[opa-nightly-tests] honest3 OPA_Daily_Tests_0720Tue_FAILED!!!
HDFTEST Community User
hdftest at ncsa.uiuc.edu
Tue Jul 20 00:38:05 CDT 2010
*** OPA Tests on 0720Tue ***
Tests Summary
****FAILED honest1: standard****
Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time = 1m 31s
honest3: Ran 1(0/0/0) hosts, Grand total test time = 2m 24s
Timekeeper log
Timekeeper started at Tue Jul 20 00:35:46 CDT 2010
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of honest1: standard
Last 50 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0720Tue_0036
Testing pointer swap with 100 threads PASSED
Testing integer LL/SC stack -SKIP-
LL/SC not available
Testing pointer LL/SC stack -SKIP-
LL/SC not available
All primitives tests passed.
PASS: test_primitives
Testing memory barrier sanity PASSED
Testing memory barriers with linear array with 2 threads PASSED
Testing memory barriers with local variables with 2 threads PASSED
Testing memory barriers with scattered array with 2 threads PASSED
Testing memory barriers with linear array with 4 threads PASSED
Testing memory barriers with local variables with 4 threads PASSED
Testing memory barriers with scattered array with 4 threads PASSED
Testing memory barriers with linear array with 10 threads PASSED
Testing memory barriers with local variables with 10 threads PASSED
Testing memory barriers with scattered array with 10 threads PASSED
Testing memory barriers with linear array with 100 threads PASSED
Testing memory barriers with local variables with 100 threads PASSED
Testing memory barriers with scattered array with 100 threads PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity PASSED
Testing multithreaded queue with 2 threads PASSED
Testing multithreaded queue (empty queue) with 2 threads PASSED
Testing multithreaded queue (full queue) with 2 threads PASSED
Testing multithreaded queue with 4 threads PASSED
Testing multithreaded queue (empty queue) with 4 threads PASSED
Testing multithreaded queue (full queue) with 4 threads PASSED
Testing multithreaded queue with 10 threads PASSED
Testing multithreaded queue (empty queue) with 10 threads PASSED
Testing multithreaded queue (full queue) with 10 threads PASSED
Testing multithreaded queue with 100 threads PASSED
Testing multithreaded queue (empty queue) with 100 threads PASSED
Testing multithreaded queue (full queue) with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_queue.c:383 in test_queue_threaded()...
***** 1 QUEUE TEST FAILED! *****
FAIL: test_queue
1 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Tue Jul 20 00:37:32 CDT 2010 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
Testing all hosts.
opa
00:35:31 up 28 days, 6:35, 39 users, load average: 0.09, 0.31, 0.69
Filesystem 1K-blocks Used Available Use% Mounted on
none 8218016 0 8218016 0% /dev/shm
abem4:/var/lib/perceus/
74763440 42390048 28575584 60% /var/lib/perceus
10.1.69.1:/usr/src 138916864 100111040 31749248 76% /usr/src
/dev/sda3 29463920 75076 29091564 1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
3385032528 618408116 2594674372 20% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
55567516032 19055655220 33734125576 37% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
3385032528 123589800 3112419240 4% /usr/local
abem5:/var/spool/torque/server_logs
961428816 192523360 720067616 22% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
73575600 56595472 13182320 82% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 60297120 6675840 91% /var/forward
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
92298352896 77326381556 13565332976 86% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
276891315456 166195252188 100845993508 63% /cfs/scratch
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/u/ac/hdftest/snapshots-opa/log/REPO_LOG_0720Tue
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0720Tue.10815: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0720Tue.10815': No such file or directory
*** launching tests from honest3 ***
TESTHOST is honest1
Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -norepo -configname honest1
Using configname option for -configname
opa
00:35:51 up 28 days, 6:36, 39 users, load average: 0.06, 0.04, 0.00
abem2:/var/lib/perceus/
74763440 49233264 21732368 70% /var/lib/perceus
/dev/sda2 63013156 3776720 58603636 7% /tmp
55567516032 19055658536 33734192408 37% /u
3385032528 123589804 3112419240 4% /usr/local
961428816 192523424 720067568 22% /var/spool/torque/server_logs
73575600 56595456 13182336 82% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 60297160 6675800 91% /var/forward
92298352896 77326381792 13565357432 86% /cfs/projects
276891315456 166195364612 100846298048 63% /cfs/scratch
TEST_TYPES=standard
Running standard
Tue Jul 20 00:36:02 CDT 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 1m 30s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest3 ***
More information about the opa-nightly-tests
