[opa-nightly-tests] co-login OPA_Daily_Tests_0501Fri_FAILED!!!
HDF Tester hdftest at ncsa.uiuc.edu
Fri May 1 02:48:58 CDT 2009
*** OPA Tests on 0501Fri ***
   Tests Summary
****FAILED co-login: standard****
   Tests Time Summary
co-login: Ran 1(0/1/0) tests, Grand total test time =  1m 27s
   Timekeeper log
   Tests Failures
Dumping logfile of co-login: standard
Last 30 lines of /u/ac/hdftest/snapshots-opa/log/co-login_0501Fri_0247
Testing fetch and add return values with 100 threads                  *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_primitives.c:1276 in test_threaded_faa_ret()...
***** 7 PRIMITIVES TESTS FAILED! *****
FAIL: test_primitives
Testing memory barrier sanity                                          PASSED
Testing memory barriers with linear array with 2 threads               PASSED
Testing memory barriers with local variables with 2 threads            PASSED
Testing memory barriers with scattered array with 2 threads            PASSED
Testing memory barriers with linear array with 10 threads              PASSED
Testing memory barriers with local variables with 10 threads           PASSED
Testing memory barriers with scattered array with 10 threads           PASSED
Testing memory barriers with linear array with 100 threads            *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:304 in test_barriers_linear_array()...
Testing memory barriers with local variables with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:558 in test_barriers_variables()...
Testing memory barriers with scattered array with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:660 in test_barriers_scattered_array()...
***** 3 BARRIERS TESTS FAILED! *****
FAIL: test_barriers
2 of 3 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/co-login/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/co-login/test'
gmake: *** [check-recursive] Error 1
===== Exit bin/snapshot with status=2: Fri May  1 02:48:58 CDT 2009 =====
Dumping done
   Watchers List
More information about the opa-nightly-tests mailing list
