[opa-nightly-tests] honest4 OPA_Daily_Tests_1213Sun_FAILED!!!
HDFTEST Community User hdftest at ncsa.uiuc.edu
Sun Dec 13 01:40:59 CST 2009
*** OPA Tests on 1213Sun ***
   Tests Summary
****FAILED honest1: standard****
   Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time =  0m 51s
honest4: Ran 1(0/0/0) hosts, Grand total test time =  1m 47s
   Timekeeper log
Timekeeper started at Sun Dec 13 01:39:21 CST 2009
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of honest1: standard
Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_1213Sun_0139
Testing memory barrier sanity                                          PASSED
Testing memory barriers with linear array with 2 threads               PASSED
Testing memory barriers with local variables with 2 threads            PASSED
Testing memory barriers with scattered array with 2 threads            PASSED
Testing memory barriers with linear array with 4 threads               PASSED
Testing memory barriers with local variables with 4 threads            PASSED
Testing memory barriers with scattered array with 4 threads            PASSED
Testing memory barriers with linear array with 10 threads              PASSED
Testing memory barriers with local variables with 10 threads           PASSED
Testing memory barriers with scattered array with 10 threads           PASSED
Testing memory barriers with linear array with 100 threads            *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:304 in test_barriers_linear_array()...
Testing memory barriers with local variables with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:558 in test_barriers_variables()...
Testing memory barriers with scattered array with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:660 in test_barriers_scattered_array()...
***** 3 BARRIERS TESTS FAILED! *****
FAIL: test_barriers
2 of 3 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Sun Dec 13 01:40:28 CST 2009 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 01:39:02 up 11 days, 35 min, 50 users,  load average: 0.18, 0.56, 1.10
Filesystem           1K-blocks      Used Available Use% Mounted on
none                   8218016         0   8218016   0% /dev/shm
abem1:/var/lib/perceus/
                     138916864 110669168  21191104  84% /var/lib/perceus
10.1.69.1:/usr/src   138916864 110669152  21191104  84% /usr/src
/dev/sda2             63013156     53564  62326792   1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
                     3385032528 534575828 2678506660  17% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
                     80761058784 51104995744 28835315136  64% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
                     55567516032 15363353568 37426776916  30% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
                     3385032528 115066724 3120942380   4% /usr/local
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
                     242279901024 94222973856 139962865132  41% /cfs/scratch
abem5:/var/spool/torque/server_logs
                     961428816 111554528 801036464  13% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
                      73575600  52710000  17067792  76% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  59489888   7483072  89% /var/forward
mds03.uits.indiana.edu:/mds-wan/client
                     363327960768 339332510732 21734273076  94% /WAN/IU
STANDARD_OPT=setenv MAKE gmake op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running CVS checkout with output saved in
   /u/ac/hdftest/snapshots-opa/log/CVS_LOG_1213Sun
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.1213Sun.16058: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.1213Sun.16058': No such file or directory
*** launching tests from honest4 ***
TESTHOST is honest1
    Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -nocvs -configname honest1
Using configname option for -configname
opa
 01:39:27 up 11 days, 36 min, 51 users,  load average: 1.79, 1.36, 2.52
abem2:/var/lib/perceus/
                      74763440  62388480   8577152  88% /var/lib/perceus
/dev/sda2             63013156    105776  62274580   1% /tmp
                     80761058784 51105400428 28834863288  64% /cfs/projects
                     55567516032 15363372256 37426686820  30% /u
                     3385032528 115066728 3120942376   4% /usr/local
                     242279901024 94225893484 139959901652  41% /cfs/scratch
                     961428816 111554592 801036384  13% /var/spool/torque/server_logs
                      73575600  52710240  17067552  76% /var/spool/torque/server_priv/accounting
                     363327960768 339332362620 21734498624  94% /WAN/IU
TEST_TYPES=standard
Running standard
Sun Dec 13 01:39:37 CST 2009
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is setenv MAKE gmake op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 0m 51s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
	****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest4 ***
More information about the opa-nightly-tests mailing list
