[Nek5000-users] Small random perturbations
nek5000-users at lists.mcs.anl.gov
Fri Mar 9 13:10:28 CST 2018
Hi Ali,
Two questions:
1) How are you forcing your flow? (Do you have periodic boundary conditions in x ? Are you using constant flow rate?
(p54 = -1; p55=1 would be recommended for periodic bcs
with ffx=0 in the .usr file).
2) If your Reynolds number is Re = Ubar H / nu , where
H=channel half height and
Re > (2/3) * 5772
then you should find that you have sustained unsteadiness.
That is, you should have linear instabilities that will grow and saturate to some truly nonlinear (unsteady) state.
[ The 2/3 is because Re=5772 is the transition point for 2D plane channel flow based on U_max, when the background profile is
U=(1-y*y)*Umax and H=1. In this case, Ubar = 2/3 * Umax .]
In general, you won't have turbulence in 2D.
hth,
Paul
From: Nek5000-users <nek5000-users-bounces at lists.mcs.anl.gov> on behalf of nek5000-users at lists.mcs.anl.gov <nek5000-users at lists.mcs.anl.gov>
Sent: Friday, March 9, 2018 11:21:46 AM
To: nek5000-users at lists.mcs.anl.gov
Subject: [Nek5000-users] Small random perturbations
Dear Dr.Fischer,
Actually, I am doing 2-D simulation, at least for now, so no z-dimension is up there. Am I wrong to do DNS in 2-D? Also, I just started doing so, and I think my files are not useful at this point.
Let me try more, maybe I am missing something.
Thank you for your awesome free code and your continuous support.
Ali
https://lists.mcs.anl.gov/pipermail/nek5000-users/2018-March/005133.html
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20180309/ad3aa388/attachment.html>
More information about the Nek5000-users
