[opa-nightly-tests] honest4 OPA_Daily_Tests_1211Fri_FAILED!!!
HDFTEST Community User hdftest at ncsa.uiuc.edu
Fri Dec 11 01:04:00 CST 2009
*** OPA Tests on 1211Fri ***
   Tests Summary
****FAILED honest1: standard****
   Tests Time Summary
honest1: Ran 1(0/1/0) tests, Grand total test time =  0m 58s
honest4: Ran 1(0/0/0) hosts, Grand total test time =  1m 52s
   Timekeeper log
Timekeeper started at Fri Dec 11 01:02:15 CST 2009
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of honest1: standard
Last 30 lines of /u/ac/hdftest/snapshots-opa/log/honest1_1211Fri_0102
FAIL: test_primitives
Testing memory barrier sanity                                          PASSED
Testing memory barriers with linear array with 2 threads               PASSED
Testing memory barriers with local variables with 2 threads            PASSED
Testing memory barriers with scattered array with 2 threads            PASSED
Testing memory barriers with linear array with 4 threads               PASSED
Testing memory barriers with local variables with 4 threads            PASSED
Testing memory barriers with scattered array with 4 threads            PASSED
Testing memory barriers with linear array with 10 threads              PASSED
Testing memory barriers with local variables with 10 threads           PASSED
Testing memory barriers with scattered array with 10 threads           PASSED
Testing memory barriers with linear array with 100 threads             PASSED
Testing memory barriers with local variables with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:558 in test_barriers_variables()...
Testing memory barriers with scattered array with 100 threads         *FAILED*
        at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:660 in test_barriers_scattered_array()...
***** 2 BARRIERS TESTS FAILED! *****
FAIL: test_barriers
2 of 3 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
make[2]: *** [check-TESTS] Error 1
make[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
make[1]: *** [check-am] Error 2
make[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/honest1/test'
make: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=2: Fri Dec 11 01:03:29 CST 2009 =====
Dumping done
Runtest did not exit normally.
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 01:01:57 up 8 days, 23:58, 45 users,  load average: 0.23, 0.48, 1.19
Filesystem           1K-blocks      Used Available Use% Mounted on
none                   8218016         0   8218016   0% /dev/shm
abem1:/var/lib/perceus/
                     138916864 110819312  21040960  85% /var/lib/perceus
10.1.69.1:/usr/src   138916864 110819296  21040960  85% /usr/src
/dev/sda2             63013156     53564  62326792   1% /tmp
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/apps
                     3385032528 534371108 2678711380  17% /usr/apps
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/projects
                     80761058784 50597592644 29342792520  64% /cfs/projects
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/home
                     55567516032 15303739480 37486229664  29% /u
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/local
                     3385032528 114994640 3121014468   4% /usr/local
abe-mgs01-ib at o2ib:abe-mgs02-ib at o2ib:/scratch
                     242279901024 91109759632 143079122956  39% /cfs/scratch
abem5:/var/spool/torque/server_logs
                     961428816 110937936 801653040  13% /var/spool/torque/server_logs
abem5:/var/spool/torque/server_priv/accounting
                      73575600  52635312  17142480  76% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  59271872   7701088  89% /var/forward
mds03.uits.indiana.edu:/mds-wan/client
                     363327960768 338225316896 22841441388  94% /WAN/IU
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
Running CVS checkout with output saved in
   /u/ac/hdftest/snapshots-opa/log/CVS_LOG_1211Fri
Checking MANIFEST file ...
cat: /u/ac/hdftest/snapshots-opa/log/#runtest.1211Fri.21138: No such file or directory
rm: cannot remove `/u/ac/hdftest/snapshots-opa/log/#runtest.1211Fri.21138': No such file or directory
*** launching tests from honest4 ***
TESTHOST is honest1
    Fork off timekeeper 30
Testing honest1
ssh honest1 -n cd /u/ac/hdftest/snapshots-opa;/u/ac/hdftest/snapshots-opa/bin/runtest -nodiff -nocvs -configname honest1
Using configname option for -configname
opa
 01:02:21 up 8 days, 23:59, 51 users,  load average: 0.46, 0.42, 0.40
abem2:/var/lib/perceus/
                      74763440  62318816   8646816  88% /var/lib/perceus
/dev/sda2             63013156    105744  62274612   1% /tmp
                     80761058784 50597662512 29342702920  64% /cfs/projects
                     55567516032 15303745444 37486218876  29% /u
                     3385032528 114994640 3121014464   4% /usr/local
                     242279901024 91112278456 143076210756  39% /cfs/scratch
                     961428816 110938032 801652944  13% /var/spool/torque/server_logs
                      73575600  52635472  17142320  76% /var/spool/torque/server_priv/accounting
pop:/var/forward      70557056  59272032   7700928  89% /var/forward
                     363327960768 338225424780 22841370484  94% /WAN/IU
TEST_TYPES=standard
Running standard
Fri Dec 11 01:02:31 CST 2009
*** starting standard tests in honest1 ***
Uname -a: Linux honest1.ncsa.uiuc.edu 2.6.18-92.1.10.el5_lustre.1.6.6smp-perfctr #7 SMP Tue Nov 10 10:41:00 CST 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is honest1
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/local/include,/usr/local/lib srcdirname honest1
*** finished standard tests for honest1 ***
Total time = 0m 58s
*** finished tests in honest1 ***
****SYSTEM ERROR honest1: Abnormal exit from runtest ****
	Fri Dec 11 01:03:59 CST 2009
	****SYSTEM ERROR honest1: runtest command failed ****
*** finished tests in honest4 ***
More information about the opa-nightly-tests mailing list
