[opa-nightly-tests] honest4 OPA_Daily_Tests_1231Thu_FAILED!!!
HDFTEST Community User hdftest at ncsa.uiuc.edu
Thu Dec 31 00:36:22 CST 2009
*** OPA Tests on 1231Thu ***
   Tests Summary
****FAILED honest1: standard****
   Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time =  1m 8s
honest4: Ran 1(0/0/0) hosts, Grand total test time =  2m 4s
   Timekeeper log
Timekeeper started at Thu Dec 31 00:34:28 CST 2009
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of honest1: standard
Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_1231Thu_0034
Testing memory barrier sanity                                          PASSED
Testing memory barriers with linear array with 2 threads               PASSED
Testing memory barriers with local variables with 2 threads            PASSED
Testing memory barriers with scattered array with 2 threads            PASSED
Testing memory barriers with linear array with 4 threads               PASSED
Testing memory barriers with local variables with 4 threads            PASSED
Testing memory barriers with scattered array with 4 threads            PASSED
Testing memory barriers with linear array with 10 threads              PASSED
Testing memory barriers with local variables with 10 threads           PASSED
Testing memory barriers with scattered array with 10 threads           PASSED
Testing memory barriers with linear array with 100 threads            *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:304 in test_barriers_linear_array()...
Testing memory barriers with local variables with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:558 in test_barriers_variables()...
Testing memory barriers with scattered array with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:660 in test_barriers_scattered_array()...
***** 3 BARRIERS TESTS FAILED! *****
FAIL: test_barriers
1 of 3 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Thu Dec 31 00:35:51 CST 2009 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 00:34:07 up 28 days, 23:30, 36 users,  load average: 0.25, 0.76, 1.37
Filesystem           1K-blocks      Used Available Use% Mounted on
none                   8218016         0   8218016   0% /dev/shm
abem1:/var/lib/perceus/
                     138916864 110661120  21199168  84% /var/lib/perceus
10.1.69.1:/usr/src   138916864 110661120  21199168  84% /usr/src
/dev/sda2             63013156    455556  61924800   1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
                     3385032528 535086456 2677996032  17% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
                     80761058784 53544785704 26395478692  67% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
                     55567516032 15848361388 36940133688  31% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
                     3385032528 122786732 3113222360   4% /usr/local
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
                     242279901024 127113715976 107062586564  55% /cfs/scratch
abem5:/var/spool/torque/server_logs
                     961428816 116144640 796446336  13% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
                      73575600  53285072  16492720  77% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  60368728   6604232  91% /var/forward
mds03.uits.indiana.edu:/mds-wan/client
                     363327960768 330173104480 30893745268  92% /WAN/IU
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running CVS checkout with output saved in
   /u/ac/hdftest/snapshots-opa/log/CVS_LOG_1231Thu
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.1231Thu.30830: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.1231Thu.30830': No such file or directory
Thu Dec 31 00:34:27 CST 2009
*** launching tests from honest4 ***
TESTHOST is honest1
    Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -nocvs -configname honest1
Using configname option for -configname
opa
 00:34:33 up 28 days, 23:31, 47 users,  load average: 1.23, 0.92, 0.80
abem2:/var/lib/perceus/
                      74763440  62348448   8617184  88% /var/lib/perceus
/dev/sda2             63013156    140172  62240184   1% /tmp
                     80761058784 53544805896 26395429220  67% /cfs/projects
                     55567516032 15848526832 36940129380  31% /u
                     3385032528 122786672 3113222272   4% /usr/local
                     242279901024 127113845320 107050393464  55% /cfs/scratch
                     961428816 116144704 796446272  13% /var/spool/torque/server_logs
pop:/var/forward      70557056  60368992   6603968  91% /var/forward
                     363327960768 330173105592 30893743776  92% /WAN/IU
TEST_TYPES=standard
Running standard
Thu Dec 31 00:34:43 CST 2009
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 1m 8s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
	****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest4 ***
More information about the opa-nightly-tests mailing list
