[opa-nightly-tests] jam OPA_Daily_Tests_0825Tue_FAILED!!!
HDF Tester
hdftest at hdfgroup.org
Tue Aug 25 10:57:51 CDT 2009
*** OPA Tests on 0825Tue ***
Tests Summary
****FAILED linew: runtest command failed ****
****FAILED linew: standard****
PASSED colonelk: standard
PASSED duty: standard
PASSED jam: standard
PASSED liberty: standard
PASSED smirom: standard
Tests Time Summary
linew: Ran 1(0/1/0) tests, Grand total test time = 0m 32s
jam: Ran 1(1/0/0) tests, Grand total test time = 0m 49s
smirom: Ran 1(1/0/0) tests, Grand total test time = 0m 59s
liberty: Ran 1(1/0/0) tests, Grand total test time = 0m 56s
colonelk: Ran 1(1/0/0) tests, Grand total test time = 1m 31s
duty: Ran 1(1/0/0) tests, Grand total test time = 2m 7s
jam: Ran 6(0/0/0) hosts, Grand total test time = 3m 5s
Timekeeper log
Timekeeper started at Tue Aug 25 10:54:50 CDT 2009
Timekeeper sleeping for 1800 seconds
Tests Failures
Dumping logfile of linew: standard
Last 30 lines of /mnt/scr1/SnapTest/snapshots-opa/log/linew_0825Tue_1055
gmake[1]: warning: -jN forced in submake: disabling jobserver mode.
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/src'
Making check in test
gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake -j 2 sanity test_primitives test_barriers
gmake[2]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake[2]: warning: -jN forced in submake: disabling jobserver mode.
gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src -I/home/hdftest/snapshots-opa/current/src -g -O2 -MT sanity.o -MD -MP -MF .deps/sanity.Tpo -c -o sanity.o /home/hdftest/snapshots-opa/current/test/sanity.c
gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src -I/home/hdftest/snapshots-opa/current/src -g -O2 -MT test_primitives.o -MD -MP -MF .deps/test_primitives.Tpo -c -o test_primitives.o /home/hdftest/snapshots-opa/current/test/test_primitives.c
mv -f .deps/sanity.Tpo .deps/sanity.Po
gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src -I/home/hdftest/snapshots-opa/current/src -g -O2 -MT test_barriers.o -MD -MP -MF .deps/test_barriers.Tpo -c -o test_barriers.o /home/hdftest/snapshots-opa/current/test/test_barriers.c
mv -f .deps/test_barriers.Tpo .deps/test_barriers.Po
gcc -g -O2 -o sanity sanity.o ../src/libopa.a -lpthread
gcc -g -O2 -o test_barriers test_barriers.o ../src/libopa.a -lpthread
mv -f .deps/test_primitives.Tpo .deps/test_primitives.Po
gcc -g -O2 -o test_primitives test_primitives.o ../src/libopa.a -lpthread
Undefined first referenced
symbol in file
pthread_yield test_primitives.o
ld: fatal: Symbol referencing errors. No output written to test_primitives
collect2: ld returned 1 exit status
gmake[2]: *** [test_primitives] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=0: Tue Aug 25 10:55:37 CDT 2009 =====
Dumping done
Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA: Neil
updated: 2009/05/05
Tests Details
Testing all hosts.
opa
10:54:36 up 54 days, 2:18, 27 users, load average: 0.09, 0.08, 0.32
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/sda3 31738420 3076844 27023348 11% /
/dev/sda1 101086 50879 44988 54% /boot
/dev/sda2 31738420 277944 29822248 1% /tmp
/dev/sda6 31738392 3796812 26303356 13% /var
/dev/sda7 31738392 14149992 15950176 48% /usr
/dev/sda8 124991068 10384976 108154392 9% /var/tmp
/dev/mapper/VolGroup00-home
198351840 11682776 176430704 7% /home
/dev/sde1 565688764 27600632 508889196 6% /scr
/dev/sdc1 961432072 448191716 464402356 50% /mnt/scr1
/dev/sdd1 961432072 229283820 683310252 26% /mnt/hdf
tmpfs 1551408 0 1551408 0% /dev/shm
gumund:/data/ftp 480719072 179000992 277298880 40% /mnt/ftp
gumund:/data/web 480719072 179000992 277298880 40% /mnt/web
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
FTP flag is
Running CVS checkout with output saved in
/mnt/scr1/SnapTest/snapshots-opa/log/CVS_LOG_0825Tue
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0825Tue.8898: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0825Tue.8898': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
smirom
colonelk
duty
liberty
Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname linew
Using configname option for -configname
opa
10:54am up 5 day(s), 22:54, 8 users, load average: 1.32, 2.20, 2.43
/ (/dev/dsk/c1t0d0s0 ):53434472 blocks 8045930 files
/devices (/devices ): 0 blocks 0 files
/system/contract (ctfs ): 0 blocks 2147483607 files
/proc (proc ): 0 blocks 29917 files
/etc/mnttab (mnttab ): 0 blocks 0 files
/etc/svc/volatile (swap ):16820336 blocks 1182897 files
/system/object (objfs ): 0 blocks 2147483484 files
/etc/dfs/sharetab (sharefs ): 0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):53434472 blocks 8045930 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):53434472 blocks 8045930 files
/dev/fd (fd ): 0 blocks 0 files
/tmp (swap ):16820336 blocks 1182897 files
/var/run (swap ):16820336 blocks 1182897 files
/home (jam:/home ):373338128 blocks 51006883 files
/mnt/hdf (jam:/mnt/hdf ):1464296504 blocks 118067210 files
/mnt/scr1 (jam:/mnt/scr1 ):1026480664 blocks 117829565 files
/mnt/web (gumund:/mnt/web ):603436128 blocks 60658995 files
/mnt/ftp (gumund:/mnt/ftp ):603436128 blocks 60658995 files
TEST_TYPES=standard
Running standard
Tue Aug 25 10:55:05 CDT 2009
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_141414-08 sun4u sparc SUNW,A70
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: !: not found
SRCDIRNAME is linew
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname linew
*** finished standard tests for linew ***
Total time = 0m 32s
*** finished tests in linew ***
****FAILED linew: Abnormal exit from runtest ****
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname jam
opa
10:54:56 up 54 days, 2:19, 27 users, load average: 0.14, 0.09, 0.32
/dev/sda2 31738420 277948 29822244 1% /tmp
/dev/sdc1 961432072 448191748 464402324 50% /mnt/scr1
TEST_TYPES=standard
Running standard
Tue Aug 25 10:55:07 CDT 2009
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-128.1.16.el5 #1 SMP Tue Jun 30 06:10:28 EDT 2009 i686 i686 i386 GNU/Linux
SRCDIRNAME is jam
/mnt/scr1/SnapTest/snapshots-opa/log/jam_0825Tue_1055
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname jam
*** finished standard tests for jam ***
Tue Aug 25 10:55:55 CDT 2009
Total time = 0m 48s
*** finished tests in jam ***
Testing smirom
ssh smirom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname smirom
opa
10:54am up 4 days 18:47, 7 users, load average: 0.00, 0.00, 0.09
/dev/hdb1 76920416 9628300 63384708 14% /
udev 1991252 116 1991136 1% /dev
/dev/sda2 129736964 31116148 98620816 24% /scr
/dev/sdb1 76920416 29624212 43388796 41% /usr
jam:/home 198351840 11682752 176430720 7% /home
jam:/mnt/hdf 961432096 229283840 683310272 26% /mnt/hdf
jam:/mnt/scr1 961432096 448191776 464402336 50% /mnt/scr1
TEST_TYPES=standard
Running standard
Tue Aug 25 10:55:09 CDT 2009
*** starting standard tests in smirom ***
Uname -a: Linux smirom 2.6.16.60-0.34-smp #1 SMP Fri Jan 16 14:59:01 UTC 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is smirom
/mnt/scr1/SnapTest/snapshots-opa/log/smirom_0825Tue_1055
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname smirom
*** finished standard tests for smirom ***
Tue Aug 25 10:56:08 CDT 2009
Total time = 0m 59s
*** finished tests in smirom ***
Testing colonelk
ssh colonelk -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname colonelk
opa
10:55:01 up 6 days, 21:49, 0 users, load average: 0.00, 0.00, 0.00
/dev/hda3 29753588 3608764 24609012 13% /
/dev/hda2 49961020 1173440 46208748 3% /tmp
/dev/hda6 9920592 1005316 8403208 11% /var
/dev/hda5 19840892 10006144 8810608 54% /scr
/dev/hda1 101086 33315 62552 35% /boot
tmpfs 517644 0 517644 0% /dev/shm
TEST_TYPES=standard
Running standard
Tue Aug 25 10:55:12 CDT 2009
*** starting standard tests in colonelk ***
Uname -a: Linux colonelk 2.6.18-128.4.1.el5 #1 SMP Tue Aug 4 20:23:34 EDT 2009 i686 i686 i386 GNU/Linux
SRCDIRNAME is colonelk
/mnt/scr1/SnapTest/snapshots-opa/log/colonelk_0825Tue_1055
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname colonelk
*** finished standard tests for colonelk ***
Tue Aug 25 10:56:42 CDT 2009
Total time = 1m 30s
*** finished tests in colonelk ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname duty
opa
10:55AM up 90 days, 22:50, 16 users, load averages: 0.00, 0.00, 0.00
Filesystem 1K-blocks Used Avail Capacity Mounted on
/dev/aacd0s1a 507630 60994 406026 13% /
devfs 1 1 0 100% /dev
/dev/aacd0s1h 188433016 120649130 52709246 70% /data
/dev/aacd0s1g 32494668 21029540 8865556 70% /local_home
/dev/aacd0s1f 12186190 2772518 8438778 25% /usr
/dev/aacd0s1d 507630 46166 420854 10% /var
/dev/aacd0s1e 253678 334 233050 0% /var/tmp
procfs 4 4 0 100% /proc
jam:/home 198351840 11682776 176430704 6% /home
jam:/mnt/scr1 961432072 448191772 464402300 49% /mnt/scr1
gumund:/data/web 480719056 179000992 277298864 39% /mnt/web
gumund:/data/ftp 480719056 179000992 277298864 39% /mnt/ftp
devfs 1 1 0 100% /var/named/dev
/dev/md0 126702 342 116224 0% /tmp
jam:/mnt/hdf 961432072 229283820 683310252 25% /mnt/hdf
TEST_TYPES=standard
Running standard
Tue Aug 25 10:55:14 CDT 2009
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008 sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY i386
SRCDIRNAME is duty
/mnt/scr1/SnapTest/snapshots-opa/log/duty_0825Tue_1055
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname duty
*** finished standard tests for duty ***
Tue Aug 25 10:57:21 CDT 2009
Total time = 2m 7s
*** finished tests in duty ***
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname liberty
opa
10:55AM up 90 days, 22:52, 7 users, load averages: 0.00, 0.00, 0.00
/dev/aacd0s1a 507630 86918 380102 19% /
/dev/aacd0s1g 47047830 17742542 25541462 41% /local_home
/dev/aacd0s1f 12186190 4192832 7018464 37% /usr
/dev/aacd0s1d 1012974 99422 832516 11% /var
/dev/aacd0s1e 507630 336490 130530 72% /var/tmp
jam:/mnt/scr1 961432072 448191780 464402292 49% /mnt/scr1
/dev/md0 126702 340 116226 0% /tmp
TEST_TYPES=standard
Running standard
Tue Aug 25 10:55:16 CDT 2009
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008 sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY amd64
SRCDIRNAME is liberty
/mnt/scr1/SnapTest/snapshots-opa/log/liberty_0825Tue_1055
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname liberty
*** finished standard tests for liberty ***
Tue Aug 25 10:56:12 CDT 2009
Total time = 0m 56s
*** finished tests in liberty ***
More information about the opa-nightly-tests
