[opa-nightly-tests] jam OPA_Daily_Tests_0609Tue_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Tue Jun 9 15:06:55 CDT 2009
*** OPA Tests on 0609Tue ***
   Tests Summary
****FAILED smirom: runtest command failed ****
****FAILED smirom: standard****
PASSED colonelk: standard
PASSED duty: standard
PASSED jam: standard
PASSED liberty: standard
PASSED linew: standard
   Tests Time Summary
smirom: Ran 1(0/1/0) tests, Grand total test time =  0m 3s
jam: Ran 1(1/0/0) tests, Grand total test time =  0m 37s
liberty: Ran 1(1/0/0) tests, Grand total test time =  0m 35s
colonelk: Ran 1(1/0/0) tests, Grand total test time =  0m 59s
linew: Ran 1(1/0/0) tests, Grand total test time =  1m 27s
duty: Ran 1(1/0/0) tests, Grand total test time =  1m 27s
jam: Ran 6(0/0/0) hosts, Grand total test time =  2m 44s
   Timekeeper log
Timekeeper started at Tue Jun  9 15:04:23 CDT 2009
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of smirom: standard
Last 30 lines of /mnt/scr1/SnapTest/snapshots-opa/log/smirom_0609Tue_1504
USER=hdftest
_=/usr/bin/printenv
VENDOR=suse
WINDOWMANAGER=/usr/X11/bin/gnome
XCURSOR_THEME=Industrial
XDG_CONFIG_DIRS=/usr/local/etc/xdg/:/etc/xdg/:/etc/opt/gnome/xdg/:/etc/xdg:/etc/opt/gnome/xdg
XDG_DATA_DIRS=/usr/local/share/:/usr/share/:/etc/opt/kde3/share/:/opt/kde3/share/:/opt/gnome/share/:/usr/local/share:/usr/share:/etc/opt/kde3/share:/opt/gnome/share:/opt/kde3/share
XKEYSYMDB=/usr/X11R6/lib/X11/XKeysymDB
XNLSPATH=/usr/X11R6/lib/X11/nls
===Done Dumping environment variables after option parsing ===
Configure command is configure  --prefix=${PWD}/opainstall
CURRENT is /home/hdftest/snapshots-opa/current
===== Run Tests: Tue Jun  9 15:04:17 CDT 2009 =====
Check to see if TESTDIR /home/hdftest/snapshots-opa/TestDir/smirom exists
gmake: Warning: File `/home/hdftest/snapshots-opa/current/Makefile.in' has modification time 5.8 s in the future
/bin/sh ./config.status --recheck
running CONFIG_SHELL=/bin/sh /bin/sh /home/hdftest/snapshots-opa/current/configure --prefix=${PWD}/opainstall --no-create --no-recursion
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... configure: error: newly created file is older than distributed files!
Check your system clock
gmake: *** [config.status] Error 1
TESTDIR is /home/hdftest/snapshots-opa/TestDir/smirom
snapshot is yes
===== configure: Tue Jun  9 15:04:18 CDT 2009 =====
===== Exit bin/snapshot with status=1: Tue Jun  9 15:04:19 CDT 2009 =====
Dumping done
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 15:04:01 up 13 days,  6:32, 19 users,  load average: 0.13, 0.10, 0.20
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   3588232  26511960  12% /
/dev/sda1               101086     45293     50574  48% /boot
/dev/sda2             31738420    354140  29746052   2% /tmp
/dev/sda6             31738392   4169304  25930864  14% /var
/dev/sda7             31738392  13372552  16727616  45% /usr
/dev/sda8            124991068   6091240 112448128   6% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840   7800584 180312896   5% /home
/dev/sde1            565688764  26612204 509877624   5% /scr
/dev/sdc1            961432072 616438636 296155436  68% /mnt/scr1
tmpfs                  7601912         0   7601912   0% /dev/shm
gumund:/data/ftp     480719072 231814496 224485376  51% /mnt/ftp
gumund:/data/web     480719072 231814496 224485376  51% /mnt/web
none                   7601824       104   7601720   1% /var/lib/xenstored
/dev/sdd1            961432072 209272764 703321308  23% /mnt/hdf
kagiso:/mnt/scr1-old 1441802336 395163776 973399200  29% /mnt/scr1-old
kagiso:/mnt/hdf-old  576713280 215106752 332311104  40% /mnt/hdf-old
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
FTP flag is
Running CVS checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/CVS_LOG_0609Tue
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0609Tue.16398: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0609Tue.16398': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
smirom
colonelk
duty
liberty
    Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname linew
Using configname option for -configname
opa
  3:04pm  up 7 day(s),  5:18,  3 users,  load average: 0.41, 1.03, 1.91
/                  (/dev/dsk/c1t0d0s0 ):63476562 blocks  8055059 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483607 files
/proc              (proc              ):       0 blocks    15964 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ): 8763056 blocks   134023 files
/system/object     (objfs             ):       0 blocks 2147483487 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):63476562 blocks  8055059 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):63476562 blocks  8055059 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ): 8763056 blocks   134023 files
/var/run           (swap              ): 8763056 blocks   134023 files
/home              (jam:/home         ):381102504 blocks 51080067 files
/mnt/hdf           (jam:/mnt/hdf      ):1504318616 blocks 118611310 files
/mnt/scr1          (jam:/mnt/scr1     ):689984432 blocks 118960767 files
/mnt/web           (gumund:/mnt/web   ):497809096 blocks 60696972 files
/mnt/ftp           (gumund:/mnt/ftp   ):497809096 blocks 60696972 files
TEST_TYPES=standard
FTP flag is
Running bin/snapshot checkout from /mnt/scr1/SnapTest/snapshots-opa
FTP flag is
Running standard
Tue Jun  9 15:04:42 CDT 2009
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_139555-08 sun4u sparc SUNW,A70
SRCDIRNAME is linew
Running snapshot with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/linew_0609Tue_1504
SNAPCMD is srcdir test clean
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname linew
*** finished standard tests for linew ***
Tue Jun  9 15:06:09 CDT 2009
Total time = 1m 27s
*** finished tests in linew ***
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname jam
opa
 15:04:34 up 13 days,  6:33, 19 users,  load average: 0.14, 0.11, 0.19
/dev/sda2             31738420    354144  29746048   2% /tmp
/dev/sda6             31738392   4169368  25930800  14% /var
/dev/sda8            124991068   6091236 112448132   6% /var/tmp
                     198351840   7800588 180312892   5% /home
/dev/sdc1            961432072 616439972 296154100  68% /mnt/scr1
TEST_TYPES=standard
FTP flag is
FTP flag is
Running standard
Tue Jun  9 15:04:44 CDT 2009
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-128.1.10.el5xen #1 SMP Thu May 7 11:51:15 EDT 2009 i686 i686 i386 GNU/Linux
SRCDIRNAME is jam
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0609Tue_1504
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname jam
*** finished standard tests for jam ***
Tue Jun  9 15:05:21 CDT 2009
Total time = 0m 37s
*** finished tests in jam ***
Testing smirom
ssh smirom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname smirom
opa
  3:04pm  up 5 days 23:13,  6 users,  load average: 0.00, 0.00, 0.00
/dev/hdb1             76920416  12353628  60659380  17% /
udev                   1991252       116   1991136   1% /dev
/dev/sda2            129736964  31083272  98653692  24% /scr
/dev/sdb1             76920416  28976256  44036752  40% /usr
jam:/home            198351840   7800576 180312896   5% /home
jam:/mnt/hdf         961432096 209272768 703321312  23% /mnt/hdf
jam:/mnt/scr1        961432096 616440000 296154112  68% /mnt/scr1
TEST_TYPES=standard
FTP flag is
FTP flag is
Running standard
*** starting standard tests in smirom ***
Uname -a: Linux smirom 2.6.16.60-0.37_f594963d-smp #1 SMP Mon Mar 23 13:39:48 UTC 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is smirom
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname smirom
*** finished standard tests for smirom ***
Total time = 0m 2s
*** finished tests in smirom ***
****FAILED smirom: Abnormal exit from runtest ****
Testing colonelk
ssh colonelk -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname colonelk
opa
 15:04:43 up 26 days,  2:50,  0 users,  load average: 0.00, 0.00, 0.00
/dev/hda3             29753588   3587832  24629944  13% /
/dev/hda2             49961020    184288  47197900   1% /tmp
/dev/hda6              9920592    592804   8815720   7% /var
/dev/hda5             19840892   9936516   8880236  53% /scr
/dev/hda1               101086     33196     62671  35% /boot
tmpfs                   517644         0    517644   0% /dev/shm
jam:/mnt/scr1        961432096 616440000 296154080  68% /mnt/scr1
TEST_TYPES=standard
FTP flag is
FTP flag is
Running standard
Tue Jun  9 15:04:53 CDT 2009
*** starting standard tests in colonelk ***
Uname -a: Linux colonelk 2.6.18-128.1.10.el5.centos.plus #1 SMP Mon May 11 07:04:55 EDT 2009 i686 i686 i386 GNU/Linux
SRCDIRNAME is colonelk
   /mnt/scr1/SnapTest/snapshots-opa/log/colonelk_0609Tue_1504
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname colonelk
*** finished standard tests for colonelk ***
Tue Jun  9 15:05:52 CDT 2009
Total time = 0m 59s
*** finished tests in colonelk ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname duty
opa
 3:04PM  up 14 days, 3 hrs, 16 users, load averages: 0.00, 0.00, 0.00
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/aacd0s1a       507630     61002    406018    13%    /
devfs                    1         1         0   100%    /dev
/dev/aacd0s1h    188433016 120648858  52709518    70%    /data
/dev/aacd0s1g     32494668  26647138   3247958    89%    /local_home
/dev/aacd0s1f     12186190   2488542   8722754    22%    /usr
/dev/aacd0s1d       507630     46160    420860    10%    /var
/dev/aacd0s1e       253678       334    233050     0%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840   7800588 180312892     4%    /home
jam:/mnt/scr1    961432072 616440008 296154064    68%    /mnt/scr1
gumund:/data/web 480719056 231814508 224485348    51%    /mnt/web
gumund:/data/ftp 480719056 231814508 224485348    51%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702        60    116506     0%    /tmp
jam:/mnt/hdf     961432072 209272764 703321308    23%    /mnt/hdf
TEST_TYPES=standard
FTP flag is
FTP flag is
Running standard
Tue Jun  9 15:04:58 CDT 2009
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
SRCDIRNAME is duty
   /mnt/scr1/SnapTest/snapshots-opa/log/duty_0609Tue_1504
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname duty
*** finished standard tests for duty ***
Tue Jun  9 15:06:25 CDT 2009
Total time = 1m 27s
*** finished tests in duty ***
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname liberty
opa
 3:04PM  up 14 days,  3:02, 6 users, load averages: 0.00, 0.00, 0.00
/dev/aacd0s1a       507630     86926    380094    19%    /
/dev/aacd0s1g     47047830  19924124  23359880    46%    /local_home
/dev/aacd0s1f     12186190   3441250   7770046    31%    /usr
/dev/aacd0s1d      1012974     98566    833372    11%    /var
/dev/aacd0s1e       507630    336490    130530    72%    /var/tmp
jam:/mnt/scr1    961432072 616440024 296154048    68%    /mnt/scr1
TEST_TYPES=standard
FTP flag is
FTP flag is
Running standard
Tue Jun  9 15:05:00 CDT 2009
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008     sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY  amd64
SRCDIRNAME is liberty
   /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0609Tue_1505
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname liberty
*** finished standard tests for liberty ***
Tue Jun  9 15:05:35 CDT 2009
Total time = 0m 35s
*** finished tests in liberty ***
More information about the opa-nightly-tests mailing list
