[opa-nightly-tests] honest3 OPA_Daily_Tests_1201Wed_FAILED!!!
HDFTEST Community User
hdftest at ncsa.uiuc.edu
Wed Dec 1 02:15:52 CST 2010
*** OPA Tests on 1201Wed ***
Tests Summary
****FAILED honest1: standard****
Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time = 1m 35s
honest3: Ran 1(0/0/0) hosts, Grand total test time = 2m 29s
Timekeeper log
Timekeeper started at Wed Dec 1 02:13:32 CST 2010
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of honest1: standard
Last 50 lines of /u/ac/hdftest/snapshots-opa/log/honest1_1201Wed_0213
Testing pointer swap with 100 threads PASSED
Testing integer LL/SC stack -SKIP-
LL/SC not available
Testing pointer LL/SC stack -SKIP-
LL/SC not available
All primitives tests passed.
PASS: test_primitives
Testing memory barrier sanity PASSED
Testing memory barriers with linear array with 2 threads PASSED
Testing memory barriers with local variables with 2 threads PASSED
Testing memory barriers with scattered array with 2 threads PASSED
Testing memory barriers with linear array with 4 threads PASSED
Testing memory barriers with local variables with 4 threads PASSED
Testing memory barriers with scattered array with 4 threads PASSED
Testing memory barriers with linear array with 10 threads PASSED
Testing memory barriers with local variables with 10 threads PASSED
Testing memory barriers with scattered array with 10 threads PASSED
Testing memory barriers with linear array with 100 threads PASSED
Testing memory barriers with local variables with 100 threads PASSED
Testing memory barriers with scattered array with 100 threads PASSED
All barriers tests passed.
PASS: test_barriers
Testing queue sanity PASSED
Testing multithreaded queue with 2 threads PASSED
Testing multithreaded queue (empty queue) with 2 threads PASSED
Testing multithreaded queue (full queue) with 2 threads PASSED
Testing multithreaded queue with 4 threads PASSED
Testing multithreaded queue (empty queue) with 4 threads PASSED
Testing multithreaded queue (full queue) with 4 threads PASSED
Testing multithreaded queue with 10 threads PASSED
Testing multithreaded queue (empty queue) with 10 threads PASSED
Testing multithreaded queue (full queue) with 10 threads PASSED
Testing multithreaded queue with 100 threads PASSED
Testing multithreaded queue (empty queue) with 100 threads PASSED
Testing multithreaded queue (full queue) with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_queue.c:383 in test_queue_threaded()...
***** 1 QUEUE TEST FAILED! *****
FAIL: test_queue
1 of 4 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Wed Dec 1 02:15:22 CST 2010 =====
Dumping done
Runtest did not exit normally.
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
Testing all hosts.
opa
02:13:13 up 27 days, 11:05, 24 users, load average: 0.03, 0.33, 1.49
Filesystem 1K-blocks Used Available Use% Mounted on
none 8218016 0 8218016 0% /dev/shm
abem4:/var/lib/perceus/
74763440 42841472 28124160 61% /var/lib/perceus
10.1.69.1:/usr/src 138916864 100765536 31094720 77% /usr/src
/dev/sda3 29463920 47892 29118748 1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
3385032528 670131576 2542950912 21% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
55567516032 21333168972 31457263260 41% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
3385032528 139163672 3096845292 5% /usr/local
abem5:/var/spool/torque/server_logs
961428816 37258704 875332272 5% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
73575600 60920992 8856800 88% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 62037024 4935936 93% /var/forward
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
276891315456 145956025684 121085305596 55% /cfs/scratch
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
92298352896 76496790680 14394968808 85% /cfs/projects
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running source repository checkout with output saved in
/u/ac/hdftest/snapshots-opa/log/REPO_LOG_1201Wed
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.1201Wed.14501: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.1201Wed.14501': No such file or directory
*** launching tests from honest3 ***
TESTHOST is honest1
Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -norepo -configname honest1
Using configname option for -configname
opa
02:13:37 up 10 days, 5:47, 26 users, load average: 0.70, 0.81, 0.61
abem2:/var/lib/perceus/
74763440 49592848 21372784 70% /var/lib/perceus
/dev/sda2 63013156 55040 62325316 1% /tmp
92298352896 76497410356 14394375928 85% /cfs/projects
55567516032 21333166560 31457263100 41% /u
3385032528 139163664 3096845300 5% /usr/local
276891315456 145954691044 121086062112 55% /cfs/scratch
961428816 37258784 875332192 5% /var/spool/torque/server_logs
73575600 60921024 8856768 88% /var/spool/torque/server_priv/accounting
pop:/var/forward 70557056 62037040 4935920 93% /var/forward
TEST_TYPES=standard
Running standard
Wed Dec 1 02:13:48 CST 2010
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #8 SMP Thu Sep 16 17:22:55 CDT 2010 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 1m 34s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest3 ***
More information about the opa-nightly-tests
