[opa-nightly-tests] co-login OPA_Daily_Tests_0430Thu_FAILED!!!
HDF Tester
hdftest at ncsa.uiuc.edu
Thu Apr 30 11:49:18 CDT 2009
*** OPA Tests on 0430Thu ***
Tests Summary
****FAILED co-login: standard****
Tests Time Summary
co-login: Ran 1(0/1/0) tests, Grand total test time = 1m 28s
Timekeeper log
Tests Failures
Dumping logfile of co-login: standard
Last 30 lines of /u/ac/hdftest/snapshots-opa/log/co-login_0430Thu_1148
Testing fetch and add with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_primitives.c:1140 in test_threaded_faa()...
Testing fetch and add return values with 100 threads /bin/sh: line 1: 27767 Segmentation fault ${dir}$tst
FAIL: test_primitives
Testing memory barrier sanity PASSED
Testing memory barriers with linear array with 2 threads PASSED
Testing memory barriers with local variables with 2 threads PASSED
Testing memory barriers with scattered array with 2 threads PASSED
Testing memory barriers with linear array with 10 threads PASSED
Testing memory barriers with local variables with 10 threads PASSED
Testing memory barriers with scattered array with 10 threads PASSED
Testing memory barriers with linear array with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:304 in test_barriers_linear_array()...
Testing memory barriers with local variables with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:558 in test_barriers_variables()...
Testing memory barriers with scattered array with 100 threads *FAILED*
at /u/ac/hdftest/snapshots-opa/current/test/test_barriers.c:660 in test_barriers_scattered_array()...
***** 3 BARRIERS TESTS FAILED! *****
FAIL: test_barriers
2 of 3 tests failed
Please report to https://trac.mcs.anl.gov/projects/openpa/newticket
gmake[2]: *** [check-TESTS] Error 1
gmake[2]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/co-login/test'
gmake[1]: *** [check-am] Error 2
gmake[1]: Leaving directory `/u/ac/hdftest/snapshots-opa/TestDir/co-login/test'
gmake: *** [check-recursive] Error 1
===== Exit bin/snapshot with status=2: Thu Apr 30 11:49:18 CDT 2009 =====
Dumping done
Watchers List
More information about the opa-nightly-tests
