[opa-nightly-tests] honest3 OPA_Daily_Tests_0706Tue_FAILED!!!
HDFTEST Community User hdftest at ncsa.uiuc.edu
Tue Jul 6 01:08:32 CDT 2010
*** OPA Tests on 0706Tue ***
   Tests Summary
****FAILED honest1: standard****
   Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time =  1m 17s
honest3: Ran 1(0/0/0) hosts, Grand total test time =  2m 36s
   Timekeeper log
Timekeeper started at Tue Jul  6 01:06:13 CDT 2010
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of honest1: standard
Last 50 lines of /u/ac/hdftest/snapshots-opa/log/honest1_0706Tue_0106
        at /u/ac/hdftest/snapshots-opa/current/test/test_primitives.c:774 in test_threaded_add()...
Testing incr and decr with 99 threads                                     Unexpected load: 4294967346 is not a multiple of 4294967295
    Unexpected load: 46 is not a multiple of 4294967295
*FAILED*
*** glibc detected *** corrupted double-linked list: 0x000000000050b0f0 ***
        at /u/ac/hdftest/snapshots-opa/current/test/test_primitives.c:941 in test_threaded_incr_decr()...
/bin/sh: line 1: 17294 Aborted                 ${dir}$tst
FAIL: test_primitives
Testing memory barrier sanity                                          PASSED
Testing memory barriers with linear array with 2 threads               PASSED
Testing memory barriers with local variables with 2 threads            PASSED
Testing memory barriers with scattered array with 2 threads            PASSED
Testing memory barriers with linear array with 4 threads               PASSED
Testing memory barriers with local variables with 4 threads            PASSED
Testing memory barriers with scattered array with 4 threads            PASSED
Testing memory barriers with linear array with 10 threads              PASSED
Testing memory barriers with local variables with 10 threads           PASSED
Testing memory barriers with scattered array with 10 threads           PASSED
Testing memory barriers with linear array with 100 threads             PASSED
Testing memory barriers with local variables with 100 threads          PASSED
Testing memory barriers with scattered array with 100 threads          PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity                                                   PASSED
Testing multithreaded queue with 2 threads                             PASSED
Testing multithreaded queue (empty queue) with 2 threads               PASSED
Testing multithreaded queue (full queue) with 2 threads                PASSED
Testing multithreaded queue with 4 threads                             PASSED
Testing multithreaded queue (empty queue) with 4 threads               PASSED
Testing multithreaded queue (full queue) with 4 threads                PASSED
Testing multithreaded queue with 10 threads                            PASSED
Testing multithreaded queue (empty queue) with 10 threads              PASSED
Testing multithreaded queue (full queue) with 10 threads               PASSED
Testing multithreaded queue with 100 threads                           PASSED
Testing multithreaded queue (empty queue) with 100 threads             PASSED
Testing multithreaded queue (full queue) with 100 threads              PASSED
All queue tests passed.
PASS: test_queue
1 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Tue Jul  6 01:07:47 CDT 2010 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 01:05:45 up 14 days,  7:06, 29 users,  load average: 0.02, 0.25, 0.75
Filesystem           1K-blocks      Used Available Use% Mounted on
none                   8218016         0   8218016   0% /dev/shm
abem4:/var/lib/perceus/
                      74763440  42411728  28553904  60% /var/lib/perceus
10.1.69.1:/usr/src   138916864 100478176  31382112  77% /usr/src
/dev/sda3             29463920     49188  29117452   1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
                     3385032528 618408108 2594674380  20% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
                     55567516032 18730830492 34059688568  36% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
                     3385032528 121131432 3114877656   4% /usr/local
abem5:/var/spool/torque/server_logs
                     961428816 187593888 724997088  21% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
                      73575600  55972976  13804816  81% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  55751976  11220984  84% /var/forward
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
                     92298352896 73946200784 16945565712  82% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
                     276891315456 177226784524 89813290580  67% /cfs/scratch
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /u/ac/hdftest/snapshots-opa/log/REPO_LOG_0706Tue
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.0706Tue.23410: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.0706Tue.23410': No such file or directory
Tue Jul  6 01:06:12 CDT 2010
*** launching tests from honest3 ***
TESTHOST is honest1
    Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -norepo -configname honest1
Using configname option for -configname
opa
 01:06:20 up 14 days,  7:06, 39 users,  load average: 0.26, 0.28, 0.31
abem2:/var/lib/perceus/
                      74763440  49212912  21752720  70% /var/lib/perceus
/dev/sda2             63013156   5489324  56891032   9% /tmp
                     55567516032 18728670004 34061906008  36% /u
                     3385032528 121131064 3114878044   4% /usr/local
                     961428816 187594032 724996960  21% /var/spool/torque/server_logs
                      73575600  55973152  13804640  81% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  55752128  11220832  84% /var/forward
                     276891315456 177228138380 89811929648  67% /cfs/scratch
TEST_TYPES=standard
Running standard
Tue Jul  6 01:06:31 CDT 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 1m 16s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
	Tue Jul  6 01:08:26 CDT 2010
	****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest3 ***
Tue Jul  6 01:08:31 CDT 2010
More information about the opa-nightly-tests mailing list
