[opa-nightly-tests] Fwd: honest3 OPA_Daily_Tests_0817Tue_FAILED!!!
Larry Knox lrknox at hdfgroup.org
Thu Aug 19 15:22:01 CDT 2010
Ah.  I can add the "libtoolize" and "reconfigure -vif" commands to our
scripts that update the source, and since all of our test platforms are
syncing with this copy of the source, just leave the files in the source on
jam without checking them in.
Larry
-----Original Message-----
Sent: Thursday, August 19, 2010 2:54 PM
To: lrknox at hdfgroup.org
Cc: 'Mike McGreevy'; 'Quincey Koziol'; opa-nightly-tests at lists.mcs.anl.gov
Subject: Re: [opa-nightly-tests] Fwd: honest3
On Aug 19, 2010, at 2:44 PM CDT, Larry Knox wrote:
> I still got the message about adding AC_PROG_LIBTOOL to configure.in, but
> consulting Mike learned that I needed to run "libtoolize" before
"autoreconf
> -vif".
This might indicate that your automake and libtool packages are installed in
different directories.  "autoreconf -vif" is supposed to take care of
running libtoolize for you.  But due to arcane and extremely boring reasons,
autoreconf doesn't do this correctly when libtool and automake live
separately.  You are supposed to be able to pass "-I
/path/to/aclocal/macro/dir" to autoreconf as well, but it doesn't work
reliably across various versions of the autotools.
> This works and the tests pass.  However, the following files are generated
> by running "libtoolize":
> ?       confdb/ltsugar.m4
> ?       confdb/libtool.m4
> ?       confdb/ltversion.m4
> ?       confdb/lt~obsolete.m4
> ?       confdb/config.guess
> ?       confdb/ltoptions.m4
> ?       confdb/config.sub
> ?       confdb/ltmain.sh
> These all seem to be necessary for the updated configure.  Do we check
them
> in, or does someone know a way around to avoid that?
No, don't check them in.  These would be distributed with a source tarball,
but shouldn't live in source control (at least, under our current autotools
usage model).  The nightly testing script should be running "autoreconf
-vif" nightly instead to incorporate any new configure/automake updates.
However, the autoreconf can happen on any machine single machine, unlike
configure, provided that the source tree is then synched up on all the
various testing platforms.
-Dave
More information about the opa-nightly-tests mailing list
