[opa-nightly-tests] honest3 OPA_Daily_Tests_0715Thu_FAILED!!!
HDFTEST Community User hdftest at ncsa.uiuc.edu
Thu Jul 15 00:40:46 CDT 2010
*** OPA Tests on 0715Thu ***
   Tests Summary
****FAILED honest1: standard****
   Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time =  1m 24s
honest3: Ran 1(0/0/0) hosts, Grand total test time =  2m 29s
   Timekeeper log
Timekeeper started at Thu Jul 15 00:38:36 CDT 2010
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of honest1: standard
Last 50 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0715Thu_0038
Testing integer swap with 100 threads                                  PASSED
Testing pointer swap with 100 threads                                  PASSED
Testing integer LL/SC stack                                            -SKIP-
    LL/SC not available
Testing pointer LL/SC stack                                            -SKIP-
    LL/SC not available
All primitives tests passed.
PASS: test_primitives
Testing memory barrier sanity                                          PASSED
Testing memory barriers with linear array with 2 threads               PASSED
Testing memory barriers with local variables with 2 threads            PASSED
Testing memory barriers with scattered array with 2 threads            PASSED
Testing memory barriers with linear array with 4 threads               PASSED
Testing memory barriers with local variables with 4 threads            PASSED
Testing memory barriers with scattered array with 4 threads            PASSED
Testing memory barriers with linear array with 10 threads              PASSED
Testing memory barriers with local variables with 10 threads           PASSED
Testing memory barriers with scattered array with 10 threads           PASSED
Testing memory barriers with linear array with 100 threads             PASSED
Testing memory barriers with local variables with 100 threads          PASSED
Testing memory barriers with scattered array with 100 threads          PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity                                                   PASSED
Testing multithreaded queue with 2 threads                             PASSED
Testing multithreaded queue (empty queue) with 2 threads               PASSED
Testing multithreaded queue (full queue) with 2 threads                PASSED
Testing multithreaded queue with 4 threads                             PASSED
Testing multithreaded queue (empty queue) with 4 threads               PASSED
Testing multithreaded queue (full queue) with 4 threads                PASSED
Testing multithreaded queue with 10 threads                            PASSED
Testing multithreaded queue (empty queue) with 10 threads              PASSED
Testing multithreaded queue (full queue) with 10 threads               PASSED
Testing multithreaded queue with 100 threads                          *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_queue.c:383 in test_queue_threaded()...
Testing multithreaded queue (empty queue) with 100 threads            *FAILED*
/bin/sh: line 1:  6987 Segmentation fault      ${dir}$tst
FAIL: test_queue
1 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Thu Jul 15 00:40:15 CDT 2010 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 00:38:06 up 23 days,  6:38, 24 users,  load average: 0.01, 0.34, 1.06
Filesystem           1K-blocks      Used Available Use% Mounted on
none                   8218016         0   8218016   0% /dev/shm
abem4:/var/lib/perceus/
                      74763440  42390784  28574848  60% /var/lib/perceus
10.1.69.1:/usr/src   138916864 100581152  31279104  77% /usr/src
/dev/sda3             29463920     74556  29092084   1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
                     3385032528 618408116 2594674372  20% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
                     55567516032 18996336736 33793961712  36% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
                     3385032528 123454148 3112554900   4% /usr/local
abem5:/var/spool/torque/server_logs
                     961428816 190949248 721641728  21% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
                      73575600  56271008  13506784  81% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  60176976   6795984  90% /var/forward
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
                     92298352896 76593648912 14298127140  85% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
                     276891315456 166038000804 100997974536  63% /cfs/scratch
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /u/ac/hdftest/snapshots-opa/log/REPO_LOG_0715Thu
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0715Thu.25347: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0715Thu.25347': No such file or directory
*** launching tests from honest3 ***
TESTHOST is honest1
    Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -norepo -configname honest1
Using configname option for -configname
opa
 00:38:41 up 23 days,  6:39, 47 users,  load average: 1.18, 1.26, 1.41
abem2:/var/lib/perceus/
                      74763440  49333664  21631968  70% /var/lib/perceus
10.1.69.1:/usr/src   138916864 100581440  31278816  77% /usr/src
/dev/sda2             63013156   5513864  56866492   9% /tmp
                     55567516032 18996331932 33793963872  36% /u
                     961428816 190949376 721641616  21% /var/spool/torque/server_logs
                      73575600  56271120  13506672  81% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  60177128   6795832  90% /var/forward
                     92298352896 76594811188 14296951480  85% /cfs/projects
                     276891315456 166045899252 100992095032  63% /cfs/scratch
TEST_TYPES=standard
Running standard
Thu Jul 15 00:38:52 CDT 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 1m 23s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
	****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest3 ***
More information about the opa-nightly-tests mailing list
