[opa-nightly-tests] jam OPA_Daily_Tests_0827Thu_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Thu Aug 27 07:47:59 CDT 2009
*** OPA Tests on 0827Thu ***
Tests Summary
****FAILED linew: runtest command failed ****
****FAILED linew: standard****
PASSED colonelk: standard
PASSED duty: standard
PASSED jam: standard
PASSED liberty: standard
PASSED smirom: standard
Tests Time Summary
linew: Ran 1(0/1/0) tests, Grand total test time = 0m 20s
jam: Ran 1(1/0/0) tests, Grand total test time = 0m 44s
smirom: Ran 1(1/0/0) tests, Grand total test time = 0m 55s
liberty: Ran 1(1/0/0) tests, Grand total test time = 0m 48s
colonelk: Ran 1(1/0/0) tests, Grand total test time = 1m 25s
duty: Ran 1(1/0/0) tests, Grand total test time = 1m 50s
jam: Ran 6(0/0/0) hosts, Grand total test time = 2m 45s
Timekeeper log
Timekeeper started at Thu Aug 27 07:45:15 CDT 2009
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of linew: standard
Last 30 lines of /mnt/scr1/SnapTest/snapshots-opa/log/linew_0827Thu_0745
gmake[1]: warning: -jN forced in submake: disabling jobserver mode.
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/src'
Making check in test
gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake -j 2 sanity test_primitives test_barriers
gmake[2]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake[2]: warning: -jN forced in submake: disabling jobserver mode.
gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src -I/home/hdftest/snapshots-opa/current/src -g -O2 -MT sanity.o -MD -MP -MF .deps/sanity.Tpo -c -o sanity.o /home/hdftest/snapshots-opa/current/test/sanity.c
gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src -I/home/hdftest/snapshots-opa/current/src -g -O2 -MT test_primitives.o -MD -MP -MF .deps/test_primitives.Tpo -c -o test_primitives.o /home/hdftest/snapshots-opa/current/test/test_primitives.c
mv -f .deps/sanity.Tpo .deps/sanity.Po
gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src -I/home/hdftest/snapshots-opa/current/src -g -O2 -MT test_barriers.o -MD -MP -MF .deps/test_barriers.Tpo -c -o test_barriers.o /home/hdftest/snapshots-opa/current/test/test_barriers.c
mv -f .deps/test_barriers.Tpo .deps/test_barriers.Po
gcc -g -O2 -o sanity sanity.o ../src/libopa.a -lpthread
gcc -g -O2 -o test_barriers test_barriers.o ../src/libopa.a -lpthread
mv -f .deps/test_primitives.Tpo .deps/test_primitives.Po
gcc -g -O2 -o test_primitives test_primitives.o ../src/libopa.a -lpthread
Undefined first referenced
symbol in file
pthread_yield test_primitives.o
ld: fatal: Symbol referencing errors. No output written to test_primitives
collect2: ld returned 1 exit status
gmake[2]: *** [test_primitives] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=0: Thu Aug 27 07:45:50 CDT 2009 =====
Dumping done
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
Testing all hosts.
opa
07:45:04 up 55 days, 23:09, 13 users, load average: 0.03, 0.03, 0.09
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3084232 27015960 11% /
/dev/sda1 101086 50879 44988 54% /boot
/dev/sda2 31738420 287884 29812308 1% /tmp
/dev/sda6 31738392 3756436 26343732 13% /var
/dev/sda7 31738392 14153784 15946384 48% /usr
/dev/sda8 124991068 12404768 106134600 11% /var/tmp
/dev/mapper/VolGroup00-home
198351840 11455536 176657944 7% /home
/dev/sde1 565688764 24894000 511595828 5% /scr
/dev/sdc1 961432072 374090840 538503232 41% /mnt/scr1
/dev/sdd1 961432072 228250112 684343960 26% /mnt/hdf
tmpfs 1551408 0 1551408 0% /dev/shm
gumund:/data/ftp 480719072 179001824 277298048 40% /mnt/ftp
gumund:/data/web 480719072 179001824 277298048 40% /mnt/web
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
FTP flag is
Running CVS checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/CVS_LOG_0827Thu
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0827Thu.31527: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0827Thu.31527': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
smirom
colonelk
duty
liberty
Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname linew
Using configname option for -configname
opa
7:45am up 7 day(s), 19:44, 7 users, load average: 0.54, 1.02, 1.10
/ (/dev/dsk/c1t0d0s0 ):54932954 blocks 8046919 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483607 files
/proc (proc ): 0 blocks 29923 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):16717616 blocks 1182891 files
/system/object (objfs ): 0 blocks 2147483484 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):54932954 blocks 8046919 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):54932954 blocks 8046919 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):16717616 blocks 1182891 files
/var/run (swap ):16717616 blocks 1182891 files
/home (jam:/home ):373792608 blocks 51009564 files
/mnt/hdf (jam:/mnt/hdf ):1466363920 blocks 118061962 files
/mnt/scr1 (jam:/mnt/scr1 ):1174682416 blocks 118425045 files
/mnt/web (gumund:/mnt/web ):603434472 blocks 60658963 files
/mnt/ftp (gumund:/mnt/ftp ):603434472 blocks 60658963 files
TEST_TYPES=standard
Running standard
Thu Aug 27 07:45:30 CDT 2009
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_141414-08 sun4u sparc SUNW,A70
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: !: not found
SRCDIRNAME is linew
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname linew
*** finished standard tests for linew ***
Total time = 0m 20s
*** finished tests in linew ***
****FAILED linew: Abnormal exit from runtest ****
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname jam
opa
07:45:22 up 55 days, 23:09, 13 users, load average: 0.14, 0.06, 0.09
/dev/sda2 31738420 287888 29812304 1% /tmp
/dev/sda6 31738392 3756432 26343736 13% /var
/dev/sdc1 961432072 374090872 538503200 41% /mnt/scr1
TEST_TYPES=standard
Running standard
Thu Aug 27 07:45:32 CDT 2009
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-128.1.16.el5 #1 SMP Tue Jun 30 06:10:28 EDT 2009 i686 i686 i386 GNU/Linux
SRCDIRNAME is jam
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0827Thu_0745
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname jam
*** finished standard tests for jam ***
Thu Aug 27 07:46:16 CDT 2009
Total time = 0m 44s
*** finished tests in jam ***
Testing smirom
ssh smirom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname smirom
opa
7:45am up 6 days 15:38, 9 users, load average: 0.00, 0.00, 0.08
/dev/hdb1 76920416 9942680 63070328 14% /
udev 1991252 116 1991136 1% /dev
/dev/sda2 129736964 30902832 98834132 24% /scr
/dev/sdb1 76920416 29630500 43382508 41% /usr
jam:/home 198351840 11455520 176657952 7% /home
jam:/mnt/hdf 961432096 228250112 684343968 26% /mnt/hdf
jam:/mnt/scr1 961432096 374090880 538503200 41% /mnt/scr1
TEST_TYPES=standard
Running standard
Thu Aug 27 07:45:34 CDT 2009
*** starting standard tests in smirom ***
Uname -a: Linux smirom 2.6.16.60-0.34-smp #1 SMP Fri Jan 16 14:59:01 UTC 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is smirom
/mnt/scr1/SnapTest/snapshots-opa/log/smirom_0827Thu_0745
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname smirom
*** finished standard tests for smirom ***
Thu Aug 27 07:46:29 CDT 2009
Total time = 0m 55s
*** finished tests in smirom ***
Testing colonelk
ssh colonelk -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname colonelk
opa
07:45:26 up 1 day, 15:52, 0 users, load average: 0.00, 0.00, 0.00
/dev/hda3 29753588 3596912 24620864 13% /
/dev/hda2 49961020 2031968 45350220 5% /tmp
/dev/hda6 9920592 987328 8421196 11% /var
/dev/hda5 19840892 9690784 9125968 52% /scr
/dev/hda1 101086 33319 62548 35% /boot
tmpfs 517644 0 517644 0% /dev/shm
jam:/mnt/scr1 961432096 374090912 538503200 41% /mnt/scr1
TEST_TYPES=standard
Running standard
Thu Aug 27 07:45:37 CDT 2009
*** starting standard tests in colonelk ***
Uname -a: Linux colonelk 2.6.18-128.7.1.el5 #1 SMP Mon Aug 24 08:20:55 EDT 2009 i686 i686 i386 GNU/Linux
SRCDIRNAME is colonelk
/mnt/scr1/SnapTest/snapshots-opa/log/colonelk_0827Thu_0745
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname colonelk
*** finished standard tests for colonelk ***
Thu Aug 27 07:47:01 CDT 2009
Total time = 1m 24s
*** finished tests in colonelk ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname duty
opa
7:45AM up 92 days, 19:41, 4 users, load averages: 0.00, 0.00, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60994 406026 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 120649130 52709246 70% /data
/dev/aacd0s1g 32494668 22126696 7768400 74% /local_home
/dev/aacd0s1f 12186190 2777952 8433344 25% /usr
/dev/aacd0s1d 507630 46222 420798 10% /var
/dev/aacd0s1e 253678 334 233050 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 11455536 176657944 6% /home
jam:/mnt/scr1 961432072 374090896 538503176 41% /mnt/scr1
gumund:/data/web 480719056 179001820 277298036 39% /mnt/web
gumund:/data/ftp 480719056 179001820 277298036 39% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 54 116512 0% /tmp
jam:/mnt/hdf 961432072 228250112 684343960 25% /mnt/hdf
TEST_TYPES=standard
Running standard
Thu Aug 27 07:45:39 CDT 2009
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
SRCDIRNAME is duty
/mnt/scr1/SnapTest/snapshots-opa/log/duty_0827Thu_0745
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname duty
*** finished standard tests for duty ***
Thu Aug 27 07:47:29 CDT 2009
Total time = 1m 50s
*** finished tests in duty ***
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname liberty
opa
7:45AM up 92 days, 19:43, 8 users, load averages: 0.00, 0.00, 0.00
/dev/aacd0s1a 507630 86918 380102 19% /
/dev/aacd0s1g 47047830 18857892 24426112 44% /local_home
/dev/aacd0s1f 12186190 4198264 7013032 37% /usr
/dev/aacd0s1d 1012974 99430 832508 11% /var
/dev/aacd0s1e 507630 336490 130530 72% /var/tmp
jam:/mnt/scr1 961432072 374090904 538503168 41% /mnt/scr1
/dev/md0 126702 48 116518 0% /tmp
TEST_TYPES=standard
Running standard
Thu Aug 27 07:45:41 CDT 2009
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008 sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY amd64
SRCDIRNAME is liberty
/mnt/scr1/SnapTest/snapshots-opa/log/liberty_0827Thu_0745
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname liberty
*** finished standard tests for liberty ***
Total time = 0m 48s
*** finished tests in liberty ***
More information about the opa-nightly-tests
