[opa-nightly-tests] jam OPA_Daily_Tests_0610Wed_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Wed Jun 10 09:13:17 CDT 2009
*** OPA Tests on 0610Wed ***
Tests Summary
****FAILED smirom: runtest command failed ****
****FAILED smirom: standard****
PASSED colonelk: standard
PASSED duty: standard
PASSED jam: standard
PASSED liberty: standard
PASSED linew: standard
Tests Time Summary
smirom: Ran 1(0/1/0) tests, Grand total test time = 0m 3s
jam: Ran 1(1/0/0) tests, Grand total test time = 0m 37s
liberty: Ran 1(1/0/0) tests, Grand total test time = 0m 33s
colonelk: Ran 1(1/0/0) tests, Grand total test time = 1m 1s
duty: Ran 1(1/0/0) tests, Grand total test time = 1m 30s
linew: Ran 1(1/0/0) tests, Grand total test time = 3m 57s
jam: Ran 6(0/0/0) hosts, Grand total test time = 4m 59s
Timekeeper log
Timekeeper started at Wed Jun 10 09:08:29 CDT 2009
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of smirom: standard
Last 30 lines of /mnt/scr1/SnapTest/snapshots-opa/log/smirom_0610Wed_0908
USER=hdftest
_=/usr/bin/printenv
VENDOR=suse
WINDOWMANAGER=/usr/X11/bin/gnome
XCURSOR_THEME=Industrial
XDG_CONFIG_DIRS=/usr/local/etc/xdg/:/etc/xdg/:/etc/opt/gnome/xdg/:/etc/xdg:/etc/opt/gnome/xdg
XDG_DATA_DIRS=/usr/local/share/:/usr/share/:/etc/opt/kde3/share/:/opt/kde3/share/:/opt/gnome/share/:/usr/local/share:/usr/share:/etc/opt/kde3/share:/opt/gnome/share:/opt/kde3/share
XKEYSYMDB=/usr/X11R6/lib/X11/XKeysymDB
XNLSPATH=/usr/X11R6/lib/X11/nls
===Done Dumping environment variables after option parsing ===
Configure command is configure --prefix=${PWD}/opainstall
CURRENT is /home/hdftest/snapshots-opa/current
===== Run Tests: Wed Jun 10 09:08:21 CDT 2009 =====
Check to see if TESTDIR /home/hdftest/snapshots-opa/TestDir/smirom exists
gmake: Warning: File `/home/hdftest/snapshots-opa/current/Makefile.in' has modification time 7.4 s in the future
/bin/sh ./config.status --recheck
running CONFIG_SHELL=/bin/sh /bin/sh /home/hdftest/snapshots-opa/current/configure --prefix=${PWD}/opainstall --no-create --no-recursion
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
gmake: *** [config.status] Error 1
TESTDIR is /home/hdftest/snapshots-opa/TestDir/smirom
snapshot is yes
===== configure: Wed Jun 10 09:08:22 CDT 2009 =====
===== Exit bin/snapshot with status=1: Wed Jun 10 09:08:24 CDT 2009 =====
Dumping done
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
Testing all hosts.
opa
09:08:08 up 14 days, 36 min, 14 users, load average: 0.03, 0.14, 0.08
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3589140 26511052 12% /
/dev/sda1 101086 45293 50574 48% /boot
/dev/sda2 31738420 305784 29794408 2% /tmp
/dev/sda6 31738392 4152688 25947480 14% /var
/dev/sda7 31738392 13374512 16725656 45% /usr
/dev/sda8 124991068 6092992 112446376 6% /var/tmp
/dev/mapper/VolGroup00-home
198351840 7801176 180312304 5% /home
/dev/sde1 565688764 24851548 511638280 5% /scr
/dev/sdc1 961432072 616096912 296497160 68% /mnt/scr1
tmpfs 7601912 0 7601912 0% /dev/shm
gumund:/data/ftp 480719072 234034688 222265184 52% /mnt/ftp
gumund:/data/web 480719072 234034688 222265184 52% /mnt/web
none 7601824 104 7601720 1% /var/lib/xenstored
/dev/sdd1 961432072 209286632 703307440 23% /mnt/hdf
kagiso:/mnt/scr1-old 1441802336 395163776 973399200 29% /mnt/scr1-old
kagiso:/mnt/hdf-old 576713280 215106752 332311104 40% /mnt/hdf-old
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
FTP flag is
Running CVS checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/CVS_LOG_0610Wed
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0610Wed.17546: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0610Wed.17546': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
smirom
colonelk
duty
liberty
Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname linew
Using configname option for -configname
opa
9:08am up 7 day(s), 23:22, 2 users, load average: 1.23, 1.28, 1.43
/ (/dev/dsk/c1t0d0s0 ):63332420 blocks 8055958 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483607 files
/proc (proc ): 0 blocks 15956 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ): 8763168 blocks 134023 files
/system/object (objfs ): 0 blocks 2147483489 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):63332420 blocks 8055958 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):63332420 blocks 8055958 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ): 8763168 blocks 134023 files
/var/run (swap ): 8763168 blocks 134023 files
/home (jam:/home ):381101328 blocks 51080064 files
/mnt/hdf (jam:/mnt/hdf ):1504290880 blocks 118611249 files
/mnt/scr1 (jam:/mnt/scr1 ):690670240 blocks 118922817 files
/mnt/web (gumund:/mnt/web ):493368720 blocks 60696921 files
/mnt/ftp (gumund:/mnt/ftp ):493368720 blocks 60696921 files
TEST_TYPES=standard
FTP flag is
Running bin/snapshot checkout from /mnt/scr1/SnapTest/snapshots-opa
FTP flag is
Running standard
Wed Jun 10 09:08:51 CDT 2009
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_139555-08 sun4u sparc SUNW,A70
SRCDIRNAME is linew
Running snapshot with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/linew_0610Wed_0908
SNAPCMD is srcdir test clean
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname linew
*** finished standard tests for linew ***
Wed Jun 10 09:12:46 CDT 2009
Total time = 3m 56s
*** finished tests in linew ***
Wed Jun 10 09:12:47 CDT 2009
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname jam
opa
09:08:42 up 14 days, 37 min, 14 users, load average: 0.06, 0.14, 0.08
/dev/sda2 31738420 305788 29794404 2% /tmp
/dev/sdc1 961432072 616096960 296497112 68% /mnt/scr1
TEST_TYPES=standard
FTP flag is
FTP flag is
Running standard
Wed Jun 10 09:08:52 CDT 2009
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-128.1.10.el5xen #1 SMP Thu May 7 11:51:15 EDT 2009 i686 i686 i386 GNU/Linux
SRCDIRNAME is jam
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0610Wed_0908
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname jam
*** finished standard tests for jam ***
Wed Jun 10 09:09:29 CDT 2009
Total time = 0m 37s
*** finished tests in jam ***
Testing smirom
ssh smirom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname smirom
opa
9:08am up 6 days 17:17, 6 users, load average: 0.43, 0.37, 0.35
/dev/hdb1 76920416 12226776 60786232 17% /
udev 1991252 116 1991136 1% /dev
/dev/sda2 129736964 30459756 99277208 24% /scr
/dev/sdb1 76920416 28979732 44033276 40% /usr
jam:/home 198351840 7801152 180312320 5% /home
jam:/mnt/hdf 961432096 209286656 703307456 23% /mnt/hdf
jam:/mnt/scr1 961432096 616096992 296497120 68% /mnt/scr1
TEST_TYPES=standard
FTP flag is
FTP flag is
Running standard
*** starting standard tests in smirom ***
Uname -a: Linux smirom 2.6.16.60-0.37_f594963d-smp #1 SMP Mon Mar 23 13:39:48 UTC 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is smirom
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname smirom
*** finished standard tests for smirom ***
Total time = 0m 3s
*** finished tests in smirom ***
****FAILED smirom: Abnormal exit from runtest ****
Testing colonelk
ssh colonelk -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname colonelk
opa
09:08:51 up 26 days, 20:54, 0 users, load average: 0.00, 0.00, 0.00
/dev/hda3 29753588 3587828 24629948 13% /
/dev/hda2 49961020 184288 47197900 1% /tmp
/dev/hda6 9920592 593708 8814816 7% /var
/dev/hda5 19840892 9642776 9173976 52% /scr
/dev/hda1 101086 33196 62671 35% /boot
tmpfs 517644 0 517644 0% /dev/shm
TEST_TYPES=standard
FTP flag is
FTP flag is
Running standard
Wed Jun 10 09:09:02 CDT 2009
*** starting standard tests in colonelk ***
Uname -a: Linux colonelk 2.6.18-128.1.10.el5.centos.plus #1 SMP Mon May 11 07:04:55 EDT 2009 i686 i686 i386 GNU/Linux
SRCDIRNAME is colonelk
/mnt/scr1/SnapTest/snapshots-opa/log/colonelk_0610Wed_0909
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname colonelk
*** finished standard tests for colonelk ***
Wed Jun 10 09:10:02 CDT 2009
Total time = 1m 0s
*** finished tests in colonelk ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname duty
opa
9:08AM up 14 days, 21:04, 0 users, load averages: 0.00, 0.00, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 61002 406018 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 120648858 52709518 70% /data
/dev/aacd0s1g 32494668 26405594 3489502 88% /local_home
/dev/aacd0s1f 12186190 2516776 8694520 22% /usr
/dev/aacd0s1d 507630 46288 420732 10% /var
/dev/aacd0s1e 253678 334 233050 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 7801176 180312304 4% /home
jam:/mnt/scr1 961432072 616097004 296497068 68% /mnt/scr1
gumund:/data/web 480719056 234034696 222265160 51% /mnt/web
gumund:/data/ftp 480719056 234034696 222265160 51% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 58 116508 0% /tmp
jam:/mnt/hdf 961432072 209286632 703307440 23% /mnt/hdf
TEST_TYPES=standard
FTP flag is
FTP flag is
Running standard
Wed Jun 10 09:09:08 CDT 2009
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
SRCDIRNAME is duty
/mnt/scr1/SnapTest/snapshots-opa/log/duty_0610Wed_0909
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname duty
*** finished standard tests for duty ***
Wed Jun 10 09:10:38 CDT 2009
Total time = 1m 30s
*** finished tests in duty ***
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname liberty
opa
9:09AM up 14 days, 21:06, 5 users, load averages: 0.00, 0.00, 0.00
/dev/aacd0s1a 507630 86926 380094 19% /
/dev/aacd0s1g 47047830 19760742 23523262 46% /local_home
/dev/aacd0s1f 12186190 3470678 7740618 31% /usr
/dev/aacd0s1d 1012974 98634 833304 11% /var
/dev/aacd0s1e 507630 336490 130530 72% /var/tmp
jam:/mnt/scr1 961432072 616097032 296497040 68% /mnt/scr1
TEST_TYPES=standard
FTP flag is
FTP flag is
Running standard
Wed Jun 10 09:09:13 CDT 2009
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008 sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY amd64
SRCDIRNAME is liberty
/mnt/scr1/SnapTest/snapshots-opa/log/liberty_0610Wed_0909
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname liberty
*** finished standard tests for liberty ***
Wed Jun 10 09:09:46 CDT 2009
Total time = 0m 33s
*** finished tests in liberty ***
More information about the opa-nightly-tests
