PASSED
Testing memory barriers with linear array with 2 threads PASSED
Testing memory barriers with local variables with 2 threads PASSED
Testing memory barriers with scattered array with 2 threads PASSED
Testing memory barriers with linear array with 4 threads PASSED
Testing memory barriers with local variables with 4 threads PASSED
Testing memory barriers with scattered array with 4 threads PASSED
Testing memory barriers with linear array with 10 threads PASSED
Testing memory barriers with local variables with 10 threads PASSED
Testing memory barriers with scattered array with 10 threads PASSED
Testing memory barriers with linear array with 100 threads PASSED
Testing memory barriers with local variables with 100 threads PASSED
Testing memory barriers with scattered array with 100 threads PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity PASSED
Testing multithreaded queue with 2 threads PASSED
Testing multithreaded queue (empty queue) with 2 threads PASSED
Testing multithreaded queue (full queue) with 2 threads PASSED
Testing multithreaded queue with 4 threads PASSED
Testing multithreaded queue (empty queue) with 4 threads PASSED
Testing multithreaded queue (full queue) with 4 threads PASSED
Testing multithreaded queue with 10 threads PASSED
Testing multithreaded queue (empty queue) with 10 threads PASSED
Testing multithreaded queue (full queue) with 10 threads PASSED
Testing multithreaded queue with 100 threads PASSED
Testing multithreaded queue (empty queue) with 100 threads PASSED
Testing multithreaded queue (full queue) with 100 threads Incorrect number of elements dequeued: 4817035 Expected: 4950000
*FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_queue.c:399 in test_queue_threaded()...
Unexpected return from 7 threads
***** 1 QUEUE TEST FAILED! *****
FAIL: test_queue
1 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Wed Jul 21 00:37:09 CDT 2010 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
Testing all hosts.
opa
00:27:56 up 29 days, 6:28, 34 users, load average: 0.09, 0.24, 0.64
Filesystem 1K-blocks Used Available Use% Mounted on
none 8218016 0 8218016 0% /dev/shm
abem4:/var/lib/perceus/
74763440 42390304 28575328 60% /var/lib/perceus
10.1.69.1:/usr/src 138916864 100111776 31748512 76% /usr/src
/dev/sda3 29463920 75064 29091576 1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
3385032528 618343656 2594738832 20% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
55567516032 19002376028 33787613396 36% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
3385032528 123621204 3112387852 4% /usr/local
abem5:/var/spool/torque/server_logs
961428816 192824784 719766192 22% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
73575600 56580368 13197424 82% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 61762976 5209984 93% /var/forward
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
92298352896 77776774868 13114796540 86% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
276891315456 165960198304 101080181128 63% /cfs/scratch
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/u/ac/hdftest/snapshots-opa/log/REPO_LOG_0721Wed
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0721Wed.3429: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0721Wed.3429': No such file or directory
*** launching tests from honest3 ***
TESTHOST is honest1
Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -norepo -configname honest1
Using configname option for -configname
opa
00:28:18 up 29 days, 6:28, 43 users, load average: 2.89, 2.83, 2.83
abem2:/var/lib/perceus/
74763440 49291456 21674176 70% /var/lib/perceus
/dev/sda2 63013156 3776824 58603532 7% /tmp
55567516032 19002553752 33787349472 36% /u
3385032528 123621204 3112387848 4% /usr/local
961428816 192824864 719766112 22% /var/spool/torque/server_logs
pop:/var/forward 70557056 61763040 5209920 93% /var/forward
92298352896 77776793428 13114744780 86% /cfs/projects
276891315456 165961184164 101079312348 63% /cfs/scratch
TEST_TYPES=standard
Running standard
Wed Jul 21 00:28:29 CDT 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 8m 40s
*** finished tests in honest1 ***
Wed Jul 21 00:37:10 CDT 2010
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest3 ***
More information about the opa-nightly-tests
