[opa-nightly-tests] co-login OPA_Daily_Tests_0511Mon_FAILED!!!
HDF Tester
hdftest at ncsa.uiuc.edu
Mon May 11 02:33:21 CDT 2009
*** OPA Tests on 0511Mon ***
Tests Summary
****FAILED co-login: standard****
Tests Time Summary
co-login: Ran 1(0/1/0) tests, Grand total test time = 0m 33s
Timekeeper log
Tests Failures
Dumping logfile of co-login: standard
Last 30 lines of /u/ac/hdftest/snapshots-opa/log/co-login_0511Mon_0232
checking for pthread.h... yes
checking atomic.h usability... no
checking atomic.h presence... no
checking for atomic.h... no
checking intrin.h usability... no
checking intrin.h presence... no
checking for intrin.h... no
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking for C/C++ restrict keyword... __restrict
checking for inline... inline
checking for pthread_create in -lpthread... yes
checking if 100 threads can be run at once... no
checking size of void *... 8
checking size of int... 4
checking whether __attribute__ allowed... yes
checking whether __attribute__((format)) allowed... yes
checking if compiler rejects bogus asm statements... yes
checking for support for gcc x86/x86_64 bit primitives... no
checking for support for gcc ia64 primitives... no
checking for support for gcc PowerPC atomics... no
checking for support for gcc SiCortex atomics... no
checking for support for gcc atomic intrinsics... no
checking for support for Windows NT atomic intrinsics... no
checking for support for Sun atomic operations library... no
configure: error: No native supported atomic primitives were detected. You can
use "--with-atomic-primitives=no" to emulate the atomic primitives using locks,
but note that doing this will result in a substantial performance penalty.
===== Exit bin/snapshot with status=1: Mon May 11 02:33:20 CDT 2009 =====
Dumping done
Watchers List
More information about the opa-nightly-tests
