[opa-nightly-tests] jam OPA_Daily_Tests_0624Wed_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Wed Jun 24 09:09:59 CDT 2009
*** OPA Tests on 0624Wed ***
   Tests Summary
****FAILED colonelk: runtest command failed ****
****FAILED colonelk: standard****
PASSED duty: standard
PASSED jam: standard
PASSED liberty: standard
PASSED linew: standard
PASSED smirom: standard
   Tests Time Summary
colonelk: Ran 1(0/1/0) tests, Grand total test time =  0m 4s
jam: Ran 1(1/0/0) tests, Grand total test time =  0m 40s
smirom: Ran 1(1/0/0) tests, Grand total test time =  0m 38s
liberty: Ran 1(1/0/0) tests, Grand total test time =  0m 35s
duty: Ran 1(1/0/0) tests, Grand total test time =  1m 31s
linew: Ran 1(1/0/0) tests, Grand total test time =  2m 36s
jam: Ran 6(0/0/0) hosts, Grand total test time =  3m 36s
   Timekeeper log
Timekeeper started at Wed Jun 24 09:06:35 CDT 2009
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of colonelk: standard
Last 30 lines of /mnt/scr1/SnapTest/snapshots-opa/log/colonelk_0624Wed_0907
/home/hdftest/snapshots-opa/current/configure: line 2676: printf: write error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2684: printf: write error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2687: printf: write error: No space left on device
cat: write error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2710: printf: write error: No space left on device
checking for C compiler default output file name... /home/hdftest/snapshots-opa/current/configure: line 2733: printf: write error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2736: printf: write error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2774: printf: write error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2777: printf: write error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2780: printf: write error: No space left on device
configure: error: in `/home/hdftest/snapshots-opa/TestDir/colonelk':
/home/hdftest/snapshots-opa/current/configure: line 2783: printf: write error: No space left on device
configure: error: C compiler cannot create executables
See `config.log' for more details.
/home/hdftest/snapshots-opa/current/configure: line 2789: echo: write error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2796: echo: write error: No space left on device
sort: fflush failed: standard output: No space left on device
sort: write error
/home/hdftest/snapshots-opa/current/configure: line 2827: echo: write error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2834: echo: write error: No space left on device
sort: write error
/home/hdftest/snapshots-opa/current/configure: line 2843: echo: write error: No space left on device
/home/hdftest/snapshots-opa/current/configure: line 2875: printf: write error: No space left on device
===== Exit bin/snapshot with status=77: Wed Jun 24 09:07:08 CDT 2009 =====
Dumping done
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 09:06:13 up 28 days, 34 min, 19 users,  load average: 0.02, 0.03, 0.01
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   3046524  27053668  11% /
/dev/sda1               101086     45293     50574  48% /boot
/dev/sda2             31738420    285716  29814476   1% /tmp
/dev/sda6             31738392   3719056  26381112  13% /var
/dev/sda7             31738392  13406616  16693552  45% /usr
/dev/sda8            124991068   8903304 109636064   8% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840   8919396 179194084   5% /home
/dev/sde1            565688764  25090704 511399124   5% /scr
/dev/sdc1            961432072 663411656 249182416  73% /mnt/scr1
tmpfs                  7601912         0   7601912   0% /dev/shm
gumund:/data/ftp     480719072 176783744 279516128  39% /mnt/ftp
gumund:/data/web     480719072 176783744 279516128  39% /mnt/web
none                   7601824       104   7601720   1% /var/lib/xenstored
/dev/sdd1            961432072 212915136 699678936  24% /mnt/hdf
kagiso:/mnt/scr1-old 1441802336 388094784 980468192  29% /mnt/scr1-old
kagiso:/mnt/hdf-old  576713280 200112128 347305760  37% /mnt/hdf-old
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
FTP flag is
Running CVS checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/CVS_LOG_0624Wed
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0624Wed.7789: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0624Wed.7789': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
smirom
colonelk
duty
liberty
    Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname linew
Using configname option for -configname
opa
  9:06am  up 20:59,  0 users,  load average: 0.45, 0.96, 1.33
/                  (/dev/dsk/c1t0d0s0 ):62047494 blocks  8054930 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483604 files
/proc              (proc              ):       0 blocks    15963 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ): 8944240 blocks   134079 files
/system/object     (objfs             ):       0 blocks 2147483487 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):62047494 blocks  8054930 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):62047494 blocks  8054930 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ): 8944240 blocks   134079 files
/var/run           (swap              ): 8944240 blocks   134079 files
/home              (jam:/home         ):378864888 blocks 51041543 files
/mnt/hdf           (jam:/mnt/hdf      ):1497033872 blocks 118562747 files
/mnt/scr1          (jam:/mnt/scr1     ):596040784 blocks 118481008 files
/mnt/web           (gumund:/mnt/web   ):607870632 blocks 60668405 files
/mnt/ftp           (gumund:/mnt/ftp   ):607870632 blocks 60668405 files
TEST_TYPES=standard
FTP flag is
Running bin/snapshot checkout from /mnt/scr1/SnapTest/snapshots-opa
FTP flag is
Running standard
Wed Jun 24 09:07:01 CDT 2009
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_141414-01 sun4u sparc SUNW,A70
SRCDIRNAME is linew
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/linew_0624Wed_0907
SNAPCMD is srcdir test clean
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname linew
*** finished standard tests for linew ***
Wed Jun 24 09:09:27 CDT 2009
Total time = 2m 26s
*** finished tests in linew ***
Wed Jun 24 09:09:29 CDT 2009
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname jam
opa
 09:06:43 up 28 days, 35 min, 19 users,  load average: 0.01, 0.02, 0.01
/dev/sda2             31738420    285720  29814472   1% /tmp
/dev/sda6             31738392   3719052  26381116  13% /var
/dev/sdc1            961432072 663411688 249182384  73% /mnt/scr1
TEST_TYPES=standard
FTP flag is
FTP flag is
Running standard
Wed Jun 24 09:06:53 CDT 2009
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-128.1.10.el5xen #1 SMP Thu May 7 11:51:15 EDT 2009 i686 i686 i386 GNU/Linux
SRCDIRNAME is jam
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0624Wed_0906
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname jam
*** finished standard tests for jam ***
Wed Jun 24 09:07:33 CDT 2009
Total time = 0m 40s
*** finished tests in jam ***
Testing smirom
ssh smirom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname smirom
opa
  9:06am  up 11 days 19:49,  7 users,  load average: 0.00, 0.00, 0.02
/dev/hdb1             76920416  12580252  60432756  18% /
udev                   1991252       116   1991136   1% /dev
/dev/sda2            129736964  30462220  99274744  24% /scr
/dev/sdb1             76920416  29021436  43991572  40% /usr
jam:/home            198351840   8919392 179194112   5% /home
jam:/mnt/hdf         961432096 212915136 699678944  24% /mnt/hdf
jam:/mnt/scr1        961432096 663411712 249182400  73% /mnt/scr1
TEST_TYPES=standard
FTP flag is
FTP flag is
Running standard
Wed Jun 24 09:06:59 CDT 2009
*** starting standard tests in smirom ***
Uname -a: Linux smirom 2.6.16.60-0.37_f594963d-smp #1 SMP Mon Mar 23 13:39:48 UTC 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is smirom
   /mnt/scr1/SnapTest/snapshots-opa/log/smirom_0624Wed_0906
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname smirom
*** finished standard tests for smirom ***
Wed Jun 24 09:07:37 CDT 2009
Total time = 0m 38s
*** finished tests in smirom ***
Testing colonelk
ssh colonelk -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname colonelk
opa
 09:06:54 up 1 day, 20:18,  0 users,  load average: 0.08, 0.02, 0.01
/dev/hda3             29753588   3591080  24626696  13% /
/dev/hda2             49961020    184288  47197900   1% /tmp
/dev/hda6              9920592    598948   8809576   7% /var
/dev/hda5             19840892  18816852         0 100% /scr
/dev/hda1               101086     33335     62532  35% /boot
tmpfs                   517644         0    517644   0% /dev/shm
jam:/mnt/scr1        961432096 663411712 249182368  73% /mnt/scr1
TEST_TYPES=standard
FTP flag is
FTP flag is
Running standard
Wed Jun 24 09:07:04 CDT 2009
*** starting standard tests in colonelk ***
Uname -a: Linux colonelk 2.6.18-128.1.14.el5 #1 SMP Wed Jun 17 06:40:54 EDT 2009 i686 i686 i386 GNU/Linux
SRCDIRNAME is colonelk
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname colonelk
*** finished standard tests for colonelk ***
Total time = 0m 4s
*** finished tests in colonelk ***
****FAILED colonelk: Abnormal exit from runtest ****
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname duty
opa
 9:06AM  up 28 days, 21:02, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/aacd0s1a       507630     61002    406018    13%    /
devfs                    1         1         0   100%    /dev
/dev/aacd0s1h    188433016 120649146  52709230    70%    /data
/dev/aacd0s1g     32494668  26925222   2969874    90%    /local_home
/dev/aacd0s1f     12186190   2546656   8664640    23%    /usr
/dev/aacd0s1d       507630     46394    420626    10%    /var
/dev/aacd0s1e       253678       334    233050     0%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840   8919396 179194084     5%    /home
jam:/mnt/scr1    961432072 663411720 249182352    73%    /mnt/scr1
gumund:/data/web 480719056 176783740 279516116    39%    /mnt/web
gumund:/data/ftp 480719056 176783740 279516116    39%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702        36    116530     0%    /tmp
jam:/mnt/hdf     961432072 212915136 699678936    23%    /mnt/hdf
TEST_TYPES=standard
FTP flag is
FTP flag is
Running standard
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
SRCDIRNAME is duty
   /mnt/scr1/SnapTest/snapshots-opa/log/duty_0624Wed_0907
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname duty
*** finished standard tests for duty ***
Wed Jun 24 09:08:39 CDT 2009
Total time = 1m 31s
*** finished tests in duty ***
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname liberty
opa
 9:07AM  up 28 days, 21:04, 1 user, load averages: 0.01, 0.00, 0.00
/dev/aacd0s1a       507630     86926    380094    19%    /
/dev/aacd0s1g     47047830  19743812  23540192    46%    /local_home
/dev/aacd0s1f     12186190   3555136   7656160    32%    /usr
/dev/aacd0s1d      1012974     98844    833094    11%    /var
/dev/aacd0s1e       507630    336490    130530    72%    /var/tmp
jam:/mnt/scr1    961432072 663411772 249182300    73%    /mnt/scr1
/dev/md0            126702        22    116544     0%    /tmp
TEST_TYPES=standard
FTP flag is
FTP flag is
Running standard
Wed Jun 24 09:07:18 CDT 2009
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008     sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY  amd64
SRCDIRNAME is liberty
   /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0624Wed_0907
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname liberty
*** finished standard tests for liberty ***
Wed Jun 24 09:07:53 CDT 2009
Total time = 0m 35s
*** finished tests in liberty ***
More information about the opa-nightly-tests mailing list
