[opa-nightly-tests] honest3 OPA_Daily_Tests_1217Fri_FAILED!!!
HDFTEST Community User hdftest at ncsa.uiuc.edu
Fri Dec 17 03:20:48 CST 2010
*** OPA Tests on 1217Fri ***
   Tests Summary
****FAILED honest1: standard****
   Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time =  1m 9s
honest3: Ran 1(0/0/0) hosts, Grand total test time =  2m 4s
   Timekeeper log
Timekeeper started at Fri Dec 17 03:18:53 CST 2010
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of honest1: standard
Last 50 lines of /u/ac/hdftest/snapshots-opa/log/honest1_1217Fri_0319
Testing pointer load/store with 100 threads                           /bin/sh: line 1: 28209 Segmentation fault      ${dir}$tst
FAIL: test_primitives
Testing memory barrier sanity                                          PASSED
Testing memory barriers with linear array with 2 threads               PASSED
Testing memory barriers with local variables with 2 threads            PASSED
Testing memory barriers with scattered array with 2 threads            PASSED
Testing memory barriers with linear array with 4 threads               PASSED
Testing memory barriers with local variables with 4 threads            PASSED
Testing memory barriers with scattered array with 4 threads            PASSED
Testing memory barriers with linear array with 10 threads              PASSED
Testing memory barriers with local variables with 10 threads           PASSED
Testing memory barriers with scattered array with 10 threads           PASSED
Testing memory barriers with linear array with 100 threads            *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:323 in test_barriers_linear_array()...
Testing memory barriers with local variables with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:599 in test_barriers_variables()...
Testing memory barriers with scattered array with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:714 in test_barriers_scattered_array()...
***** 3 BARRIERS TESTS FAILED! *****
FAIL: test_barriers
Testing queue sanity                                                   PASSED
Testing multithreaded queue with 2 threads                             PASSED
Testing multithreaded queue (empty queue) with 2 threads               PASSED
Testing multithreaded queue (full queue) with 2 threads                PASSED
Testing multithreaded queue with 4 threads                             PASSED
Testing multithreaded queue (empty queue) with 4 threads               PASSED
Testing multithreaded queue (full queue) with 4 threads                PASSED
Testing multithreaded queue with 10 threads                            PASSED
Testing multithreaded queue (empty queue) with 10 threads              PASSED
Testing multithreaded queue (full queue) with 10 threads               PASSED
Testing multithreaded queue with 100 threads                          *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_queue.c:383 in test_queue_threaded()...
Testing multithreaded queue (empty queue) with 100 threads            *FAILED*
Testing multithreaded queue (full queue) with 100 threads             *FAILED*
***** 3 QUEUE TESTS FAILED! *****
FAIL: test_queue
3 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Fri Dec 17 03:20:18 CST 2010 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 03:18:34 up 43 days, 12:11, 37 users,  load average: 0.00, 0.46, 1.41
Filesystem           1K-blocks      Used Available Use% Mounted on
none                   8218016         0   8218016   0% /dev/shm
abem4:/var/lib/perceus/
                      74763440  42217776  28747856  60% /var/lib/perceus
10.1.69.1:/usr/src   138916864 100296928  31563360  77% /usr/src
/dev/sda3             29463920     47996  29118644   1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
                     3385032528 685519524 2527562964  22% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
                     55567516032 21882337104 30906805368  42% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
                     3385032528 139551824 3096457284   5% /usr/local
abem5:/var/spool/torque/server_logs
                     961428816  37672368 874918608   5% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
                      73575600  61453328   8324464  89% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  64853728   2119232  97% /var/forward
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
                     276891315456 182985523184 84056319428  69% /cfs/scratch
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
                     92298352896 82176118744 8715670580  91% /cfs/projects
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
   /u/ac/hdftest/snapshots-opa/log/REPO_LOG_1217Fri
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.1217Fri.31008: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.1217Fri.31008': No such file or directory
*** launching tests from honest3 ***
TESTHOST is honest1
    Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -norepo -configname honest1
Using configname option for -configname
opa
 03:18:59 up 4 days, 15:39, 17 users,  load average: 0.18, 0.54, 1.39
abem2:/var/lib/perceus/
                      74763440  49221520  21744112  70% /var/lib/perceus
/dev/sda2             63013156     59256  62321100   1% /tmp
                     92298352896 82176118744 8715670584  91% /cfs/projects
                     55567516032 21882337048 30906811400  42% /u
                     3385032528 139551816 3096457292   5% /usr/local
                     276891315456 182989424536 84052679180  69% /cfs/scratch
                     961428816  37672480 874918496   5% /var/spool/torque/server_logs
                      73575600  61453424   8324368  89% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  64853784   2119176  97% /var/forward
TEST_TYPES=standard
Running standard
Fri Dec 17 03:19:09 CST 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #8 SMP Thu Sep 16 17:22:55 CDT 2010 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 1m 9s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
	****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest3 ***
More information about the opa-nightly-tests mailing list
