[opa-nightly-tests] jam OPA_Daily_Tests_0823Sun_FAILED!!!
HDF Tester hdftest at hdfgroup.org
Sun Aug 23 08:03:10 CDT 2009
*** OPA Tests on 0823Sun ***
   Tests Summary
****FAILED linew: runtest command failed ****
****FAILED linew: standard****
PASSED colonelk: standard
PASSED duty: standard
PASSED jam: standard
PASSED liberty: standard
PASSED smirom: standard
   Tests Time Summary
jam: Ran 1(1/0/0) tests, Grand total test time =  0m 49s
smirom: Ran 1(1/0/0) tests, Grand total test time =  0m 59s
liberty: Ran 1(1/0/0) tests, Grand total test time =  0m 55s
linew: Ran 1(0/1/0) tests, Grand total test time =  1m 11s
colonelk: Ran 1(1/0/0) tests, Grand total test time =  1m 31s
duty: Ran 1(1/0/0) tests, Grand total test time =  2m 1s
jam: Ran 6(0/0/0) hosts, Grand total test time =  2m 59s
   Timekeeper log
Timekeeper started at Sun Aug 23 08:00:15 CDT 2009
Timekeeper sleeping for 1800 seconds
   Tests Failures
Dumping logfile of linew: standard
Last 30 lines of /mnt/scr1/SnapTest/snapshots-opa/log/linew_0823Sun_0800
gmake[1]: warning: -jN forced in submake: disabling jobserver mode.
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/src'
Making check in test
gmake[1]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake -j 2  sanity test_primitives test_barriers
gmake[2]: Entering directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake[2]: warning: -jN forced in submake: disabling jobserver mode.
gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src  -I/home/hdftest/snapshots-opa/current/src   -g -O2 -MT sanity.o -MD -MP -MF .deps/sanity.Tpo -c -o sanity.o /home/hdftest/snapshots-opa/current/test/sanity.c
gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src  -I/home/hdftest/snapshots-opa/current/src   -g -O2 -MT test_primitives.o -MD -MP -MF .deps/test_primitives.Tpo -c -o test_primitives.o /home/hdftest/snapshots-opa/current/test/test_primitives.c
mv -f .deps/sanity.Tpo .deps/sanity.Po
gcc -DHAVE_CONFIG_H -I. -I/home/hdftest/snapshots-opa/current/test -I../src  -I/home/hdftest/snapshots-opa/current/src   -g -O2 -MT test_barriers.o -MD -MP -MF .deps/test_barriers.Tpo -c -o test_barriers.o /home/hdftest/snapshots-opa/current/test/test_barriers.c
mv -f .deps/test_barriers.Tpo .deps/test_barriers.Po
gcc  -g -O2   -o sanity sanity.o ../src/libopa.a -lpthread
gcc  -g -O2   -o test_barriers test_barriers.o ../src/libopa.a -lpthread
mv -f .deps/test_primitives.Tpo .deps/test_primitives.Po
gcc  -g -O2   -o test_primitives test_primitives.o ../src/libopa.a -lpthread
Undefined			first referenced
 symbol  			    in file
pthread_yield                       test_primitives.o
ld: fatal: Symbol referencing errors. No output written to test_primitives
collect2: ld returned 1 exit status
gmake[2]: *** [test_primitives] Error 1
gmake[2]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/scr/hdftest/snapshots-opa/TestDir/linew/test'
gmake: *** [check-recursive] Error 1
Failed running make check
===== Exit bin/snapshot with status=0: Sun Aug 23 08:01:41 CDT 2009 =====
Dumping done
   Watchers List
OPA Daily test features/platforms watchers and procedure
Procedure:
The watcher will investigate and report the cause of failure by 11am.
The developer who checked in the error code may report so by then too.
The watcher or the developer should get the failure fixed and report it
by 3pm.
Watcher for OPA:	 	Neil
updated: 2009/05/05
   Tests Details
Testing all hosts.
opa
 08:00:01 up 51 days, 23:24, 15 users,  load average: 0.00, 0.00, 0.08
Filesystem           1K-blocks      Used Available Use% Mounted on
/dev/sda3             31738420   3076784  27023408  11% /
/dev/sda1               101086     50879     44988  54% /boot
/dev/sda2             31738420    278056  29822136   1% /tmp
/dev/sda6             31738392   3771656  26328512  13% /var
/dev/sda7             31738392  14145924  15954244  47% /usr
/dev/sda8            124991068  14144300 104395068  12% /var/tmp
/dev/mapper/VolGroup00-home
                     198351840  11677504 176435976   7% /home
/dev/sde1            565688764  27747176 508742652   6% /scr
/dev/sdc1            961432072 446791760 465802312  49% /mnt/scr1
/dev/sdd1            961432072 229125276 683468796  26% /mnt/hdf
tmpfs                  1551408         0   1551408   0% /dev/shm
gumund:/data/ftp     480719072 178841504 277458368  40% /mnt/ftp
gumund:/data/web     480719072 178841504 277458368  40% /mnt/web
STANDARD_OPT=op-configure --prefix=${PWD}/opainstall
TEST_TYPES=standard
FTP flag is
Running CVS checkout with output saved in
   /mnt/scr1/SnapTest/snapshots-opa/log/CVS_LOG_0823Sun
Checking MANIFEST file ...
cat: /mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0823Sun.12510: No such file or directory
rm: cannot remove `/mnt/scr1/SnapTest/snapshots-opa/log/#runtest.0823Sun.12510': No such file or directory
*** launching tests from jam ***
TESTHOST is linew
jam
smirom
colonelk
duty
liberty
    Fork off timekeeper 30
Testing linew
ssh linew -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname linew
Using configname option for -configname
opa
  8:00am  up 3 day(s), 19:59,  7 users,  load average: 0.54, 1.01, 1.11
/                  (/dev/dsk/c1t0d0s0 ):54790598 blocks  8043198 files
/devices           (/devices          ):       0 blocks        0 files
/system/contract   (ctfs              ):       0 blocks 2147483607 files
/proc              (proc              ):       0 blocks    29918 files
/etc/mnttab        (mnttab            ):       0 blocks        0 files
/etc/svc/volatile  (swap              ):16840768 blocks  1182898 files
/system/object     (objfs             ):       0 blocks 2147483484 files
/etc/dfs/sharetab  (sharefs           ):       0 blocks 2147483646 files
/platform/sun4u-us3/lib/libc_psr.so.1(/platform/sun4u-us3/lib/libc_psr/libc_psr_hwcap1.so.1):54790598 blocks  8043198 files
/platform/sun4u-us3/lib/sparcv9/libc_psr.so.1(/platform/sun4u-us3/lib/sparcv9/libc_psr/libc_psr_hwcap1.so.1):54790598 blocks  8043198 files
/dev/fd            (fd                ):       0 blocks        0 files
/tmp               (swap              ):16840768 blocks  1182898 files
/var/run           (swap              ):16840768 blocks  1182898 files
/home              (jam:/home         ):373348672 blocks 51006775 files
/mnt/hdf           (jam:/mnt/hdf      ):1464613592 blocks 118078169 files
/mnt/scr1          (jam:/mnt/scr1     ):1029280512 blocks 117845183 files
/mnt/web           (gumund:/mnt/web   ):603755112 blocks 60659283 files
/mnt/ftp           (gumund:/mnt/ftp   ):603755112 blocks 60659283 files
TEST_TYPES=standard
Running standard
Sun Aug 23 08:00:31 CDT 2009
*** starting standard tests in linew ***
Uname -a: SunOS linew 5.10 Generic_141414-08 sun4u sparc SUNW,A70
/mnt/scr1/SnapTest/snapshots-opa/bin/runtest: !: not found
SRCDIRNAME is linew
Running snapshot with output saved in
SNAPCMD is srcdir test clean
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname linew
*** finished standard tests for linew ***
Total time = 1m 10s
*** finished tests in linew ***
****FAILED linew: Abnormal exit from runtest ****
Testing jam
ssh jam -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname jam
opa
 08:00:22 up 51 days, 23:24, 15 users,  load average: 0.07, 0.02, 0.08
/dev/sda2             31738420    278060  29822132   1% /tmp
/dev/sda6             31738392   3771696  26328472  13% /var
/dev/sdc1            961432072 446791824 465802248  49% /mnt/scr1
TEST_TYPES=standard
Running standard
Sun Aug 23 08:00:32 CDT 2009
*** starting standard tests in jam ***
Uname -a: Linux jam 2.6.18-128.1.16.el5 #1 SMP Tue Jun 30 06:10:28 EDT 2009 i686 i686 i386 GNU/Linux
SRCDIRNAME is jam
   /mnt/scr1/SnapTest/snapshots-opa/log/jam_0823Sun_0800
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname jam
*** finished standard tests for jam ***
Sun Aug 23 08:01:21 CDT 2009
Total time = 0m 49s
*** finished tests in jam ***
Testing smirom
ssh smirom -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname smirom
opa
  8:00am  up 2 days 15:53,  4 users,  load average: 0.00, 0.00, 0.07
/dev/hdb1             76920416  10136036  62876972  14% /
udev                   1991252       116   1991136   1% /dev
/dev/sda2            129736964  30305776  99431188  24% /scr
/dev/sdb1             76920416  29618324  43394684  41% /usr
jam:/home            198351840  11677504 176436000   7% /home
jam:/mnt/hdf         961432096 229125280 683468800  26% /mnt/hdf
jam:/mnt/scr1        961432096 446791840 465802240  49% /mnt/scr1
TEST_TYPES=standard
Running standard
Sun Aug 23 08:00:34 CDT 2009
*** starting standard tests in smirom ***
Uname -a: Linux smirom 2.6.16.60-0.34-smp #1 SMP Fri Jan 16 14:59:01 UTC 2009 x86_64 x86_64 x86_64 GNU/Linux
SRCDIRNAME is smirom
   /mnt/scr1/SnapTest/snapshots-opa/log/smirom_0823Sun_0800
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname smirom
*** finished standard tests for smirom ***
Sun Aug 23 08:01:33 CDT 2009
Total time = 0m 59s
*** finished tests in smirom ***
Testing colonelk
ssh colonelk -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname colonelk
opa
 08:00:27 up 4 days, 18:55,  0 users,  load average: 0.00, 0.00, 0.00
/dev/hda3             29753588   3608704  24609072  13% /
/dev/hda2             49961020   1184228  46197960   3% /tmp
/dev/hda6              9920592   1004052   8404472  11% /var
/dev/hda5             19840892   9690816   9125936  52% /scr
/dev/hda1               101086     33315     62552  35% /boot
tmpfs                   517644         0    517644   0% /dev/shm
TEST_TYPES=standard
Running standard
Sun Aug 23 08:00:37 CDT 2009
*** starting standard tests in colonelk ***
Uname -a: Linux colonelk 2.6.18-128.4.1.el5 #1 SMP Tue Aug 4 20:23:34 EDT 2009 i686 i686 i386 GNU/Linux
SRCDIRNAME is colonelk
   /mnt/scr1/SnapTest/snapshots-opa/log/colonelk_0823Sun_0800
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname colonelk
*** finished standard tests for colonelk ***
Sun Aug 23 08:02:08 CDT 2009
Total time = 1m 31s
*** finished tests in colonelk ***
Testing duty
ssh duty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname duty
opa
 8:00AM  up 88 days, 19:56, 17 users, load averages: 0.00, 0.00, 0.00
Filesystem       1K-blocks      Used     Avail Capacity  Mounted on
/dev/aacd0s1a       507630     60994    406026    13%    /
devfs                    1         1         0   100%    /dev
/dev/aacd0s1h    188433016 120649098  52709278    70%    /data
/dev/aacd0s1g     32494668  22723210   7171886    76%    /local_home
/dev/aacd0s1f     12186190   2770778   8440518    25%    /usr
/dev/aacd0s1d       507630     46220    420800    10%    /var
/dev/aacd0s1e       253678       334    233050     0%    /var/tmp
procfs                   4         4         0   100%    /proc
jam:/home        198351840  11677504 176435976     6%    /home
jam:/mnt/scr1    961432072 446791848 465802224    49%    /mnt/scr1
gumund:/data/web 480719056 178841500 277458356    39%    /mnt/web
gumund:/data/ftp 480719056 178841500 277458356    39%    /mnt/ftp
devfs                    1         1         0   100%    /var/named/dev
/dev/md0            126702        50    116516     0%    /tmp
jam:/mnt/hdf     961432072 229125276 683468796    25%    /mnt/hdf
TEST_TYPES=standard
Running standard
Sun Aug 23 08:00:39 CDT 2009
*** starting standard tests in duty ***
Uname -a: FreeBSD duty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:10:59 CDT 2008     sukoziol at duty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/DUTY  i386
SRCDIRNAME is duty
   /mnt/scr1/SnapTest/snapshots-opa/log/duty_0823Sun_0800
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname duty
*** finished standard tests for duty ***
Sun Aug 23 08:02:40 CDT 2009
Total time = 2m 1s
*** finished tests in duty ***
Testing liberty
ssh liberty -n cd /home/hdftest/snapshots-opa;/mnt/scr1/SnapTest/snapshots-opa/bin/runtest -nodiff -nocvs -configname liberty
opa
 8:00AM  up 88 days, 19:58, 10 users, load averages: 0.00, 0.00, 0.00
/dev/aacd0s1a       507630     86918    380102    19%    /
/dev/aacd0s1g     47047830  20506586  22777418    47%    /local_home
/dev/aacd0s1f     12186190   4133002   7078294    37%    /usr
/dev/aacd0s1d      1012974     98976    832962    11%    /var
/dev/aacd0s1e       507630    336490    130530    72%    /var/tmp
jam:/mnt/scr1    961432072 446791856 465802216    49%    /mnt/scr1
/dev/md0            126702        54    116512     0%    /tmp
TEST_TYPES=standard
Running standard
Sun Aug 23 08:00:42 CDT 2009
*** starting standard tests in liberty ***
Uname -a: FreeBSD liberty.hdfgroup.uiuc.edu 6.3-STABLE FreeBSD 6.3-STABLE #1: Fri Jul 25 17:21:46 CDT 2008     sukoziol at liberty.hdfgroup.uiuc.edu:/usr/obj/usr/src/sys/LIBERTY  amd64
SRCDIRNAME is liberty
   /mnt/scr1/SnapTest/snapshots-opa/log/liberty_0823Sun_0800
SNAPCMD_OPT is op-configure --prefix=${PWD}/opainstall zlib /usr/include,/usr/lib srcdirname liberty
*** finished standard tests for liberty ***
Sun Aug 23 08:01:36 CDT 2009
Total time = 0m 54s
*** finished tests in liberty ***
More information about the opa-nightly-tests mailing list
